    • tbbearT
      tbbear Module Developer @Mykle1
      @Mykle1 grrrrrrrrrrrrrrrrrrrrrrrrrr here we can go ice skating or building a snow man …
      Robert the Bear
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @tbbear
        @tbbear
        My son on both sides of the pool. The magic of panoramic photos!
        tbbearT 1 Reply Last reply Reply Quote 2
          planet4
          I have some questions regarding this module. In the screenshots I do not se the grey boxes like in the image below. 0 G. I have tried to set everything as false but still.
          Also the font size is smaller on this module compared to all other modules on my MM2. I suppose I can change this in the CSS but it seems to be worong.
          alt text
          • cowboysdudeC
            cowboysdude Module Developer @planet4
            @planet4 Not sure what you have there but that looks all wrong…
              planet4 @cowboysdude
              @cowboysdude
              Thanks for the reply. Just like this.
              		module: 'MMM-NOAA',
              		disabled: false,
              		position: 'top_right',
              			apiKey: "xxxxxxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
              			useAir: false,             // set to false if you do not want to use Air Quality Index
              			airKey: "xxxxxxxxxxxxxxxx",    // IF you want Air Quality Index
              			pws: "IMLNLYCK10",         // go here to find your pws: https://www.wunderground.com/wundermap
              			showClock: false,           // Hides or shows clock
              			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
              			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
              			ampm: false,                // to show AM and PM on Sunrise/Sunset time
              			showGreet: true,          // deafult is false - to show greeting under clock and above date
              			name: "Persson",                  // Your name
              			showWind: false,
              			showDate: false,
              			showForecast: true,         //show bottom 3 day forecast
              			flash: false,                 //Today in forecast flashes halo
              			showUV: false,               //show UV index
              			showBar: false,             // show Barometer
              			showHum: false,              //show Humidity level
              			position: 'top_right'       //whatever you have in above position must also be here
              • cowboysdudeC
                @planet4 said in MMM-NOAA - Another Weather Module:
                disabled: false,
                Delete that line for now…
                Then go a git pull and npm install and see if that helps…changes have been made to fix certain things :)
                  @cowboysdude Thanks but it looks the same unfortunatly.
                  tbbearT 1 Reply Last reply Reply Quote 0
                  • tbbearT
                    @planet4 Hi, please try to select showWind: true it should fix your problem
                    Robert the Bear
                    • tbbearT
                      @Mykle1 oo i see so u are an iphone fan ?
                      Robert the Bear
                      • Mykle1M
                        @tbbear said in MMM-NOAA - Another Weather Module:
                        I’m an iPhone user but I am not a fan of iPhone prices.
                        • tbbearT
                          @Mykle1 hahah thats true but they are the best, i have a iphone x and its unbelievable
                          Robert the Bear
                          • Mykle1M
                            @tbbear
                            I’m still using the 6 but I have no intention of getting the newest version any time soon. I have to buy my grandchildren Christmas presents! :-)
                            • tbbearT
                              tbbear Module Developer @planet4
                              @planet4 The problems are fixed. Please load the aktual version.
                              Robert the Bear
                                rezocharly
                                hi ! Thanks for this great plugin !
                                1. There is a way to hide the ALERT block ?
                                2. I use the AirVisual API for the air quality index but it’s look incorrect about when I check the data from my city. There is a way to be more accurate?
                                Thanks a lot
                                • cowboysdudeC
                                  cowboysdude Module Developer @rezocharly
                                  @rezocharly said in MMM-NOAA - Another Weather Module:
                                  Thanks a lot
                                  Added a config option
                                  add -> alert:false
                                  to your config and it will not show alert.
                                  I don’t know what you mean by ‘look incorrect’ … it uses the lat and lon of your location BUT you can also add lat: your lat and lon: your lon to the config file… see if that improves it :)
                                    rezocharly @cowboysdude
                                    thanks a lot @cowboysdude but alert are still displayed with alert: false,
                                    And with showWind: true, indications about wind are not diplayed.
                                    • Y
                                      yawns Moderator @rezocharly
                                      @rezocharly
                                      Could you please show where you added the config options? Maybe it’s in the wrong place and therefore ignored?
                                      • tbbearT
                                        @rezocharly … if there is no wind than it will not be displayed so no wind 0 will appear
                                        Robert the Bear
                                          rezocharly @yawns
                                          @yawns
                                          Here you can see my config.js file: ( I’ve try first and last line)
                                                              disabled: false,
                                                              module: 'MMM-NOAA',
                                                              position: 'bottom_left',
        alert: false,
        apiKey: "XXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
        useAir: true,             // set to false if you do not want to use Air Quality Index
        airKey: "XXXXXX",    // IF you want Air Quality Index
        pws: "IAMIENS35",         // go here to find your pws: https://www.wunderground.com/wundermap
        ampm: true,               // to show AM and PM on Sunrise/Sunset time
        showGreet: false,         // deafult is false - to show greeting under clock and above date
        name: "charly",           // Your name
        showWind: true,
        showDate: false,
        showUV: true,              //show UV index
        showBar: true,             // show Barometer
        showHum: true,             //show Humidity level
        position: 'bottom_left'    //whatever you have in above position must also be here
                                            rezocharly @tbbear
                                            @tbbear I live in a windy area. Today Force 5/6.
                                            As you can see with this screenshot the O doesn’t appear. Even if the config.js is well setup to display this information (as you can see on the post above)
                                            Capture_d_e_cran_2017_12_14_a_17_46_39
                                            tbbearT cowboysdudeC 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 34
                                            • 35
                                            • 12 / 35
