    690 Posts 77 Posters 3.1m Views 70 Watching
      planet4 @cowboysdude
      @cowboysdude Thanks but it looks the same unfortunatly.
      tbbearT 1 Reply Last reply Reply Quote 0
      • tbbearT Offline
        tbbear Module Developer
        @planet4 Hi, please try to select showWind: true it should fix your problem
        Robert the Bear
        • tbbearT Offline
          tbbear Module Developer @Mykle1
          @Mykle1 oo i see so u are an iphone fan ?
          Robert the Bear
            Mykle1 Project Sponsor Module Developer @tbbear
            @tbbear said in MMM-NOAA - Another Weather Module:
            I’m an iPhone user but I am not a fan of iPhone prices.
            • tbbearT Offline
              @Mykle1 hahah thats true but they are the best, i have a iphone x and its unbelievable
              Robert the Bear
                @tbbear
                I’m still using the 6 but I have no intention of getting the newest version any time soon. I have to buy my grandchildren Christmas presents! :-)
                • tbbearT Offline
                  tbbear Module Developer @planet4
                  @planet4 The problems are fixed. Please load the aktual version.
                  Robert the Bear
                    rezocharly
                    hi ! Thanks for this great plugin !
                    1. There is a way to hide the ALERT block ?
                    2. I use the AirVisual API for the air quality index but it’s look incorrect about when I check the data from my city. There is a way to be more accurate?
                    Thanks a lot
                    • cowboysdudeC Offline
                      cowboysdude Module Developer @rezocharly
                      @rezocharly said in MMM-NOAA - Another Weather Module:
                      Thanks a lot
                      Added a config option
                      add -> alert:false
                      to your config and it will not show alert.
                      I don’t know what you mean by ‘look incorrect’ … it uses the lat and lon of your location BUT you can also add lat: your lat and lon: your lon to the config file… see if that improves it :)
                        rezocharly @cowboysdude
                        thanks a lot @cowboysdude but alert are still displayed with alert: false,
                        And with showWind: true, indications about wind are not diplayed.
                        • Y Offline
                          yawns Moderator @rezocharly
                          @rezocharly
                          Could you please show where you added the config options? Maybe it’s in the wrong place and therefore ignored?
                          • tbbearT Offline
                            @rezocharly … if there is no wind than it will not be displayed so no wind 0 will appear
                            Robert the Bear
                              rezocharly @yawns
                              @yawns
                              Here you can see my config.js file: ( I’ve try first and last line)
                                                  disabled: false,
                                                  module: 'MMM-NOAA',
                                                  position: 'bottom_left',
                                                          alert: false,
                                                          apiKey: "XXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
                                                          useAir: true,             // set to false if you do not want to use Air Quality Index
                                                          airKey: "XXXXXX",    // IF you want Air Quality Index
                                                          pws: "IAMIENS35",         // go here to find your pws: https://www.wunderground.com/wundermap
                                                          showClock: false,         // Hides or shows clock
                                                          dformat: false,            // for M/D/YYYY format, false for D/M/YYYY
                                                          format: "24",             // 12 or 24 hour format.. will default to 12 hour if none selected.
                                                          ampm: true,               // to show AM and PM on Sunrise/Sunset time
                                                          showGreet: false,         // deafult is false - to show greeting under clock and above date
                                                          name: "charly",           // Your name
                                                          showWind: true,
                                                          showDate: false,
                                                          showForecast: true,        //show bottom 3 day forecast
                                                          flash: false,               //Today in forecast flashes halo
                                                          showUV: true,              //show UV index
                                                          showBar: true,             // show Barometer
                                                          showHum: true,             //show Humidity level
                                                          position: 'bottom_left'    //whatever you have in above position must also be here
                                rezocharly @tbbear
                                @tbbear I live in a windy area. Today Force 5/6.
                                As you can see with this screenshot the O doesn’t appear. Even if the config.js is well setup to display this information (as you can see on the post above)
                                Capture_d_e_cran_2017_12_14_a_17_46_39
                                tbbearT cowboysdudeC 2 Replies Last reply Reply Quote 0
                                • tbbearT Offline
                                  tbbear Module Developer @rezocharly
                                  @rezocharly ok, so its another problem.
                                  First the lines “ALERT” and the “Warning Level:” are parts of ur language translation file. So add them their and it will show in the correct language. Here my de.json file from translation dir.
                                  "***ALERT***":"*** Wetterwarnungen ***",
                                  "Warning Level: ":"Warnstufe: ",
                                  Second ur wind problem. This module depends on wunderground which is a network of personal wheaterstations. NOT every person who has a PWS has also a wind sensor. Maybe u try to select another
                                  StationID which has one. (i had the same problem too)
                                  Third with alerts: false i have this in my config.js just before the line position: … and it works.
                                  Robert the Bear
                                    Just add this to your custom css
                                    .MMM-NOAA .set {
                                    float: left;
                                      rezocharly @tbbear
                                      @tbbear
                                      Thanks a lot for this information I got it but unfortunately nobody have a wind sensor around me :)
                                      I confirm, just before the line position, alerts are not displayed anymore.
                                        @rezocharly just disable that in the config like this:
                                        showWind: false
                                        As for the alerts I’m gonna let @tbbear chime in on this one…he rewrote the alerts :)
                                          Peter
                                          This module works perfect … almost …
                                          Is it possible to change CET in alerts to MET ( I use the Dutch translation)?
                                          Peter
                                          • tbbearT Offline
                                            tbbear Module Developer @Peter
                                            @Peter The translation for the alerts depends on google translate, so at the moment we cant change this
                                            Robert the Bear
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 34
                                            • 35
                                            • 12 / 35
