    Hello-Lucy
    Scheduled Pinned Locked Moved Fun & Games
    285 Posts 27 Posters 740.4k Views 27 Watching
      Damian @Mykle1
      @Mykle1
      Thanks I will just try and find a similar 3.5 Mic to your tried and tested one, here on Amazon uk. At least I know that will work since you have it working well :-)
        Mykle1 Project Sponsor Module Developer @Damian
        @Damian
        Well, why don’t you try the mic that you have? You may be satisfied with the result. If not, you can always pick up the other. I didn’t do any shopping. I simply chose an inexpensive mic that employs a 3.5mm jack instead of USB. In any case, let me know your results
        D 1 Reply Last reply Reply Quote 2
          Damian @Mykle1
          @Mykle1
          I bought a micro USB one last year when I tried to put alexa on the Pi, and when testing at about 1 foot away, I sounded as if I were 10 feet away with cotton wool in my mouth. Also had problems of latency using Alexa, so I abandoned both, having spent way too much time trying just about every combination of settings I read up to try, and ask about.
          I always read reviews on the likes of Amazon, and have read of a few that really only work great when really close up to the Mic, and so far I have not came across any review that has mentioned a Mic that has worked from a decent distance, seeing as Mic’s are usually always used up close.
          The PS3 Eye was the only one where I seen a reviewer state that he used his from about 3M away and was heard perfectly on Skype, but alas, not from a Pi, and not using it for voice control.
          As you have noted, the USB mic works perfect for normal usage, and it only becomes a problem when using Lucy… Like my previous problem when using Alexa, so therein may be the problem? I was about to add the limitations of the Pi as an additional factor, but you also noted the same problem on your powerfull i7, so I am of the opinion that USB mic’s for Voice control are not a good combination? for whatever techy reason that I know nothing about.
          The only sure way of sourcing a suitable Mic, for the purpose of long range use, is to read from someone that is actually using one that has worked from a decent distance, on the same project - Lucy.
          @pepebc offered up the PS3 Eye, which sounds and looks great, and works for him, but he is not using it for Lucy, so there is no telling if it will work or not, with Lucy :-(
          You may have been very lucky in your random choice of 3.5 Mic, as if you chose another, it may have only worked at very close quarters? but seeing as your one actualy works at a decent distance with Lucy, then that is worth a hundred reviews, imho ;-) as I would be hard pushed to find a reviewer on Amazon that is reviewing a Mic for the purposes of using Lucy from a decent distance away, from a MM. ;-)
          I will find a UK supplier of the same one you have used, as that has proven to work within a decent range, that users of MM/Lucy would want.
          I will see if I can remove the long stem from the Mic though, to make it easier to hide from sight.
          Thanks again.
            @Damian
            Ok, good luck and keep me posted
            • cowboysdudeC Offline
              Latest tests…
              https://www.youtube.com/watch?v=UEiENwkSZSU&ab_channel=MaintenanceConcepts
              cruunnerrC P 2 Replies Last reply Reply Quote 3
              • cruunnerrC Offline
                cruunnerr @cowboysdude
                @cowboysdude
                U need a touch screen, bro ^^
                It’s running like hell ^^Very nice
                • Y Offline
                  yawns Moderator
                  System performance is awesome, not comparable to the pi at all.
                  After show modules the screen is crowded. Is this an error as it is not looking like in the beginning of your video? Or did you hide some modules before starting your video?
                  Touch hardware is not yet implemented, is it? Would love to see this in action regarding latency and reliability :)
                  Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                    maxbachmann
                    What is The Computer Setup You use?
                    And yes seems like it Shows Modules from other Pages than Page one Aswell white The command Show Modules
                    Although I am Not sure wether that isn’t intended As there Is The command Show Page 1 Aswell
                      pepebc @cowboysdude
                      @cowboysdude
                      OK, great work !!
                        Mykle1 Project Sponsor Module Developer @yawns
                        @yawns said in Hello-Lucy:
                        Exactly.
                        SHOW MODULES by default will show ALL modules. So, if you have several pages employed it can get busy real fast. Still, it was intentional to have the ability to hide/show all modules, individual modules and pages of modules.
                        @cowboysdude has done an excellent job of implementing Hello-Lucy
                        Y M 2 Replies Last reply Reply Quote 1
                        • Y Offline
                          yawns Moderator @Mykle1
                          @Mykle1 said in Hello-Lucy:
                          I see, thanks for clarification Mykle!
                            maxbachmann @Mykle1
                            Exactly.
                            Ah thats what I Thought :)
                              cowboysdude Module Developer @cruunnerr
                              @cruunnerr said in Hello-Lucy:
                              @cowboysdude
                              It is a touch screen already ;)
                                cowboysdude Module Developer @yawns
                                NO that’s just what happens because when you blanket show modules it shows all pages at once. That’s not a bug it’s just how it works :)
                                • NathanWilcoxN Offline
                                  NathanWilcox
                                  @Mykle1
                                  Great module have been using for some time while developing the mirror.
                                  I apologise if you have covered this else where but I simply cannot find it, Is there a way to automatically show modules on MagicMirror start as appose to them being hidden and only shown when prompted.
                                    Mykle1 Project Sponsor Module Developer @NathanWilcox
                                    @NathanWilcox said in Hello-Lucy:
                                    If you’re not gun shy about modifying the files yourself, you can find this in the MMM-voice.js file and comment it out. You’ll find it at about line 277. I assume you know that every module you have loading will be displayed. :-)
                                         if (notification === 'DOM_OBJECTS_CREATED') {
                                             MM.getModules().enumerate((module) => {
                                                    module.hide(1000);
                                      NathanWilcox
                                      @Mykle1
                                      That’s exactly what I was looking for. Yes I did realise it would show all.
                                      I’m trying to demonstrate to the other half the different ways we can have the mirror and she wasn’t too enthusiastic with booting a “blank screen”
                                        @NathanWilcox
                                        Sound of whip snapping
                                          maxbachmann
                                          Will give Snips a try when I get my microphone array. Seems like the just released ther German automated speech recognition a few days ago
                                          Seems pretty easy in general (I guess the hardest thing will be talking to the modules since snips uses python and here it’s java script while I am usually only using c++ lmao)
                                          Edit: Just realised there is already a mqtt module for MagicMirror2 that should make it quite a bit easier
                                            djsunrise19
                                            @mykle1: Very nice module! Works really good, and it’s easy to add more and more modules. unfortunately, with one of them, I have a problem: https://github.com/eouia/MMM-CalendarExt.
                                            I found the wrapper part, but it doesn’t work. The other modules are still working. Do you have an idea?
                                              getDom: function() {
                                                if (this.isInit) {
                                                  R = new Render ()
                                                  R.drawViews(
                                                    this.CurrentConfigs,
                                                    this.getEventsToDraw()
                                                var wrapper = null
                                                wrapper = document.createElement("div")
                                                wrapper.id = 'CALEXT_proxy'
                                                wrapper.className = 'proxy'
                                                return wrapper
                                                notificationReceived: function(notification, payload) {
                                                    if (notification === 'HIDE_WORK') {
                                                        this.hide(1000);
                                                    }  else if (notification === 'SHOW_WORK') {
                                                        this.show(1000);
                                            Thank you!
                                            • 14
                                            • 15
                                            • 3 / 15
