    Just installed magic mirror, now how do I change some things?
    28 Posts 12 Posters 49.1k Views 11 Watching
      Crookedsoul
      I am also very new to the raspberry pi. I see the links but i am having an issue accessing the correct folders to make the needed changes. It may be something simple but I am not seeing it at this time.
      How do you get into the modules to make changes?
      Thanks in advance.
      B L 2 Replies Last reply Reply Quote 0
        bhepler Module Developer @Crookedsoul
        @Crookedsoul The modules that come with the Magic Mirror software can be found in ~/MagicMirror/modules/default/[name of module] (assuming you ran through the tutorial and didn’t change anything).
        Any of the modules that you download from the community (Weatherbug, Instagram, Tides, etc.) need to be installed in their own folder in the modules folder. The positioning of any module is handled by the config.js script located at ~/MagicMirror/config/config.js. In addition to location information, you’ll also define most of the module’s configuration there as well. Think of it as configuration parameters that you’re passing into the module code, so you need to specify those parameters while you’re telling the Magic Mirror system to load up the module.
          Pi-Gi @bhepler
          @bhepler hello everyone.
          I am in the process of making a magic mirror as well. I have downloaded and installed it on my Pi 3. But I am getting a permission denied message when I try to update the current weather with an app ID.
          I have not tried any other modules to update or change at this time.
          Any help will be greatly appreciated.
          Where’s my wallet honey…>>>
          • F
            frog
            I’m not totally sure what your issue is, but it may be permissions when editing the config.js file.
            try:
            sudo nano ~/MagicMirror/config/config.js
            make the change and save it with ctrl-o, ctrl–z
            P V 2 Replies Last reply Reply Quote 0
            • L
              lolobyte @Crookedsoul
              @Crookedsoul
              for guys without command line experience do following!
              login to your raspi.
              execute following command:
              sudo apt-get install mc
              That’s the midnight commander SW. Maybe u know the old DOS norton commander, mc is similar like notons commander.
              U can start mc by typing mc and enter.
              For root privileges type sudo mc.
              Now u can brows with your keyboard or mouse between the folder, view or edit config or other files.
              Good luck
                Pi-Gi @frog
                Thank you I forgot to use Nano
                  Pi-Gi @lolobyte
                  @lolobyte I will try this as well. Thanks guys just really new to this you’re the best.
                  • V
                    VirtualLeonard @frog
                    • H
                      hellboyhum
                      Hello guys. I have just one question. I have installed my magic mirror, and changed everything like hours, temp. etc. But i can’t add my own news from my country…I am from Croatia. Please help me :/
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @hellboyhum
                        @hellboyhum
                        You need to google search for Croatian rss news feeds. Then get the url to the rss file of the news feed. Then add it to your config like this:
                        			disabled: f,
                        			module: 'newsfeed',
                        			position: 'bottom_bar',
                        				feeds: [
                        						title: "NASA",
                        						url: "https://www.nasa.gov/rss/dyn/solar_system.rss"
                        						title: "Reuters Science News",
                        						url: "http://feeds.reuters.com/reuters/scienceNews"
                        						title: "New York Times",
                                            				title: "BBC World News",
                                            				url: "http://feeds.bbci.co.uk/news/world/us_and_canada/rss.xml"
                        • H
                          hellboyhum @Mykle1
                          @Mykle1 First, I want to thank you for your response.! :D Second, I forgot to tell you that I have a bit different magic mirror installed than you think :) I know that I need the RSS news but they don’t work :S
                          I will paste my magic mirror code here so you can see it :/
                          Here we go: --> the document is “smartmirror.py” and I start magic mirror in terminal with command “python smartmirror.py”
                          [0_1509619008226_code.pdf](Uploading 100%)
                          • Mykle1M
                            @hellboyhum
                            So you want me to troubleshoot an issue you’re having using a platform other than this forum’s MagicMirror software?
                            Uhhh . . .
                            • H
                              hellboyhum @Mykle1
                              @Mykle1 I’m so sorry, i don’t know why I can’t past my code here :/
                              class News(Frame):
                              def init(self, parent, *args, **kwargs):
                              Frame.init(self, parent, *args, **kwargs)
                              self.config(bg=‘black’)
                              self.title = ‘Novosti’ # ‘News’ is more internationally generic
                              self.newsLbl = Label(self, text=self.title, font=(‘Helvetica’, medium_text_size), fg=“white”, bg=“black”)
                              self.newsLbl.pack(side=TOP, anchor=W)
                              self.headlinesContainer = Frame(self, bg=“black”)
                              self.headlinesContainer.pack(side=TOP)
                              self.get_headlines()
                              def get_headlines(self):
                                  try:
                                      # remove all children
                                      for widget in self.headlinesContainer.winfo_children():
                                          widget.destroy()
                                      if news_country_code == None:
                                          headlines_url = "http://www.hrt.hr/?id=316&type=100&rss=vijesti"
                                      else:
                                          headlines_url = "http://www.hrt.hr/?id=316&type=100&rss=vijesti" % news_country_code
                                      feed = feedparser.parse(headlines_url)
                                      for post in feed.entries[0:5]:
                                          headline = NewsHeadline(self.headlinesContainer, post.title)
                                          headline.pack(side=TOP, anchor=W)
                                  except Exception as e:
                                      traceback.print_exc()
                                      print "Error: %s. Cannot get news." % e
                                  self.after(600000, self.get_headlines)
                              • Mykle1M
                                @hellboyhum
                                This forum is for MagicMirror users.
                                You’re using smartmirror software.
                                • cowboysdudeC
                                  Looks like Evan Cohen’s magic mirror… that’s a different forum my friend…
                                  • H
                                    hellboyhum @Mykle1
                                    @Mykle1 Oh dammit…I’m so sorry for bothering you. I will install this magic mirror then :D I’m so stupid 😒🔫
                                    cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
                                    • H
                                      hellboyhum @cowboysdude
                                      @cowboysdude I see it now 😂 I will install this magic mirror then :) tkanks to you both for helping me :)
                                      • cowboysdudeC
                                        cowboysdude Module Developer @hellboyhum
                                        @hellboyhum No not stupid…easy mistake to make… we won’t shoot you here LOL
                                        If put MagicMirror in and have questions feel free to ask
                                        H 1 Reply Last reply Reply Quote 1
                                        • Mykle1M
                                          @hellboyhum said in Just installed magic mirror, now how do I change some things?:
                                          I’m so stupid 😒🔫
                                          In that case, stay away from smartmirror. :-)
                                          • H
                                            @cowboysdude Oh, you are so nice here 😂 I will :) thanks! 😳
