    • tbbearT Offline
      tbbear Module Developer @kbostick88
      @kbostick88 are u sure that ur keys are ok and also ur pws1. i will check them if u want
      Robert the Bear
      • tbbearT Offline
        @kbostick88 Looks like ur pws1 is not correct, maybe again a typing error … -)
        Robert the Bear
        • K Offline
          kbostick88
          I got it. Thanks!
          tbbearT 1 Reply Last reply Reply Quote 0
          • tbbearT Offline
            @kbostick88 your welcome
            Robert the Bear
            • K Offline
              kbostick88 @tbbear
              @tbbear I am having issues with one other module also, any chance you might be able to help me with that one? I had the module working, but all of a sudden part of it seems broke. I get NaN on that one… its MMM-cryptocurrency
              Bitcoin works fine, ethereum, litecoin and ripple all show NaN but all 4 were working yesterday. not sure why they are not working now, nothing changed.
              • tbbearT Offline
                @kbostick88 sorry, i dont use any one of this modules. i would love to help u but i dont know the modules u are using. But maybe contact Mykle1 he is the best helper here. If u like the help i did for u maybe gimme a click on the ^ sign close to my answers.
                Robert the Bear
                tbbearT 1 Reply Last reply Reply Quote 1
                • K Offline
                  kbostick88
                  ok thanks, i posted it in the correct module so ill see if i can get it. Thanks for the help!
                  • tbbearT Offline
                    tbbear Module Developer @tbbear
                    @tbbear Thanks, if i can help contact me anytime, maybe u can show me ur config, cause in the most cases their is the problem
                    Robert the Bear
                    • K Offline
                      kbostick88 @tbbear
                      @tbbear
                      	module: "MMM-cryptocurrency",
                      		currency: ['bitcoin', 'ethereum', 'litecoin', 'ripple'],
                      		displayType: 'logo',
                      		showGraphs: false
                        Stellanova @kbostick88
                        • K Offline
                          kbostick88 @Stellanova
                          @Stellanova Did yours just stop working too? mine was working fine for several days
                              barnosch
                              please do not use this thread for a complete other module and problem
                              • cowboysdudeC Offline
                                MMM-NOAA3 is in the works…
                                It will be a little while but rest assured I’m working on it :)
                                • Z Offline
                                  Zooooooom
                                  Finally updated the module, and I like the new look. However, I was wondering if there’s a toggle to hide the “Forecast” piece.
                                  Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                                    Mykle1 Project Sponsor Module Developer @Zooooooom
                                    @Zooooooom
                                    You can’t hide it in css?
                                    Z 1 Reply Last reply Reply Quote 0
                                    • Z Offline
                                      Zooooooom @Mykle1
                                      I believe the last version had some toggles in the config which were quite nice to have, which is why I am asking if it’s there now. I took a quick look at the code, and wasn’t able to find anything like it.
                                      I would prefer not to mess with CSS files, because it would mean that updates might break my config.
                                        @Zooooooom said in MMM-NOAA - Another Weather Module:
                                        No sir. Your config is unaffected by your custom.css entries. In fact, it’s the very reason there is a custom.css file, so that you can make those changes without changing the module files and you don’t lose your changes when the module is updated.
                                        Z 1 Reply Last reply Reply Quote 1
                                          cowboysdude Module Developer @Zooooooom
                                          @Zooooooom put this in your custom.css file:
                                          .MMM-NOAA .forehead {
                                          display: none;
                                          .MMM-NOAA .fmar {
                                          display: none;
                                          after you do a git pull to update your NOAA css file :)
                                          Z 1 Reply Last reply Reply Quote 2
                                          • Z Offline
                                            Zooooooom @Mykle1
                                            @Mykle1 Thanks, I didn’t realize that.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 34
                                            • 35
                                            • 19 / 35
