    Ghost Overlay / OMXPlayerTransparency
    mmm-pirvideoplayer
    40 Posts 9 Posters 35.6k Views 8 Watching
      Reotch2 @Mykle1
      @Mykle1 said in Ghost Overlay / OMXPlayerTransparency:
      What version combination of MM and Electron are you running? We’ve had great success eliminating excessive Electron CPU usage with MM v2.1.0 and Electron v1.4.15 on Pi3 B’s, and just recently, a Pi2 as well.
      Obviously, the results are at the end of the topic
      https://forum.magicmirror.builders/topic/4684/electron-cpu-usage
      Unsure on electron (kinda hard to find a version). But I’m running 2.1.2, and still running Jessie. I should have some more time MUCH later today to tinker. I’ll use the steps on page 15 of that thread for a clean install and report back. Do any of these combinations allow GPU usage within electron? As always, appreciate the help.
      -Rich
      Nystro0mN 1 Reply Last reply Reply Quote 0
      • Nystro0mN Offline
        Nystro0m @Reotch2
        @Reotch2
        I got helped with this yesterday from Mykle and i went from 80-100% cpu usage to 2-45% cpu usage.
        The biggest difference was by downgrading electron to 1.4.15.
        But running MM 2.1.0 instead of 2.1.2 also made a improvement.
        How to downgrade electron
        Navigate to your home folder, from here delete all maps including electron. there should be two:
        .electron & .electron-glpyh.
        Navigate to you node-modules inside MM.
        § cd ~/MagicMirror/node_modules
        Uninstall electron by
        § sudo npm uninstall electron
        install electron with desired version in this case 1.4.15 by:
        § sudo npm install electron@1.4.15
        Now open file manager or navigate to “~/MagicMirror/node_modules/electron” and look in package.json
        Here you can confirm your version number of electron.
        How to downgrade MagicMirror
        If you want to downgrade your MM version you will need to make a new install.
        I would suggest everyone doing this to NOT delete it BEFORE you have made a backup.
        You can find MM 2.1.0 here (thanks to Mykle for providing me with link):
        https://github.com/MichMich/MagicMirror/archive/v2.1.0.zip.
        Unpack the zip in you home folder, and rename it to MagicMirror
        then just run npm install from the folder.
        § cd ~/MagicMirror/
        § npm install
        Note: You will need to re-install electron 1.4.15 after the clean install of MM 2.1.0.
        Make sure to have everything up and running before you do that.
        I did run the gun and needed to redo everything twice.
        R 1 Reply Last reply Reply Quote 2
          Reotch2 @Nystro0m
          @Nystro0m So went all out, and did a fresh install of Raspbian Stretch, MM2.1.0 and electron 1.4.15… even with just the default modules and htmlvideo, electron has the CPU pegged at >75% playing the .webm file. The video is slightly less choppy than before, but still not as seamless as OMXPlayer. Do I just have a crappy Pi3? Are there memory, GPU, or overclock settings I’m missing in my pi config file that may help? I’m also running it through PM2… is that causing issues?
          Thanks,
          Rich
          Mykle1M Nystro0mN 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @Reotch2
            @Reotch2 said in Ghost Overlay / OMXPlayerTransparency:
            If you read through the Electron CPU Usage you would see that your results are not as bad as you think they are. Many people saw drastically worse results without asking their Pi to run htmlvideo. A simple default installation of MM 2.1.1 or higher and Electron higher than 1.4.15 would bring a Pi3 to its knees.
            I don’t believe it’s your Pi3. Again, all the testing we did in that topic pretty much ruled that out and pointed the finger squarely at the MM/Electron version combination,
            My opinion: We’re asking the Pi to do things that it’s just not capable of, or at least pushing it to its limits. I’m not bashing the Pi. I love the Pi. There’s just only so much it can do. I think you should be glad that OMXPlayer is giving you the results you want on the Pi. If you moved from the Pi to something more robust then you would likely not have the problem running htmlvideo within MM, no matter what versions of MM and Electron.
            • Nystro0mN Offline
              Nystro0m @Reotch2
              @Reotch2
              Sorry that it does not seem to work.
              The only thing i can think about now is the read speed of your micro SD card.
