    • Mykle1M
      Mykle1 Project Sponsor Module Developer @tbbear
      @tbbear said in MMM-NOAA - Another Weather Module:
      oo i see so u are an iphone fan ?
      I’m an iPhone user but I am not a fan of iPhone prices.
      tbbearT 1 Reply Last reply Reply Quote 0
      • tbbearT
        tbbear Module Developer @Mykle1
        @Mykle1 hahah thats true but they are the best, i have a iphone x and its unbelievable
        Robert the Bear
        • Mykle1M
          @tbbear
          I’m still using the 6 but I have no intention of getting the newest version any time soon. I have to buy my grandchildren Christmas presents! :-)
          • tbbearT
            tbbear Module Developer @planet4
            @planet4 The problems are fixed. Please load the aktual version.
            Robert the Bear
              rezocharly
              hi ! Thanks for this great plugin !
              1. There is a way to hide the ALERT block ?
              2. I use the AirVisual API for the air quality index but it’s look incorrect about when I check the data from my city. There is a way to be more accurate?
              Thanks a lot
              • cowboysdudeC
                cowboysdude Module Developer @rezocharly
                @rezocharly said in MMM-NOAA - Another Weather Module:
                Thanks a lot
                Added a config option
                add -> alert:false
                to your config and it will not show alert.
                I don’t know what you mean by ‘look incorrect’ … it uses the lat and lon of your location BUT you can also add lat: your lat and lon: your lon to the config file… see if that improves it :)
                  rezocharly @cowboysdude
                  thanks a lot @cowboysdude but alert are still displayed with alert: false,
                  And with showWind: true, indications about wind are not diplayed.
                  • Y
                    yawns Moderator @rezocharly
                    @rezocharly
                    Could you please show where you added the config options? Maybe it’s in the wrong place and therefore ignored?
                    • tbbearT
                      @rezocharly … if there is no wind than it will not be displayed so no wind 0 will appear
                      Robert the Bear
                        rezocharly @yawns
                        @yawns
                        Here you can see my config.js file: ( I’ve try first and last line)
                                            disabled: false,
                                            module: 'MMM-NOAA',
                                            position: 'bottom_left',
                                                    alert: false,
                                                    apiKey: "XXXXXX",    // https://www.wunderground.com/weather/api  select the middle plan...
                                                    useAir: true,             // set to false if you do not want to use Air Quality Index
                                                    airKey: "XXXXXX",    // IF you want Air Quality Index
                                                    pws: "IAMIENS35",         // go here to find your pws: https://www.wunderground.com/wundermap
                                                    showClock: false,         // Hides or shows clock
                                                    dformat: false,            // for M/D/YYYY format, false for D/M/YYYY
                                                    format: "24",             // 12 or 24 hour format.. will default to 12 hour if none selected.
                                                    ampm: true,               // to show AM and PM on Sunrise/Sunset time
                                                    showGreet: false,         // deafult is false - to show greeting under clock and above date
                                                    name: "charly",           // Your name
                                                    showWind: true,
                                                    showDate: false,
                                                    showForecast: true,        //show bottom 3 day forecast
                                                    flash: false,               //Today in forecast flashes halo
                                                    showUV: true,              //show UV index
                                                    showBar: true,             // show Barometer
                                                    showHum: true,             //show Humidity level
                                                    position: 'bottom_left'    //whatever you have in above position must also be here
                          rezocharly @tbbear
                          @tbbear I live in a windy area. Today Force 5/6.
                          As you can see with this screenshot the O doesn’t appear. Even if the config.js is well setup to display this information (as you can see on the post above)
                          Capture_d_e_cran_2017_12_14_a_17_46_39
                          tbbearT cowboysdudeC 2 Replies Last reply Reply Quote 0
                          • tbbearT
                            tbbear Module Developer @rezocharly
                            @rezocharly ok, so its another problem.
                            First the lines “ALERT” and the “Warning Level:” are parts of ur language translation file. So add them their and it will show in the correct language. Here my de.json file from translation dir.
                            "***ALERT***":"*** Wetterwarnungen ***",
                            "Warning Level: ":"Warnstufe: ",
                            Second ur wind problem. This module depends on wunderground which is a network of personal wheaterstations. NOT every person who has a PWS has also a wind sensor. Maybe u try to select another
                            StationID which has one. (i had the same problem too)
                            Third with alerts: false i have this in my config.js just before the line position: … and it works.
                            Robert the Bear
                            • cowboysdudeC
                              Just add this to your custom css
                              .MMM-NOAA .set {
                              float: left;
                                rezocharly @tbbear
                                @tbbear
                                Thanks a lot for this information I got it but unfortunately nobody have a wind sensor around me :)
                                I confirm, just before the line position, alerts are not displayed anymore.
                                • cowboysdudeC
                                  @rezocharly just disable that in the config like this:
                                  showWind: false
                                  As for the alerts I’m gonna let @tbbear chime in on this one…he rewrote the alerts :)
                                    Peter
                                    This module works perfect … almost …
                                    Is it possible to change CET in alerts to MET ( I use the Dutch translation)?
                                    Peter
                                    • tbbearT
                                      tbbear Module Developer @Peter
                                      @Peter The translation for the alerts depends on google translate, so at the moment we cant change this
                                      Robert the Bear
                                        Peter @tbbear
                                        @tbbear thanks!
                                        Peter
                                          mac0178
                                          Nice Module, really love it.
                                          Unfortunately i have a problem with another module (mmm-traffic) while NOAA is active. The font there should be colored but now it´s background is completely colored. While NOAA is disabled, everything is fine.
                                          Any clue?
                                          thx,
                                          Mac
                                          • cowboysdudeC
                                            cowboysdude Module Developer @mac0178
                                            @mac0178 Let me take a look perhaps a css tag is similar :) Ahhhhhh yes perhaps this is it…
                                            In the NOAA css file there is this:
                                            .red{
                                            	background:#f00;
                                            .green{
                                            	background:#0f0;
                                            .blue{
                                            	background:#00f;
                                            and in the MMM-Traffic module there is this:
                                            .green {
                                              color: #83FFB3;
                                            .yellow {
                                              color: yellow;
                                            .red {
                                              color: #FF4C4C;
                                            So I’m going to update the css file and you can try it again :)
                                            Just go to the MagicMirror/modules/MMM-NOAA dir and type
                                            git pull
                                            that should update the css file :)
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 34
                                            • 35
                                            • 12 / 35
