    690 Posts 77 Posters 3.3m Views 70 Watching
    • cowboysdudeC
      cowboysdude Module Developer @Peter
      @Peter said in MMM-NOAA - Another Weather Module:
      Where can I find NOAA 2?
      Peter
      I just finished all the translation files today :) So people will have to let me know if they are correct LOL
      All updated and it’s located here:
      http://173.56.209.189:443/topic/9/mmm-noaa2/5
      • A
        anubis273 @tbbear
        @tbbear Hey, thumps up for helping to develope this great module to the german language !!!
        the reason why I write here are two problems:
        1.) My Mirror shows me the English translation instead of the german one. My config.js is set to: language: “de”, I thought the module will pull the german translation file, but everything is in english for now. Do you have any suggestions what´s wrong? if you want, i can post the snippet out of my config.js
        2.) The measures are still in Fahrenheit. For me as a german user it would be fine to display the units in Celsius as it is the case on your mirror :-) Maybe when I solve the 1.) problem, the units switch?
        I would be very happy to receive your feedback, cheers from Bonn Germany,
        Bernd
        A 1 Reply Last reply
        • A
          anubis273 @anubis273
          @anubis273 For better analysis here are snippets from my config.js an a screenshot what my mirror is currently show:
          snip
          language: “de”,
          timeFormat: 24,
          units: “metric”,
          snip
          snip
          disabled: false,
          module: ‘MMM-NOAA’,
          position: ‘top_right’,
          apiKey: “81944d2065866c80”,
          airKey: “your key”,
          pws: “INORDRHE796”
          snip
          Cheers,
          Bernd
          tbbearT 1 Reply Last reply
          • tbbearT
            tbbear Module Developer @anubis273
            @anubis273 Hallo du hast alles richtig gemacht nur die falsche Version in meinem github findest du die richtige tbbear/NOAA2
            Robert the Bear
            A tbbearT 2 Replies Last reply
            • A
              anubis273 @tbbear
              @tbbear Hey, super vielen Dank für die schnelle Antwort, ich suche mir hier schon die ganze Zeit nen Wolf was ich falsch gemacht haben könnte ^^
              Ich werde mir dann gleich mal deine richtige Version ziehen ;-)
              Besten Dank nochmals und Cheers,
              Bernd
              • tbbearT
                tbbear Module Developer @tbbear
                Bitte aber die Read.me beachten diese Version kann das Wetter von 3 versch. Pws anzeigen Umschalten durch Mausklick oder Touch auf den Ortsnamen
                Robert the Bear
                • A
                  anubis273 @tbbear
                  @tbbear Hey, war jetzt familienbedingt ein paar Stunden abwesend.
                  Weshalb ich doch noch mal stören muss… Habe mir aus deinem GitHub Repository das Modul gezogen und bin nach der Readme vorgegangen. Meine config.js habe ich belassen, wenn ich mehrere Orte definiere, kommt es zu einem config.js Fehler. Mein eigentliches Problem ist nun, dass das Wetter Modul nun nicht mehr angezeigt wird. Es bleibt an der Stelle schwarz, als wenn ich einfach kein Modul für die Stelle platziert hätte.
                  Meine config.js schaut wie gehabt so aus:
                  snip
                  disabled: false,
                  module: ‘MMM-NOAA’,
                  airKey: “your key”,
                  pws: “INORDRHE796”
                  snip
                  Habe jetzt schon selbst wieder ne Weile gesucht woran es liegen könnte, habe aber weder Syntax noch andere Fehler finden können. Im Vorfeld hatte ich das alte NOAA Modul zunächst gelöscht bevor ich deines installiert hatte. Hast du da noch ne Idee weshalb das Bild schwarz bleibt?
                  Cheers,
                  Bernd
                  • DesaydroneD
                    Desaydrone
                    Hi !
                    This new version is so cool, may i ask for a feature ?
                    Do you think it’s possible to add weather running info to this plugin ?
