    690 Posts 77 Posters 3.3m Views 70 Watching
      Stellanova @kbostick88
      K 1 Reply Last reply
      • K
        kbostick88 @Stellanova
        @Stellanova Did yours just stop working too? mine was working fine for several days
            barnosch
            please do not use this thread for a complete other module and problem
            • cowboysdudeC
              MMM-NOAA3 is in the works…
              It will be a little while but rest assured I’m working on it :)
              • Z
                Zooooooom
                Finally updated the module, and I like the new look. However, I was wondering if there’s a toggle to hide the “Forecast” piece.
                Mykle1M cowboysdudeC 2 Replies Last reply
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @Zooooooom
                  @Zooooooom
                  You can’t hide it in css?
                  Z 1 Reply Last reply
                  • Z
                    Zooooooom @Mykle1
                    I believe the last version had some toggles in the config which were quite nice to have, which is why I am asking if it’s there now. I took a quick look at the code, and wasn’t able to find anything like it.
                    I would prefer not to mess with CSS files, because it would mean that updates might break my config.
                    Mykle1M 1 Reply Last reply
                    • Mykle1M
                      @Zooooooom said in MMM-NOAA - Another Weather Module:
                      No sir. Your config is unaffected by your custom.css entries. In fact, it’s the very reason there is a custom.css file, so that you can make those changes without changing the module files and you don’t lose your changes when the module is updated.
                      • cowboysdudeC
                        cowboysdude Module Developer @Zooooooom
                        @Zooooooom put this in your custom.css file:
                        .MMM-NOAA .forehead {
                        display: none;
                        .MMM-NOAA .fmar {
                        display: none;
                        after you do a git pull to update your NOAA css file :)
                        Reply Quote 2
                        • Z
                          Zooooooom @Mykle1
                          @Mykle1 Thanks, I didn’t realize that.
                          • Z
                            Zooooooom @cowboysdude
                            @cowboysdude Awesome, thanks!
                              Peter
                              I am using NOAA version 1 because I like this more than version 2.
                              Is there any problem going to be in the future with version 1?
                              Peter
                              • Mykle1M
                                @Zooooooom
                                You are welcome, sir. I see that @cowboysdude has given you some direct assistance above so I will bow out gracefully. Props to @cowboysdude for his wonderful module and fantastic support.
                                • cowboysdudeC
                                  cowboysdude Module Developer @Peter
                                  @Peter said in MMM-NOAA - Another Weather Module:
                                  Peter
                                  Not sure what you mean. Do you mean you’d like to see future versions based on V1?
                                  P 1 Reply Last reply
                                    Peter @cowboysdude
                                    @cowboysdude yes; there are not going to be any updates for version 1?
                                    Peter
                                      barnosch
                                      Same for me.
                                      I will stay with V1, since the new one is too fancy (and way to big) for me.
                                      Hope it will not getting corrupted by any changes with the new versions.
                                      • yawnsY
                                        yawns Moderator
                                        Ideal would be to use the same core and develope different templates which could be chosen via config.
                                        Reply Quote 2
                                        • cowboysdudeC
                                          cowboysdude Module Developer @yawns
                                          @yawns said in MMM-NOAA - Another Weather Module:
                                          You would think that wouldn’t you? LOL
                                          • Mykle1M
                                            This is, by far, my favorite weather module, V1 and V2. And like everyone else, I have my own likes and dislikes. But rather than trouble @cowboysdude and his vision of what he wants the module to be, I made my own adjustments via css. With 76.6k views, and 390 posts in this topic alone, I can’t even imagine trying to satisfy everyone’s requests.
                                            Forrest Gump: “That’s all I have to say about that.”
                                            Reply Quote 2
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 34
                                            • 35
                                            • 20 / 35
