    690 Posts 77 Posters 3.3m Views 70 Watching
    • cowboysdudeC
      cowboysdude Module Developer @Zooooooom
      @Zooooooom put this in your custom.css file:
      .MMM-NOAA .forehead {
      display: none;
      .MMM-NOAA .fmar {
      display: none;
      after you do a git pull to update your NOAA css file :)
      Z 1 Reply Last reply
      Reply Quote 2
      • Z
        Zooooooom @Mykle1
        @Mykle1 Thanks, I didn’t realize that.
        Mykle1M 1 Reply Last reply
        • Z
          Zooooooom @cowboysdude
          @cowboysdude Awesome, thanks!
            Peter
            I am using NOAA version 1 because I like this more than version 2.
            Is there any problem going to be in the future with version 1?
            Peter
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Zooooooom
              @Zooooooom
              @Zooooooom said in MMM-NOAA - Another Weather Module:
              You are welcome, sir. I see that @cowboysdude has given you some direct assistance above so I will bow out gracefully. Props to @cowboysdude for his wonderful module and fantastic support.
              • cowboysdudeC
                cowboysdude Module Developer @Peter
                @Peter said in MMM-NOAA - Another Weather Module:
                Peter
                Not sure what you mean. Do you mean you’d like to see future versions based on V1?
                P 1 Reply Last reply
                  Peter @cowboysdude
                  @cowboysdude yes; there are not going to be any updates for version 1?
                  Peter
                    barnosch
                    Same for me.
                    I will stay with V1, since the new one is too fancy (and way to big) for me.
                    Hope it will not getting corrupted by any changes with the new versions.
                    • yawnsY
                      yawns Moderator
                      Ideal would be to use the same core and develope different templates which could be chosen via config.
                      Reply Quote 2
                      • cowboysdudeC
                        cowboysdude Module Developer @yawns
                        @yawns said in MMM-NOAA - Another Weather Module:
                        You would think that wouldn’t you? LOL
                        • Mykle1M
                          This is, by far, my favorite weather module, V1 and V2. And like everyone else, I have my own likes and dislikes. But rather than trouble @cowboysdude and his vision of what he wants the module to be, I made my own adjustments via css. With 76.6k views, and 390 posts in this topic alone, I can’t even imagine trying to satisfy everyone’s requests.
                          Forrest Gump: “That’s all I have to say about that.”
                          Reply Quote 2
                            soshea1
                            Hey there,
                            Im hoping that someone can help me out with an error on this module. I am a complete newbie to this, so please bare with me.
                            I have loaded the MMM-NOA module onto the config script, created the API key and selected the PWS on wundermap. However when i load up Magic Mirror- The module displays 'Undefined and NAN with no information loaded. It seems like it is just not pulling the info from the PWS correctly.
                            I followed the instructions correctly, but dont seem to be able to fix this.
                            Thank you
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @soshea1
                              @soshea1
                              Did you try another PWS? They can fail. Also, post your config entry for NOAA here (in a code block) so we can have a look at it.
                                soshea1 @Mykle1
                                @Mykle1
                                Yes i tried using multiple different PWS codes, and still none of them display.
                                Ill try upload a picture in a separate reply of what displays.
                                Thanks for any help
                                /* Magic Mirror Config Sample
                                 * MIT Licensed.
                                var config = {
                                	                      // - "localhost", "127.", "::1" to listen on loopback interface
                                	port: 8080,
                                	ipWhitelist: ["127.0.0.1", "::ffff:127", "::1"], // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.****** :
        // ["127.0.0.1", "::ffff:127", "::1", "::ffff:192."],
        // or IPv4 range of 192. --> 192.1 use CIDR format :
        // ["127.0.0.1", "::ffff:127.", "::1", "::ffff:192/28"],
                                	language: "en",
                                	timeFormat: 24,
                                	units: "metric",
                                			module: "alert",
                                			module: "updatenotification",
                                			position: "top_bar"
                                			module: "clock",
                                			position: "top_left"
                                			header: "Canada Holidays",
                                						symbol: "calendar-check-o ",
                                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics"
                                			module: "compliments",
                                			position: "lower_third"
                                			disabled: true,
                                			module: "currentweather",
                                				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                			disabled: true,
                                			module: "weatherforecast",
                                			header: "Weather Forecast",
                                				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                			module: "newsfeed",
                                			position: "bottom_bar",
                                				feeds: [
                                						title: "New York Times",
                                				showSourceTitle: true,
                                				showPublishDate: true
                                			disabled: false,
                                			module: 'MMM-NOAA',
                                			apiKey: "f78fa7e86*****",
                                			useAir: false,
                                			psw1: "IONTARIO1060",
                                			lat: "43.177",
                                			long: "-79.800",
                                • yawnsY
                                  yawns Moderator
                                  It is pws1, not psw1
                                  And according to the readme you don’t need lat and long
                                  Reply Quote 2
                                    soshea1
                                    @yawns
                                    Thank you so much!. Such a small detail caused me hours of pain!
                                    I must of looked at that config 100 times and didnt spot that!
                                    • Mykle1M
                                      @soshea1
                                      @yawns is KING! :-)
                                      • cowboysdudeC
                                        Folks NOAA 3 is WELL under development BUT with Wunderground going belly up on users I’ll have to reconfigure a lot of stuff… at this point Wunderground will no longer be used to get the weather for NOAA, NOAA2 or 3.
                                        IF you’re having issues with either NOAA or NOAA2 please post them here …
                                        http://108.29.66.102:443/
                                        • cowboysdudeC
                                          I’ll be reconfiguring NOAA2 this evening… will let you know.
                                          • Mykle1M
                                            @cowboysdude
                                            Hurry up. I don’t have all night. ;-)
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 34
                                            • 35
                                            • 20 / 35