              In video editing playback often is limited due to read speeds of the drive.
              But here we talk about 100MB+ per second. And that is an understatement.
              I would try to see if you can get html video running from a embedded source such as Youtube.
              Else, if you have not tried running OMXPlayer and the PIR module as “behind” in the config i have no idea.
              Im interesting in following up this project in the future, when i run out of things to incorporate in my MM.
              If you decide to not follow this up anymore i would love to see a summary post what you have up and running, including scripts and such. Also a summary of what did and did not work in your research :)
                Reotch2 @Mykle1
                @Mykle1 @Nystro0m
                Honestly… this is good news. Gives me permission to stop troubleshooting :). I’m still doing a clean install of STRETCH (having minor issues on another thread), and I’ll fall back on my OMXPlayer workaround.
                Thanks EVERYONE for helping me try every possible workaround. When the time comes for me to scale-up to a bathroom mirror, I’ll definitely plan on a little more processing power.
                Also, I’ll post my final workaround/setup when I’m back up and running.
                  Yeah dude, keep us posted!
                    jasondreher @pyrosmiley
                    @pyrosmiley
                    What module did you use to play the .webm file? I have converted a file but dont know how to play it on the MM.
                    pyrosmileyP 1 Reply Last reply Reply Quote 0
                    • pyrosmileyP Offline
                      pyrosmiley @jasondreher
                      @jasondreher
                      I use the MMM-htmlvideo module for it. Webm seems to work best for me as a format to reduce choppiness but even then it’s certainly not perfect. This module is great though!
                        bhepler Module Developer
                        I played around with this a bit. In the end, running omxplayer with a resized and rotated video was the way to go. Oh, and I re-edited a few videos together in order to provide a more seamless experience. I’ll see about capturing some video tomorrow and uploading it.
                        I used pm2 to manage a quick script to keep the video going in case of failure. Overall, I’m quite pleased. Now to do the same to my office mirror…
                          Reotch2 @bhepler
                          @bhepler Are you running a borderless OMX window centered on your mirror? If so, what parameters you starting it with?
                          After all of my troubleshooting, it seems like OMX is the best solution. I’ve just been putting up with the loss of module brightness. Overall though, good enough to get me through Halloween.
                            bhepler Module Developer @Reotch2
                            @Reotch2 I started by editing together the videos into a single 5 minute video, using the vertical sources. These show up on my normal computer monitor as rotated 90 degrees. Once i had the video edited (with several of the buffer video interspersed to add some tension), I output the video as a full resolution 1920x1080 MP4. I copied that video over to the pi and then used ffdshow to rotate the video 90 degrees. This part took close to 30 minutes and it made the pi sweat resistors.
                            Once the file was rotated, I created a one-line script file called boo.sh that contains omxplayer -p -o hdmi --loop --alpha 85 boo.mp4. Start it up with pm2 (pm2 start boo.sh) and then save it.
                            Originally I was going to convert the file to webm, but the ffdshow that installed on the pi doesn’t have that switch enabled. I didn’t feel like recompiling ffdshow, so I just went with a H264 encoded MP4.
                              Reotch2 @bhepler
                              @bhepler Wow. Well done. That’s exactly where I ended up except my pm2 file name is called “omx.sh”. I ran into issues with the looped video interrupting my Monitors sleep mode (PIR Sensor), so I ended up disabling it and setting a crontab for both sleep and pm2 stop/start omx.sh. My original post was only because the —alpha was dimming other modules. Are you seeing the same?
                              Good work.
                                Video of the ghost in the mirror can be found here: https://youtu.be/6hb1N1tYcPc
                                As an aside, this morning I changed the command to omxplayer -p -o local --loop --alpha 85 boo.mp4 to cut the sound from the video file. It woke me up when the mirror switched on this morning at 5 AM.
                                G 1 Reply Last reply Reply Quote 1
                                • G Offline
                                  Gubert @bhepler
                                  @bhepler said in Ghost Overlay / OMXPlayerTransparency:
                                  Realy nice solution! Looks awesome!
                                  Could you sum up all the things needed for that?
                                  Reading through this 4 Pages is very difficulty.
                                  Would be very thankful.
