    Ghost Overlay / OMXPlayerTransparency
    mmm-pirvideoplayer
    40 Posts 9 Posters 36.3k Views 8 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Reotch2
      @Reotch2 said in Ghost Overlay / OMXPlayerTransparency:
      even with just the default modules and htmlvideo, electron has the CPU pegged at >75% playing the .webm file.
      If you read through the Electron CPU Usage you would see that your results are not as bad as you think they are. Many people saw drastically worse results without asking their Pi to run htmlvideo. A simple default installation of MM 2.1.1 or higher and Electron higher than 1.4.15 would bring a Pi3 to its knees.
      The video is slightly less choppy than before, but still not as seamless as OMXPlayer. Do I just have a crappy Pi3?
      I don’t believe it’s your Pi3. Again, all the testing we did in that topic pretty much ruled that out and pointed the finger squarely at the MM/Electron version combination,
      My opinion: We’re asking the Pi to do things that it’s just not capable of, or at least pushing it to its limits. I’m not bashing the Pi. I love the Pi. There’s just only so much it can do. I think you should be glad that OMXPlayer is giving you the results you want on the Pi. If you moved from the Pi to something more robust then you would likely not have the problem running htmlvideo within MM, no matter what versions of MM and Electron.
      R 1 Reply Last reply
      • Nystro0mN
        Nystro0m @Reotch2
        @Reotch2
        Sorry that it does not seem to work.
        The only thing i can think about now is the read speed of your micro SD card.
        In video editing playback often is limited due to read speeds of the drive.
        But here we talk about 100MB+ per second. And that is an understatement.
        I would try to see if you can get html video running from a embedded source such as Youtube.
        Else, if you have not tried running OMXPlayer and the PIR module as “behind” in the config i have no idea.
        Im interesting in following up this project in the future, when i run out of things to incorporate in my MM.
        If you decide to not follow this up anymore i would love to see a summary post what you have up and running, including scripts and such. Also a summary of what did and did not work in your research :)
          Reotch2 @Mykle1
          @Mykle1 @Nystro0m
          Honestly… this is good news. Gives me permission to stop troubleshooting :). I’m still doing a clean install of STRETCH (having minor issues on another thread), and I’ll fall back on my OMXPlayer workaround.
          Thanks EVERYONE for helping me try every possible workaround. When the time comes for me to scale-up to a bathroom mirror, I’ll definitely plan on a little more processing power.
          Also, I’ll post my final workaround/setup when I’m back up and running.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Yeah dude, keep us posted!
              jasondreher @pyrosmiley
              @pyrosmiley
              What module did you use to play the .webm file? I have converted a file but dont know how to play it on the MM.
              pyrosmileyP 1 Reply Last reply
              • pyrosmileyP
                pyrosmiley @jasondreher
                @jasondreher
                I use the MMM-htmlvideo module for it. Webm seems to work best for me as a format to reduce choppiness but even then it’s certainly not perfect. This module is great though!
                  bhepler Module Developer
                  I played around with this a bit. In the end, running omxplayer with a resized and rotated video was the way to go. Oh, and I re-edited a few videos together in order to provide a more seamless experience. I’ll see about capturing some video tomorrow and uploading it.
                  I used pm2 to manage a quick script to keep the video going in case of failure. Overall, I’m quite pleased. Now to do the same to my office mirror…
                    Reotch2 @bhepler
                    @bhepler Are you running a borderless OMX window centered on your mirror? If so, what parameters you starting it with?
                    After all of my troubleshooting, it seems like OMX is the best solution. I’ve just been putting up with the loss of module brightness. Overall though, good enough to get me through Halloween.
                    B 1 Reply Last reply
                      bhepler Module Developer @Reotch2
                      @Reotch2 I started by editing together the videos into a single 5 minute video, using the vertical sources. These show up on my normal computer monitor as rotated 90 degrees. Once i had the video edited (with several of the buffer video interspersed to add some tension), I output the video as a full resolution 1920x1080 MP4. I copied that video over to the pi and then used ffdshow to rotate the video 90 degrees. This part took close to 30 minutes and it made the pi sweat resistors.
                      Once the file was rotated, I created a one-line script file called boo.sh that contains omxplayer -p -o hdmi --loop --alpha 85 boo.mp4. Start it up with pm2 (pm2 start boo.sh) and then save it.
                      Originally I was going to convert the file to webm, but the ffdshow that installed on the pi doesn’t have that switch enabled. I didn’t feel like recompiling ffdshow, so I just went with a H264 encoded MP4.
                        Reotch2 @bhepler
                        @bhepler Wow. Well done. That’s exactly where I ended up except my pm2 file name is called “omx.sh”. I ran into issues with the looped video interrupting my Monitors sleep mode (PIR Sensor), so I ended up disabling it and setting a crontab for both sleep and pm2 stop/start omx.sh. My original post was only because the —alpha was dimming other modules. Are you seeing the same?
                        Good work.
                          Video of the ghost in the mirror can be found here: https://youtu.be/6hb1N1tYcPc
                          As an aside, this morning I changed the command to omxplayer -p -o local --loop --alpha 85 boo.mp4 to cut the sound from the video file. It woke me up when the mirror switched on this morning at 5 AM.
                          G 1 Reply Last reply
                          • G
                            Gubert @bhepler
                            @bhepler said in Ghost Overlay / OMXPlayerTransparency:
                            Realy nice solution! Looks awesome!
                            Could you sum up all the things needed for that?
                            Reading through this 4 Pages is very difficulty.
                            Would be very thankful.
