    • A
      anubis273 @tbbear
      @tbbear hey, oh I forget to Tell you that I tried this of course :-) I renamed the folder to MMM-NOAA2. The result was the same, a black screen on top right.
      But you‘re right, this is the solution in normal case but unfortunately not for me.
      Cheers,
      Bernd
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @tbbear
        @tbbear said in MMM-NOAA - Another Weather Module:
        after u clone from my repository
        You’re maintaining NOAA now?
        tbbearT 1 Reply Last reply Reply Quote 0
        • cowboysdudeC
          No… any cloning or git pull should ONLY be done from MMM-NOAA master …
          • tbbearT
            tbbear Module Developer @Mykle1
            @Mykle1 of course not, but i changed a few things and it looks like the people like it but its def. John s modules
            Robert the Bear
            • cowboysdudeC
              That should be done via pull request to the main repository… ;)
              Well because what’s going to end up happening is there will be different versions and that will just confuse the issues.
              • DesaydroneD
                Desaydrone @tbbear
                @tbbear Thanks a lot , i can be patient :D
                • G
                  gashion
                  First of all, Thank you for this great module.
                  After the latest MM update, this module stopped working correctly for him. Does someone know how i can fix this problem.
                  Here is a picture :
                  alt text
                  Here is my config;
                      		disabled: false,
                      		module: 'MMM-NOAA',
                      		position: 'top_right',
                  			apiKey: "83c61585aabeb89c",    // https://www.wunderground.com/weather/api  select the 			middle plan...
                  			useAir: true,             // set to false if you do not want to use Air Quality Index
                  			airKey: "x7hcisbyAjENpBy4f",    // IF you want Air Quality Index
                  			pws: "IKIVIKKO4",         // go here to find your pws: https://www.wunderground.com/wundermap
                  			showClock: true,           // Hides or shows clock
                  			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
                  			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
                  			ampm: true,                // to show AM and PM on Sunrise/Sunset time
                  			showGreet: false,          // deafult is false - to show greeting under clock and above date
                  			name: "Moe",                  // Your name
                  			showWind: false,
                  			showDate: false,
                  			showForecast: true,         //show bottom 3 day forecast
                  			flash: true,                 //Today in forecast flashes halo
                  			showUV: true,               //show UV index
                         		showBar: true,             // show Barometer
                          	showHum: true,              //show Humidity level
                  			position: 'top_right',       //whatever you have in above position must also be here
                          	alert: true,                //show weather alerts default is true
                  			days: "3"                   //default in config is 3 can be either "3" or "10" for forecast
                  • tbbearT
                    tbbear Module Developer @gashion
                    @gashion Hi, looks like u are using the v2 so u need to change ur config. U need only a few lines now:
                    apiKey
                    airKey
                    and rename pws to pws1
                    Please remove the rest
                    Robert the Bear
                    • G
                      gashion
                      @tbbear
                      Hi, thanks for ur reply.
                      I tried what u said and still the same. Nothing changed.
                      New config settings:
                          		disabled: false,
                          		module: 'MMM-NOAA',
                      • tbbearT
                        @gashion Good but u forgot one thing Rename pws to pws1!!!
                        Robert the Bear
                        • Y
                          yomm
                          First of all, thanks for your work.
                          I did have the same issue that @gashion had. I read your comment, it fix it !
                          But… to be honnest I really prefer the v1 look and feel. So is there a way to revert change and stay back in the v1 version ?
                          • G
                            gashion
                            @tbbear
                            How stupid of me. I replaced it and it works now. Thank you! :)
                              stevegoble @tbbear
                              @tbbear
                              I had the same issue. The change to config.js did fix it but now the temp is showing in Celsius. My locals are:
                                      language: "en",
                                      timeFormat: 24,
                                      units: "imperial",
                              any idea?
                              Thanks!
                              • tbbearT
                                tbbear Module Developer @stevegoble
                                @stevegoble hi, this units option does only work for the default weather module. In NOAA its the value of the time format so 24 hours is european so Celsius, 12 hours is USA so Fahrenheit. Where are u living?
                                Robert the Bear
                                  stevegoble @tbbear
                                  @tbbear
                                  Thank you for the quick response. I am in Atlanta, GA USA. I prefer 24 hour clock so…sigh.
                                  tbbearT 2 Replies Last reply Reply Quote 0
                                  • tbbearT
                                    @stevegoble if u have a few minutes i can fix it for u cause i just saw that v1 used units
                                    Robert the Bear
                                    • tbbearT
                                      @stevegoble ok, done do a git pull and u have it like it was using units
                                      Robert the Bear
                                        stevegoble @tbbear
                                        @tbbear
                                        BAH! I just made the locale change to 12!! Thanks a bunch for the fix, I’ll update now… you da man!!
                                        • tbbearT
                                          @stevegoble we love to make the users happy (if we can or we made the mistake lol)
                                          Robert the Bear
                                          • tbbearT
                                            I saw that lot’s of people dont like the headers in v2 so maybe an idea for a headerless option. Please let us know if u would like this option:
                                            (0_1522844950854_headerless.png Bild Link)
                                            Robert the Bear
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
