    690 Posts 77 Posters 3.3m Views 70 Watching
    • tbbearT
      tbbear Module Developer @kbostick88
      @kbostick88 sorry, i dont use any one of this modules. i would love to help u but i dont know the modules u are using. But maybe contact Mykle1 he is the best helper here. If u like the help i did for u maybe gimme a click on the ^ sign close to my answers.
      Robert the Bear
      tbbearT 1 Reply Last reply
      • K
        kbostick88
        ok thanks, i posted it in the correct module so ill see if i can get it. Thanks for the help!
        • tbbearT
          tbbear Module Developer @tbbear
          @tbbear Thanks, if i can help contact me anytime, maybe u can show me ur config, cause in the most cases their is the problem
          Robert the Bear
          K 1 Reply Last reply
          • K
            kbostick88 @tbbear
            @tbbear
            	module: "MMM-cryptocurrency",
            		currency: ['bitcoin', 'ethereum', 'litecoin', 'ripple'],
            		displayType: 'logo',
            		showGraphs: false
              Stellanova @kbostick88
              • K
                kbostick88 @Stellanova
                @Stellanova Did yours just stop working too? mine was working fine for several days
                    barnosch
                    please do not use this thread for a complete other module and problem
                    • cowboysdudeC
                      MMM-NOAA3 is in the works…
                      It will be a little while but rest assured I’m working on it :)
                      • Z
                        Zooooooom
                        Finally updated the module, and I like the new look. However, I was wondering if there’s a toggle to hide the “Forecast” piece.
                        Mykle1M cowboysdudeC 2 Replies Last reply
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Zooooooom
                          @Zooooooom
                          You can’t hide it in css?
                          Z 1 Reply Last reply
                          • Z
                            Zooooooom @Mykle1
                            I believe the last version had some toggles in the config which were quite nice to have, which is why I am asking if it’s there now. I took a quick look at the code, and wasn’t able to find anything like it.
                            I would prefer not to mess with CSS files, because it would mean that updates might break my config.
                            Mykle1M 1 Reply Last reply
                            • Mykle1M
                              @Zooooooom said in MMM-NOAA - Another Weather Module:
                              No sir. Your config is unaffected by your custom.css entries. In fact, it’s the very reason there is a custom.css file, so that you can make those changes without changing the module files and you don’t lose your changes when the module is updated.
                              • cowboysdudeC
                                cowboysdude Module Developer @Zooooooom
                                @Zooooooom put this in your custom.css file:
                                .MMM-NOAA .forehead {
                                display: none;
                                .MMM-NOAA .fmar {
                                display: none;
                                after you do a git pull to update your NOAA css file :)
                                Reply Quote 2
                                • Z
                                  Zooooooom @Mykle1
                                  @Mykle1 Thanks, I didn’t realize that.
                                  • Z
                                    Zooooooom @cowboysdude
                                    @cowboysdude Awesome, thanks!
                                      Peter
                                      I am using NOAA version 1 because I like this more than version 2.
                                      Is there any problem going to be in the future with version 1?
                                      Peter
                                      • Mykle1M
                                        @Zooooooom
                                        You are welcome, sir. I see that @cowboysdude has given you some direct assistance above so I will bow out gracefully. Props to @cowboysdude for his wonderful module and fantastic support.
                                        • cowboysdudeC
                                          cowboysdude Module Developer @Peter
                                          @Peter said in MMM-NOAA - Another Weather Module:
                                          Peter
                                          Not sure what you mean. Do you mean you’d like to see future versions based on V1?
                                          P 1 Reply Last reply
                                            Peter @cowboysdude
                                            @cowboysdude yes; there are not going to be any updates for version 1?
                                            Peter
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 34
                                            • 35
                                            • 19 / 35
