    Just installed magic mirror, now how do I change some things?
    28 Posts 12 Posters 46.5k Views 11 Watching
      C13INTZ @KirAsh4
      @KirAsh4 Thank You! It’s exactly how I want it now!
      • KirAsh4K Offline
        KirAsh4 Moderator
        Don’t hesitate to ask more questions if you get stuck.
          Crookedsoul
          I am also very new to the raspberry pi. I see the links but i am having an issue accessing the correct folders to make the needed changes. It may be something simple but I am not seeing it at this time.
          How do you get into the modules to make changes?
          Thanks in advance.
          bheplerB lolobyteL 2 Replies Last reply Reply Quote 0
          • bheplerB Offline
            bhepler Module Developer @Crookedsoul
            @Crookedsoul The modules that come with the Magic Mirror software can be found in ~/MagicMirror/modules/default/[name of module] (assuming you ran through the tutorial and didn’t change anything).
            Any of the modules that you download from the community (Weatherbug, Instagram, Tides, etc.) need to be installed in their own folder in the modules folder. The positioning of any module is handled by the config.js script located at ~/MagicMirror/config/config.js. In addition to location information, you’ll also define most of the module’s configuration there as well. Think of it as configuration parameters that you’re passing into the module code, so you need to specify those parameters while you’re telling the Magic Mirror system to load up the module.
            Pi-GiP 1 Reply Last reply Reply Quote 1
            • Pi-GiP Offline
              Pi-Gi @bhepler
              @bhepler hello everyone.
              I am in the process of making a magic mirror as well. I have downloaded and installed it on my Pi 3. But I am getting a permission denied message when I try to update the current weather with an app ID.
              I have not tried any other modules to update or change at this time.
              Any help will be greatly appreciated.
              Where's my wallet honey…>>>
              • F Offline
                frog
                I’m not totally sure what your issue is, but it may be permissions when editing the config.js file.
                try:
                sudo nano ~/MagicMirror/config/config.js
                make the change and save it with ctrl-o, ctrl–z
                Pi-GiP V 2 Replies Last reply Reply Quote 0
                • lolobyteL Offline
                  lolobyte @Crookedsoul
                  @Crookedsoul
                  for guys without command line experience do following!
                  login to your raspi.
                  execute following command:
                  sudo apt-get install mc
                  That’s the midnight commander SW. Maybe u know the old DOS norton commander, mc is similar like notons commander.
                  U can start mc by typing mc and enter.
                  For root privileges type sudo mc.
                  Now u can brows with your keyboard or mouse between the folder, view or edit config or other files.
                  Good luck
                  Pi-GiP 1 Reply Last reply Reply Quote 0
                  • Pi-GiP Offline
                    Pi-Gi @frog
                    Thank you I forgot to use Nano
                    • Pi-GiP Offline
                      Pi-Gi @lolobyte
                      @lolobyte I will try this as well. Thanks guys just really new to this you’re the best.
                      • V Offline
                        VirtualLeonard @frog
