    690 Posts 77 Posters 3.3m Views 70 Watching
    • Z
      Zooooooom
      Finally updated the module, and I like the new look. However, I was wondering if there’s a toggle to hide the “Forecast” piece.
      Mykle1M cowboysdudeC 2 Replies Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Zooooooom
        @Zooooooom
        You can’t hide it in css?
        Z 1 Reply Last reply
        • Z
          Zooooooom @Mykle1
          I believe the last version had some toggles in the config which were quite nice to have, which is why I am asking if it’s there now. I took a quick look at the code, and wasn’t able to find anything like it.
          I would prefer not to mess with CSS files, because it would mean that updates might break my config.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            @Zooooooom said in MMM-NOAA - Another Weather Module:
            No sir. Your config is unaffected by your custom.css entries. In fact, it’s the very reason there is a custom.css file, so that you can make those changes without changing the module files and you don’t lose your changes when the module is updated.
            • cowboysdudeC
              cowboysdude Module Developer @Zooooooom
              @Zooooooom put this in your custom.css file:
              .MMM-NOAA .forehead {
              display: none;
              .MMM-NOAA .fmar {
              display: none;
              after you do a git pull to update your NOAA css file :)
              Reply Quote 2
              • Z
                Zooooooom @Mykle1
                @Mykle1 Thanks, I didn’t realize that.
                • Z
                  Zooooooom @cowboysdude
                  @cowboysdude Awesome, thanks!
                    Peter
                    I am using NOAA version 1 because I like this more than version 2.
                    Is there any problem going to be in the future with version 1?
                    Peter
                    • Mykle1M
                      @Zooooooom
                      You are welcome, sir. I see that @cowboysdude has given you some direct assistance above so I will bow out gracefully. Props to @cowboysdude for his wonderful module and fantastic support.
                      • cowboysdudeC
                        cowboysdude Module Developer @Peter
                        @Peter said in MMM-NOAA - Another Weather Module:
                        Peter
                        Not sure what you mean. Do you mean you’d like to see future versions based on V1?
                        P 1 Reply Last reply
                          Peter @cowboysdude
                          @cowboysdude yes; there are not going to be any updates for version 1?
                          Peter
                            barnosch
                            Same for me.
                            I will stay with V1, since the new one is too fancy (and way to big) for me.
                            Hope it will not getting corrupted by any changes with the new versions.
                            • yawnsY
                              yawns Moderator
                              Ideal would be to use the same core and develope different templates which could be chosen via config.
                              Reply Quote 2
                              • cowboysdudeC
                                cowboysdude Module Developer @yawns
                                @yawns said in MMM-NOAA - Another Weather Module:
                                You would think that wouldn’t you? LOL
                                • Mykle1M
                                  This is, by far, my favorite weather module, V1 and V2. And like everyone else, I have my own likes and dislikes. But rather than trouble @cowboysdude and his vision of what he wants the module to be, I made my own adjustments via css. With 76.6k views, and 390 posts in this topic alone, I can’t even imagine trying to satisfy everyone’s requests.
                                  Forrest Gump: “That’s all I have to say about that.”
                                  Reply Quote 2
                                    soshea1
                                    Hey there,
                                    Im hoping that someone can help me out with an error on this module. I am a complete newbie to this, so please bare with me.
                                    I have loaded the MMM-NOA module onto the config script, created the API key and selected the PWS on wundermap. However when i load up Magic Mirror- The module displays 'Undefined and NAN with no information loaded. It seems like it is just not pulling the info from the PWS correctly.
                                    I followed the instructions correctly, but dont seem to be able to fix this.
                                    Thank you
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @soshea1
                                      @soshea1
                                      Did you try another PWS? They can fail. Also, post your config entry for NOAA here (in a code block) so we can have a look at it.
                                        soshea1 @Mykle1
                                        @Mykle1
                                        Yes i tried using multiple different PWS codes, and still none of them display.
                                        Ill try upload a picture in a separate reply of what displays.
                                        Thanks for any help
                                        /* Magic Mirror Config Sample
                                         * MIT Licensed.
                                        var config = {
                                        	                      // - "localhost", "127.", "::1" to listen on loopback interface
                                        	port: 8080,
                                        	ipWhitelist: ["127.0.0.1", "::ffff:127", "::1"], // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.****** :
        // ["127.0.0.1", "::ffff:127", "::1", "::ffff:192."],
        // or IPv4 range of 192. --> 192.1 use CIDR format :
        // ["127.0.0.1", "::ffff:127.", "::1", "::ffff:192/28"],
                                        	language: "en",
                                        	timeFormat: 24,
                                        	units: "metric",
                                        			module: "alert",
                                        			module: "updatenotification",
                                        			position: "top_bar"
                                        			module: "clock",
                                        			position: "top_left"
                                        			header: "Canada Holidays",
                                        						symbol: "calendar-check-o ",
                                        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics"
                                        			module: "compliments",
                                        			position: "lower_third"
                                        			disabled: true,
                                        			module: "currentweather",
                                        				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                        			disabled: true,
                                        			module: "weatherforecast",
                                        			header: "Weather Forecast",
                                        				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                        			module: "newsfeed",
                                        			position: "bottom_bar",
                                        				feeds: [
                                        						title: "New York Times",
                                        				showSourceTitle: true,
                                        				showPublishDate: true
                                        			disabled: false,
                                        			module: 'MMM-NOAA',
                                        			apiKey: "f78fa7e86*****",
                                        			useAir: false,
                                        			psw1: "IONTARIO1060",
                                        			lat: "43.177",
                                        			long: "-79.800",
                                        • yawnsY
                                          yawns Moderator
                                          It is pws1, not psw1
                                          And according to the readme you don’t need lat and long
                                          Reply Quote 2
                                            soshea1
                                            @yawns
                                            Thank you so much!. Such a small detail caused me hours of pain!
                                            I must of looked at that config 100 times and didnt spot that!
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 34
                                            • 35
                                            • 20 / 35
