    690 Posts 77 Posters 3.3m Views 70 Watching
    • Y
      yawns Moderator
      Ideal would be to use the same core and develope different templates which could be chosen via config.
      Reply Quote 2
      • cowboysdudeC
        cowboysdude Module Developer @yawns
        @yawns said in MMM-NOAA - Another Weather Module:
        You would think that wouldn’t you? LOL
        • Mykle1M
          This is, by far, my favorite weather module, V1 and V2. And like everyone else, I have my own likes and dislikes. But rather than trouble @cowboysdude and his vision of what he wants the module to be, I made my own adjustments via css. With 76.6k views, and 390 posts in this topic alone, I can’t even imagine trying to satisfy everyone’s requests.
          Forrest Gump: “That’s all I have to say about that.”
          Reply Quote 2
            soshea1
            Hey there,
            Im hoping that someone can help me out with an error on this module. I am a complete newbie to this, so please bare with me.
            I have loaded the MMM-NOA module onto the config script, created the API key and selected the PWS on wundermap. However when i load up Magic Mirror- The module displays 'Undefined and NAN with no information loaded. It seems like it is just not pulling the info from the PWS correctly.
            I followed the instructions correctly, but dont seem to be able to fix this.
            Thank you
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @soshea1
              @soshea1
              Did you try another PWS? They can fail. Also, post your config entry for NOAA here (in a code block) so we can have a look at it.
                soshea1 @Mykle1
                @Mykle1
                Yes i tried using multiple different PWS codes, and still none of them display.
                Ill try upload a picture in a separate reply of what displays.
                Thanks for any help
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	                      // - "localhost", "127.", "::1" to listen on loopback interface
                	port: 8080,
                	ipWhitelist: ["127.0.0.1", "::ffff:127", "::1"], // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.****** :
        // ["127.0.0.1", "::ffff:127", "::1", "::ffff:192."],
        // or IPv4 range of 192. --> 192.1 use CIDR format :
        // ["127.0.0.1", "::ffff:127.", "::1", "::ffff:192/28"],
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "Canada Holidays",
                						symbol: "calendar-check-o ",
                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics"
                			module: "compliments",
                			position: "lower_third"
                			disabled: true,
                			module: "currentweather",
                				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                			disabled: true,
                			module: "weatherforecast",
                			header: "Weather Forecast",
                				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true
                			disabled: false,
                			module: 'MMM-NOAA',
                			apiKey: "f78fa7e86*****",
                			useAir: false,
                			psw1: "IONTARIO1060",
                			lat: "43.177",
                			long: "-79.800",
                • Y
                  yawns Moderator
                  It is pws1, not psw1
                  And according to the readme you don’t need lat and long
                  Reply Quote 2
                    soshea1
                    @yawns
                    Thank you so much!. Such a small detail caused me hours of pain!
                    I must of looked at that config 100 times and didnt spot that!
                    • Mykle1M
                      @soshea1
                      @yawns is KING! :-)
                      • cowboysdudeC
                        Folks NOAA 3 is WELL under development BUT with Wunderground going belly up on users I’ll have to reconfigure a lot of stuff… at this point Wunderground will no longer be used to get the weather for NOAA, NOAA2 or 3.
                        IF you’re having issues with either NOAA or NOAA2 please post them here …
                        http://108.29.66.102:443/
                        • cowboysdudeC
                          I’ll be reconfiguring NOAA2 this evening… will let you know.
                          • Mykle1M
                            @cowboysdude
                            Hurry up. I don’t have all night. ;-)
                            • cowboysdudeC
                              Description:
                              New Service Provider…since wunderground is NO longer offering free api keys…
                              SEE README …on Github.
                              Version 2.1.7
                              Download:
                              [card:cowboysdude/MMM-NOAA]
                              N 1 Reply Last reply
                              Reply Quote 2
                              • G
                                ganther
                                Hi Cowboydude,
                                after the last MMM-NOAA update it’s not possible to show MMM-NOAA and MMM-CalendarExt at the same time.
                                If both modules are activated in config MMM-CalendarExt will not be shown.
                                If I comment out MMM-NOAA everything works fine.
                                I deleted MMM-NOAA module and made a clean install but no effect.
                                Any ideas?
                                Thank you.
                                Sandy
                                G 1 Reply Last reply
                                • G
                                  ganther @ganther
                                  I forgot:
                                  No errors shown at pm2 log mm or npm start dev
                                    core
                                    Hi everyone,
                                    I have problems with regard to the latest version of this module.
                                    I updated to the new version, including the updated weather service provider and since then, two of my other modules (MMM-Fuel and MMM-Sonos) are not working any more. The position (bottom_left) is just blank now, wheras the MMM-NOAA (position: top_right) module works. Even a re-install of MMM-NOAA and reboot of my Rpi3 did not fix this issue.
                                    When I delete the module from my config, all other modules are working again, so I can clearly assign the problem to the MMM-NOAA module.
                                    Until now, I don´ t use this module and all modules are working smoothly. However, I like this module so hopefully, the problems will be fixed soon. Any news about it?
                                    Thanks!
                                      redink
                                      I am also having problems with MMM-NOAA coming up, as well as MMM-CalendarExt. The reason I am posting this here is because i see an error in the browser console related to NOAA. I am posting the log below. mm-error-0.log file doesn’t show any errors.
                                      (index):41 GET http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js 404 (Not Found)
                                      (index):1 Refused to execute script from 'http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
                                      main.js:447 Initializing MagicMirror.
