    • cowboysdudeC
      That should be done via pull request to the main repository… ;)
      Well because what’s going to end up happening is there will be different versions and that will just confuse the issues.
      • DesaydroneD
        Desaydrone @tbbear
        @tbbear Thanks a lot , i can be patient :D
        • G
          gashion
          First of all, Thank you for this great module.
          After the latest MM update, this module stopped working correctly for him. Does someone know how i can fix this problem.
          Here is a picture :
          alt text
          Here is my config;
              		disabled: false,
              		module: 'MMM-NOAA',
              		position: 'top_right',
          			apiKey: "83c61585aabeb89c",    // https://www.wunderground.com/weather/api  select the 			middle plan...
          			useAir: true,             // set to false if you do not want to use Air Quality Index
          			airKey: "x7hcisbyAjENpBy4f",    // IF you want Air Quality Index
          			pws: "IKIVIKKO4",         // go here to find your pws: https://www.wunderground.com/wundermap
          			showClock: true,           // Hides or shows clock
          			dformat: false,             // for M/D/YYYY format, false for D/M/YYYY
          			format: "24",              // 12 or 24 hour format.. will default to 12 hour if none selected.
          			ampm: true,                // to show AM and PM on Sunrise/Sunset time
          			showGreet: false,          // deafult is false - to show greeting under clock and above date
          			name: "Moe",                  // Your name
          			showWind: false,
          			showDate: false,
          			showForecast: true,         //show bottom 3 day forecast
          			flash: true,                 //Today in forecast flashes halo
          			showUV: true,               //show UV index
                 		showBar: true,             // show Barometer
                  	showHum: true,              //show Humidity level
          			position: 'top_right',       //whatever you have in above position must also be here
                  	alert: true,                //show weather alerts default is true
          			days: "3"                   //default in config is 3 can be either "3" or "10" for forecast
          tbbearT 1 Reply Last reply Reply Quote 0
          • tbbearT
            tbbear Module Developer @gashion
            @gashion Hi, looks like u are using the v2 so u need to change ur config. U need only a few lines now:
            apiKey
            airKey
            and rename pws to pws1
            Please remove the rest
            Robert the Bear
            • G
              gashion
              @tbbear
              Hi, thanks for ur reply.
              I tried what u said and still the same. Nothing changed.
              New config settings:
                  		disabled: false,
                  		module: 'MMM-NOAA',
              • tbbearT
                @gashion Good but u forgot one thing Rename pws to pws1!!!
                Robert the Bear
                • Y
                  yomm
                  First of all, thanks for your work.
                  I did have the same issue that @gashion had. I read your comment, it fix it !
                  But… to be honnest I really prefer the v1 look and feel. So is there a way to revert change and stay back in the v1 version ?
                  • G
                    gashion
                    @tbbear
                    How stupid of me. I replaced it and it works now. Thank you! :)
                      stevegoble @tbbear
                      @tbbear
                      I had the same issue. The change to config.js did fix it but now the temp is showing in Celsius. My locals are:
                              language: "en",
                              timeFormat: 24,
                              units: "imperial",
                      any idea?
                      Thanks!
                      • tbbearT
                        tbbear Module Developer @stevegoble
                        @stevegoble hi, this units option does only work for the default weather module. In NOAA its the value of the time format so 24 hours is european so Celsius, 12 hours is USA so Fahrenheit. Where are u living?
                        Robert the Bear
                          stevegoble @tbbear
                          @tbbear
                          Thank you for the quick response. I am in Atlanta, GA USA. I prefer 24 hour clock so…sigh.
                          tbbearT 2 Replies Last reply Reply Quote 0
                          • tbbearT
                            @stevegoble if u have a few minutes i can fix it for u cause i just saw that v1 used units
                            Robert the Bear
                            • tbbearT
                              @stevegoble ok, done do a git pull and u have it like it was using units
                              Robert the Bear
                                stevegoble @tbbear
                                @tbbear
                                BAH! I just made the locale change to 12!! Thanks a bunch for the fix, I’ll update now… you da man!!
                                • tbbearT
                                  @stevegoble we love to make the users happy (if we can or we made the mistake lol)
                                  Robert the Bear
                                  • tbbearT
                                    I saw that lot’s of people dont like the headers in v2 so maybe an idea for a headerless option. Please let us know if u would like this option:
                                    (0_1522844950854_headerless.png Bild Link)
                                    Robert the Bear
                                    • Y
                                      yomm
                                      It looks much better :)
                                      • cowboysdudeC
                                        If you prefer not to have colored headers put this into your custom css file:
                                        .MMM-NOAA .rheading {
                                        background-color: transparent;
                                        color: white;
                                        While module makers like to entertain ideas adding more config options is not always the
                                        best answer when it can be changed easily using custom.css.
                                        There in lies the problem some like it, some don’t. Some like V1 of NOAA better.
                                        So there will be 2 versions…1 and 2. :)
                                        V1 can be found here -> http://173.56.209.189:443/topic/26/mmm-noaa-v1
                                        [This is the only place you can get it from] :)
                                        V2 still on github [There will be no config option for this, instead use custom.css]
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @tbbear
                                          @tbbear said in MMM-NOAA - Another Weather Module:
                                          Where? :-)
                                          • G
                                            gashion
                                            I changed the colors of the header to black. Looks better now…For me…
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
