    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.0k Views 59 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Wominator
      @Wominator said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      That would be a great improvement.
      Well, I never did, but you can try this. I can’t test at the moment, but it should work. Save this as a .bat file and put it on your desktop.
      :: This should work if this bat file is on the desktop
      :: Also, CMD window needs ability to run bash commands (done during install of GIT)
      :: Start CMD window
      start cmd.exe /k
      :: cd back one directory
      cd ..
      :: cd to MM directory
      cd MagicMirror
      :: start MM
      npm start
      WominatorW 1 Reply Last reply Reply Quote 0
      • WominatorW
        Wominator @Mykle1
        @Mykle1
        Hi!
        Thanks for the quick reply!
        It didn’t work out that way. I found a documentation on:
        https://stackoverflow.com/questions/21564275/windows-shortcut-to-run-git-bash-script
        So, I generated a script C:\Users\USER\npmstart.sh with
        cd ..
        npm start
        Afterwards I generated a shortcut on the desktop with following path:
        "C:\Program Files\Git\bin\sh.exe" -l -i "C:\Users\USER\npmstart.sh"
        And it works. It starts the Bash and runs MagicMirror and leaves the Bash open in the background, so I can get back to it by pressing the Windows-Button. (remember, I run the MagicMirror on a tablet without keyboard and mouse)
        In the Bash, I can stop MagicMirror with the onscreen keyboard by pressing Ctrl+C.
        Regards
        womi
        If you want to make it idiot proof, someone will build a better idiot.
        • Mykle1M
          @Wominator
          Well done!
          • H
            Henrik @Mykle1
            @Mykle1 Fantastic, thanks!
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Henrik
              @Henrik
              You’re welcome, mate! Enjoy your mirror. :-)
              Peace!
              • H
                Henrik @Mykle1
                @Mykle1 I fully am. :) Now the time has come to develop my first module.
                  djsunrise19
                  I switched from raspberry to a mini-itx windows10 system, too. With my raspy system I had way too much performance issues. Thanks for your walkthrough, it works really well. But, modules like MMM-voice or Hello Lucy won’t work, am I right? That would be too bad :/.
                  • H
                    Henrik @djsunrise19
                    @djsunrise19 Maybe a bit late, but are you sure the performance issues were not caused by the incompatible Electron version? That seems to have been fixed in the latest MM (by downgrading Electron).
                    Anyway, MMM-voice should work, but it’ll probably be a lot of hassle to get it going!
                      djsunrise19 @Henrik
                      @Henrik No, I tried a lot of electron versions, a lot of raspberries, ATB, odroids. I created that electron topic :-D. I like it smooth, none of them was. All in all I have to say, that electron seems to be the problem. The renderer / the performance is too bad. Within chrome only, the website runs super smooth. With electron its a huge difference. Even under windows (8GB RAM, G4600 CPU), electron doesn’t perform like chrome does. But it’s okay, and expensive, :-D. MagicMirror V1 was a website only. Way better than V2 with the electron framework (only the performance aspect).
                      Perhaps @Mykle1 has an idea for MMM-voice under windows?
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @djsunrise19
                        @djsunrise19 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                        The problem with MMM-voice under windows is dependencies. The installer script will not work under Windows, only Raspbian or linux. So, unless you can install the dependencies independent of the installer, you’re out of luck. I don’t even know if the dependencies are available for Windows. I never really tried to find out. Let me know if you do.
                        Now that you are running on a mini-itx board, you do have some options. You could make it a dual boot machine, which is fairly simple. One side Windows, one side ubuntu. Then you can run MMM-voice with Hello-Lucy like a champion.
                          djsunrise19 @Mykle1
                          @Mykle1 Thank you! First I installed ubuntu (and ubuntu mate) on that system. But there were some graphic-issues (f.e. marquee-fx in display-rotate mode looks very awful) and my microphone doesn’t work. I checked 4 or 5 of them. I thought, MMM-voice works with windows as well.
                          After that I decided to go with windows. It works pretty well. More performant than ubuntu. There is only one problem: Each 10min (or something like that) there are very much git processes within the electron process (cpu usage is 70% for a few seconds, windows antivirus checks something too; MM2 lags a little bit). Don’t know why. Do you have the same with your windows environment?
                          • Mykle1M
                            @djsunrise19
                            I am no longer running MM on Windows. It doesn’t make sense to me. I’ve become a huge fan of ubuntu. I would recommend finding the version that works best for you. It takes a little time but it’s worth it. For me, ubuntu 16.04 is rock solid and works on every machine I’ve installed it on. I had some trouble with earlier and later versions.
                            IMHO, for MM, ubuntu is the way to go. You might have some trouble initially but once you find the right combination you’ll be happy with it. And hey, I think you can rotate the screen from inside ubuntu preferences. I have 2 microphones. One usb and one 3.5mm jack version. Both work with no issue under ubuntu. Even the laptops I use with ubuntu have no issue with the integrated microphones.
                              djsunrise19 @Mykle1
                              @Mykle1 I tested two Mainboards, because ubuntu doesn’t recognize the realtek chips. Also I rotated the screen within the ubuntu options. But, thanks for your input. Who knows, if I’ll switch again ;).
                              • Mykle1M
                                I did not know that. Are you choosing "install 3rd party drivers during installation? This is what I do know. I’ve installed ubuntu 16.04 on a 32 bit MacBook (2006), a Compaq Presario CQ57 laptop, a Dell 1505 laptop, an HP Pavilion a6130n desktop and an HPE i7 Quad core desktop. All are problem free. All are running MMM-voice and Hello-Lucy. All drivers were installed automatically with ubuntu. All microphones work, all sound out works, all bluetooth works. I didn’t do anything special. I just installed and it works.
                                I’ll ask my friend who is running an mini itx board if he has any insight on this. He is running ubuntu and Hello-Lucy without a hitch.
                                  djsunrise19 @Mykle1
                                  @Mykle1 A good point. I didn’t choose that 3rd party option. Perhaps there are some better graphic drivers, too. I think I’ll create a windows backup and give ubuntu a 3rd chance :-D. Using ubuntu mate shouldn’t be a problem? I like that interface a little bit more. If it doesn’t work again, I’ll make the windows recovery and try to tweak that.
                                  Another option for voice would be an alexa skill an module. So I can use alexa for the input trigger.
                                  • Mykle1M
                                    Personally, I wouldn’t care which version name or number, as long as it’s stable and MM resides there happily.
                                    Cool. Keep me posted.
                                    • lavolp3L
                                      lavolp3 Module Developer
                                      Thanks Mykle1 for this great tutorial. You are the man!
                                      Working great on Win 10 Pro 64 bit
                                      How to troubleshoot modules
                                      MMM-soccer v2, MMM-AVStock
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @lavolp3
                                        @lavolp3 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                        That’s good news! Enjoy your mirror. :-)
                                        • L
                                          lancerkid38
                                          @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                          walkthrough
                                          I’m a Windows 10 user & your MagicMirror Walkthrough was wonderful. Worked perfectly the first run. I have been on youtube for a month or so watching other with work with MM. I would like to expand on whats was given but this is a great start.
                                          Thanks for sharing your walkthrough. Incredibly easy to follow!
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @lancerkid38
                                            @lancerkid38
                                            You’re quite welcome, my friend. :-)
                                            • 16
                                            • 17
                                            • 2 / 17
