    690 Posts 77 Posters 3.0m Views 70 Watching
      Vielleicht gibt es hier eine Antwort, aber ich würde es nie erfahren, wenn ich nicht Deutsch spreche. :-)
        anubis273 @Mykle1
        @Mykle1 Jup damit hast du vollkommen Recht. Von mir aus und gerne für alle ab jetzt:
        We switch to english language again ;-)
        Cheers
        Mykle1M tbbearT 2 Replies Last reply Reply Quote 1
          Mykle1 Project Sponsor Module Developer @anubis273
          @anubis273
          My point is this. Anyone that doesn’t speak German (me) can’t help if you are speaking German
          • tbbearT Offline
            tbbear Module Developer @anubis273
            @anubis273 I am sorry i forgot to mention that after u clone from my repository u have to rename the directory from NOAA2 to NOAA this will fix all ur problems
            Robert the Bear
            A Mykle1M 2 Replies Last reply Reply Quote 0
              anubis273 @tbbear
              @tbbear hey, oh I forget to Tell you that I tried this of course :-) I renamed the folder to MMM-NOAA2. The result was the same, a black screen on top right.
              But you‘re right, this is the solution in normal case but unfortunately not for me.
              Cheers,
              Bernd
                Mykle1 Project Sponsor Module Developer @tbbear
                @tbbear said in MMM-NOAA - Another Weather Module:
                You’re maintaining NOAA now?
                tbbearT 1 Reply Last reply Reply Quote 0
                • cowboysdudeC Offline
                  No… any cloning or git pull should ONLY be done from MMM-NOAA master …
                  • tbbearT Offline
                    tbbear Module Developer @Mykle1
                    @Mykle1 of course not, but i changed a few things and it looks like the people like it but its def. John s modules
                    Robert the Bear
                      That should be done via pull request to the main repository… ;)
                      Well because what’s going to end up happening is there will be different versions and that will just confuse the issues.
                      • DesaydroneD Offline
                        Desaydrone @tbbear
                        @tbbear Thanks a lot , i can be patient :D
                        • G Offline
                          gashion
                          First of all, Thank you for this great module.
                          After the latest MM update, this module stopped working correctly for him. Does someone know how i can fix this problem.
                          Here is a picture :
                          alt text
                          Here is my config;
                              		disabled: false,
                              		module: 'MMM-NOAA',
                              		position: 'top_right',
                          			apiKey: "83c61585aabeb89c",    // https://www.wunderground.com/weather/api  select the 			middle plan...
                          			useAir: true,             // set to false if you do not want to use Air Quality Index
                          			airKey: "x7hcisbyAjENpBy4f",    // IF you want Air Quality Index
                          			pws: "IKIVIKKO4",         // go here to find your pws: https://www.wunderground.com/wundermap
                          			showClock: true,           // Hides or shows clock
                          			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
                          			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
                          			ampm: true,                // to show AM and PM on Sunrise/Sunset time
                          			showGreet: false,          // deafult is false - to show greeting under clock and above date
                          			name: "Moe",                  // Your name
                          			showWind: false,
                          			showDate: false,
                          			showForecast: true,         //show bottom 3 day forecast
                          			flash: true,                 //Today in forecast flashes halo
                          			showUV: true,               //show UV index
                                 		showBar: true,             // show Barometer
                                  	showHum: true,              //show Humidity level
                          			position: 'top_right',       //whatever you have in above position must also be here
                                  	alert: true,                //show weather alerts default is true
                          			days: "3"                   //default in config is 3 can be either "3" or "10" for forecast
                          • tbbearT Offline
                            tbbear Module Developer @gashion
                            @gashion Hi, looks like u are using the v2 so u need to change ur config. U need only a few lines now:
                            apiKey
                            airKey
                            and rename pws to pws1
                            Please remove the rest
                            Robert the Bear
                            • G Offline
                              gashion
                              @tbbear
                              Hi, thanks for ur reply.
                              I tried what u said and still the same. Nothing changed.
                              New config settings:
                                  		disabled: false,
                                  		module: 'MMM-NOAA',
                              • tbbearT Offline
                                @gashion Good but u forgot one thing Rename pws to pws1!!!
                                Robert the Bear
                                • Y Offline
                                  yomm
                                  First of all, thanks for your work.
                                  I did have the same issue that @gashion had. I read your comment, it fix it !
                                  But… to be honnest I really prefer the v1 look and feel. So is there a way to revert change and stay back in the v1 version ?
                                  • G Offline
                                    gashion
                                    @tbbear
                                    How stupid of me. I replaced it and it works now. Thank you! :)
                                      stevegoble @tbbear
                                      @tbbear
                                      I had the same issue. The change to config.js did fix it but now the temp is showing in Celsius. My locals are:
                                              language: "en",
                                              timeFormat: 24,
                                              units: "imperial",
                                      any idea?
                                      Thanks!
                                      • tbbearT Offline
                                        tbbear Module Developer @stevegoble
                                        @stevegoble hi, this units option does only work for the default weather module. In NOAA its the value of the time format so 24 hours is european so Celsius, 12 hours is USA so Fahrenheit. Where are u living?
                                        Robert the Bear
                                          stevegoble @tbbear
                                          @tbbear
                                          Thank you for the quick response. I am in Atlanta, GA USA. I prefer 24 hour clock so…sigh.
                                          tbbearT 2 Replies Last reply Reply Quote 0
                                          • tbbearT Offline
                                            @stevegoble if u have a few minutes i can fix it for u cause i just saw that v1 used units
                                            Robert the Bear
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 34
                                            • 35
                                            • 16 / 35