                    Like this https://weather.com/fr-FR/forecast/gorun/l/FRXX0079:1:FR
                    hour by hour ? :D
                    • tbbearT
                      @anubis273 hallo Bernd, denkst du daran das du in der config für jeden Ort eine
                      pws1 und dazu die loco1 brauchst die pws ohne zahl kannst du weglassen
                      Robert the Bear
                      • tbbearT
                        tbbear Module Developer @Desaydrone
                        @Desaydrone ok i will have a look for this Feature gimmi a little time
                        Robert the Bear
                        DesaydroneD 1 Reply Last reply
                        • A
                          anubis273 @tbbear
                          @tbbear Hey, das war mir nicht ganz klar, dass ich zwingend zur pws1 auch eine loco1 benötige…
                          Der loco1 Name ist aber nicht ein exklusiver Name wie der pws Name den ich irgendwo abgreifen muss, oder? Ich habe da einfach mal Bonn-Beuel reingeschrieben:
                          disabled: false,
                          module: ‘MMM-NOAA’,
                          airKey: “YhBwYaaAyfqArCdHZ”,
                          pws1: “INORDRHE796”,
                          loco1: “Bonn-Beuel/De”,
                          Geändert hat das aber leider nichts. Seitdem ich auf deinen GitHub Zweig gewechselt bin, mag das Modul nicht mehr starten. Auch eine neu Installation hat keine Abhilfe geschaffen. Das einzige was mir aufgefallen ist, ist das hier:
                          Ob das aber kriegsentscheident ist, kann ich mir nicht vorstellen.
                          Ich bin jedenfalls kurz davor, aufzugeben. Ich habe wirklich keine Ahnung weshalb das Wetter Modul nicht mehr startet. Alle anderen Modul funktionieren nach wie vor.
                          Cheers,
                          Bernd
                          • tbbearT
                            @anubis273 Tut mir echt leid. das ist meine config und die geht super:
                            module: “MMM-NOAA”,
                            position: “top_right”,
                            config:
                            apiKey: “xxxxxxx”,
                            airKey: “xxxxx”,
                            pws1: “IBAYERNE30”,
                            pws2: “KNYELMIR13”,
                            pws3: “IHERAKLI5”,
                            loco1: “Erdweg/De”,
                            loco2: “New York/Us”,
                            loco3: “Kos/Gr”,
                            ampm: false,
                            Robert the Bear
                            • A
                              anubis273 @tbbear
                              @tbbear Hey, alles gut, bin jetzt wieder zurück auf den ursprünglichen also das erste Wetter Modul. Das läuft nun auch in deutsch obwohl ich nichts weiter verändert hab.
                              Somit hat sich die Problematik erst mal erledigt.
                              Ich danke dir aber dennoch und hoffe demnächst wenn es um NOAA3 geht, wieder von dir zu hören :-)
                              Cheers,
                              Bernd
                              • Mykle1M
                                Vielleicht gibt es hier eine Antwort, aber ich würde es nie erfahren, wenn ich nicht Deutsch spreche. :-)
                                • A
                                  anubis273 @Mykle1
                                  @Mykle1 Jup damit hast du vollkommen Recht. Von mir aus und gerne für alle ab jetzt:
                                  We switch to english language again ;-)
                                  Cheers
                                  Mykle1M tbbearT 2 Replies Last reply
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @anubis273
                                    @anubis273
                                    My point is this. Anyone that doesn’t speak German (me) can’t help if you are speaking German
                                    • tbbearT
                                      @anubis273 I am sorry i forgot to mention that after u clone from my repository u have to rename the directory from NOAA2 to NOAA this will fix all ur problems
                                      Robert the Bear
                                      A Mykle1M 2 Replies Last reply
                                      • A
                                        anubis273 @tbbear
                                        @tbbear hey, oh I forget to Tell you that I tried this of course :-) I renamed the folder to MMM-NOAA2. The result was the same, a black screen on top right.
                                        But you‘re right, this is the solution in normal case but unfortunately not for me.
                                        Cheers,
                                        Bernd
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @tbbear
                                          @tbbear said in MMM-NOAA - Another Weather Module:
                                          You’re maintaining NOAA now?
                                          • cowboysdudeC
                                            No… any cloning or git pull should ONLY be done from MMM-NOAA master …
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 34
                                            • 35
                                            • 16 / 35
