    • cowboysdudeC
      No… any cloning or git pull should ONLY be done from MMM-NOAA master …
      • tbbearT
        tbbear Module Developer @Mykle1
        @Mykle1 of course not, but i changed a few things and it looks like the people like it but its def. John s modules
        Robert the Bear
        • cowboysdudeC
          That should be done via pull request to the main repository… ;)
          Well because what’s going to end up happening is there will be different versions and that will just confuse the issues.
          • DesaydroneD
            Desaydrone @tbbear
            @tbbear Thanks a lot , i can be patient :D
            • G
              gashion
              First of all, Thank you for this great module.
              After the latest MM update, this module stopped working correctly for him. Does someone know how i can fix this problem.
              Here is a picture :
              alt text
              Here is my config;
                  		disabled: false,
                  		module: 'MMM-NOAA',
                  		position: 'top_right',
              			apiKey: "83c61585aabeb89c",    // https://www.wunderground.com/weather/api  select the 			middle plan...
              			useAir: true,             // set to false if you do not want to use Air Quality Index
              			airKey: "x7hcisbyAjENpBy4f",    // IF you want Air Quality Index
              			pws: "IKIVIKKO4",         // go here to find your pws: https://www.wunderground.com/wundermap
              			showClock: true,           // Hides or shows clock
              			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
              			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
              			ampm: true,                // to show AM and PM on Sunrise/Sunset time
              			showGreet: false,          // deafult is false - to show greeting under clock and above date
              			name: "Moe",                  // Your name
              			showWind: false,
              			showDate: false,
              			showForecast: true,         //show bottom 3 day forecast
              			flash: true,                 //Today in forecast flashes halo
              			showUV: true,               //show UV index
                     		showBar: true,             // show Barometer
                      	showHum: true,              //show Humidity level
              			position: 'top_right',       //whatever you have in above position must also be here
                      	alert: true,                //show weather alerts default is true
              			days: "3"                   //default in config is 3 can be either "3" or "10" for forecast
              tbbearT 1 Reply Last reply Reply Quote 0
              • tbbearT
                tbbear Module Developer @gashion
                @gashion Hi, looks like u are using the v2 so u need to change ur config. U need only a few lines now:
                apiKey
                airKey
                and rename pws to pws1
                Please remove the rest
                Robert the Bear
                • G
                  gashion
                  @tbbear
                  Hi, thanks for ur reply.
                  I tried what u said and still the same. Nothing changed.
                  New config settings:
                      		disabled: false,
                      		module: 'MMM-NOAA',
                  • tbbearT
                    @gashion Good but u forgot one thing Rename pws to pws1!!!
                    Robert the Bear
                    • Y
                      yomm
                      First of all, thanks for your work.
                      I did have the same issue that @gashion had. I read your comment, it fix it !
                      But… to be honnest I really prefer the v1 look and feel. So is there a way to revert change and stay back in the v1 version ?
                      • G
                        gashion
                        @tbbear
                        How stupid of me. I replaced it and it works now. Thank you! :)
                          stevegoble @tbbear
                          @tbbear
                          I had the same issue. The change to config.js did fix it but now the temp is showing in Celsius. My locals are:
                                  language: "en",
                                  timeFormat: 24,
                                  units: "imperial",
                          any idea?
                          Thanks!
                          • tbbearT
                            tbbear Module Developer @stevegoble
                            @stevegoble hi, this units option does only work for the default weather module. In NOAA its the value of the time format so 24 hours is european so Celsius, 12 hours is USA so Fahrenheit. Where are u living?
                            Robert the Bear
                              stevegoble @tbbear
                              @tbbear
                              Thank you for the quick response. I am in Atlanta, GA USA. I prefer 24 hour clock so…sigh.
                              tbbearT 2 Replies Last reply Reply Quote 0
                              • tbbearT
                                @stevegoble if u have a few minutes i can fix it for u cause i just saw that v1 used units
                                Robert the Bear
                                • tbbearT
                                  @stevegoble ok, done do a git pull and u have it like it was using units
                                  Robert the Bear
                                    stevegoble @tbbear
                                    @tbbear
                                    BAH! I just made the locale change to 12!! Thanks a bunch for the fix, I’ll update now… you da man!!
                                    • tbbearT
                                      @stevegoble we love to make the users happy (if we can or we made the mistake lol)
                                      Robert the Bear
                                      • tbbearT
                                        I saw that lot’s of people dont like the headers in v2 so maybe an idea for a headerless option. Please let us know if u would like this option:
                                        (0_1522844950854_headerless.png Bild Link)
                                        Robert the Bear
                                        • Y
                                          yomm
                                          It looks much better :)
                                          • cowboysdudeC
                                            If you prefer not to have colored headers put this into your custom css file:
                                            .MMM-NOAA .rheading {
                                            background-color: transparent;
                                            color: white;
                                            While module makers like to entertain ideas adding more config options is not always the
                                            best answer when it can be changed easily using custom.css.
                                            There in lies the problem some like it, some don’t. Some like V1 of NOAA better.
                                            So there will be 2 versions…1 and 2. :)
                                            V1 can be found here -> http://173.56.209.189:443/topic/26/mmm-noaa-v1
                                            [This is the only place you can get it from] :)
                                            V2 still on github [There will be no config option for this, instead use custom.css]
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