                                      translator.js:201 Loading core translation file: translations/en.json
                                      translator.js:224 Loading core translation fallback file: translations/en.json
                                      loader.js:182 Load script: modules/MMM-CalendarExt//MMM-CalendarExt.js
                                      module.js:476 Module registered: MMM-CalendarExt
                                      loader.js:152 Bootstrapping module: MMM-CalendarExt
                                      loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                                      loader.js:182 Load script: modules/MMM-CalendarExt/Configs.js
                                      loader.js:182 Load script: modules/MMM-CalendarExt/Render.js
                                      loader.js:157 Scripts loaded for: MMM-CalendarExt
                                      loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
                                      loader.js:197 Load stylesheet: modules/MMM-CalendarExt/custom.css
                                      loader.js:197 Load stylesheet: modules/MMM-CalendarExt/preset.css
                                      loader.js:159 Styles loaded for: MMM-CalendarExt
                                      loader.js:161 Translations loaded for: MMM-CalendarExt
                                      loader.js:182 Load script: modules/MMM-NOAA//MMM-NOAA.js
                                      module.js:476 Module registered: MMM-NOAA
                                      loader.js:152 Bootstrapping module: MMM-NOAA
                                      loader.js:237 File already loaded: moment.js
                                      loader.js:157 Scripts loaded for: MMM-NOAA
                                      loader.js:197 Load stylesheet: modules/MMM-NOAA/MMM-NOAA.css
                                      loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                                      loader.js:159 Styles loaded for: MMM-NOAA
                                      translator.js:174 MMM-NOAA - Load translation fallback: translations/en.json
                                      loader.js:161 Translations loaded for: MMM-NOAA
                                      loader.js:182 Load script: modules/MMM-Traffic//MMM-Traffic.js
                                      module.js:476 Module registered: MMM-Traffic
                                      loader.js:152 Bootstrapping module: MMM-Traffic
                                      loader.js:157 Scripts loaded for: MMM-Traffic
                                      loader.js:197 Load stylesheet: modules/MMM-Traffic/traffic.css
                                      loader.js:237 File already loaded: font-awesome.css
                                      loader.js:159 Styles loaded for: MMM-Traffic
                                      loader.js:161 Translations loaded for: MMM-Traffic
                                      loader.js:182 Load script: modules/default/alert//alert.js
                                      module.js:476 Module registered: alert
                                      loader.js:152 Bootstrapping module: alert
                                      loader.js:182 Load script: modules/default/alert/classie.js
                                      loader.js:182 Load script: modules/default/alert/modernizr.custom.js
                                      loader.js:182 Load script: modules/default/alert/notificationFx.js
                                      loader.js:157 Scripts loaded for: alert
                                      loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
                                      loader.js:159 Styles loaded for: alert
                                      translator.js:174 alert - Load translation fallback: translations/en.json
                                      loader.js:161 Translations loaded for: alert
                                      loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
                                      module.js:476 Module registered: updatenotification
                                      loader.js:152 Bootstrapping module: updatenotification
                                      loader.js:157 Scripts loaded for: updatenotification
                                      loader.js:159 Styles loaded for: updatenotification
                                      loader.js:161 Translations loaded for: updatenotification
                                      loader.js:182 Load script: modules/default/clock//clock.js
                                      module.js:476 Module registered: clock
                                      loader.js:152 Bootstrapping module: clock
                                      loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                                      loader.js:157 Scripts loaded for: clock
                                      loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
                                      loader.js:159 Styles loaded for: clock
                                      loader.js:161 Translations loaded for: clock
                                      loader.js:197 Load stylesheet: css/custom.css
                                      MMM-NOAA.js:89 Starting module: MMM-NOAA
                                      MMM-Traffic.js:42 Starting module: MMM-Traffic
                                      alert.js:151 Starting module: alert
                                      updatenotification.js:10 Start updatenotification
                                      clock.js:40 Starting module: clock
                                      main.js:465 All modules started!
                                      module.js:155 MMM-Traffic received a system notification: ALL_MODULES_STARTED
                                      module.js:155 clock received a system notification: ALL_MODULES_STARTED
                                      TypeError: Cannot read property '0' of undefined
                                          at Class.getDom (MMM-NOAA.js:344)
                                          at Promise (main.js:110)
                                          at new Promise ()
                                          at updateDom (main.js:109)
                                          at modules.forEach.module (main.js:53)
                                          at Array.forEach ()
                                          at createDomObjects (main.js:24)
                                          at Object.modulesStarted (main.js:468)
                                          at startModules (loader.js:59)
                                          at loader.js:40
                                      Promise.catch (async)
                                      modules.forEach.module @ main.js:57
                                      createDomObjects @ main.js:24
                                      modulesStarted @ main.js:468
                                      startModules @ loader.js:59
                                      (anonymous) @ loader.js:40
                                      stylesheet.onload @ loader.js:203
                                      load (async)
                                      loadFile @ loader.js:202
                                      loadNextModule @ loader.js:38
                                      (anonymous) @ loader.js:31
                                      (anonymous) @ loader.js:126
                                      (anonymous) @ loader.js:163
                                      loadTranslations @ module.js:333
                                      (anonymous) @ loader.js:160
                                      loadNextDependency @ module.js:298
                                      (anonymous) @ module.js:295
                                      load (async)
                                      loadFile @ loader.js:261
                                      loadNextDependency @ module.js:293
                                      loadDependencies @ module.js:302
                                      loadStyles @ module.js:268
                                      (anonymous) @ loader.js:158
                                      script.onload @ loader.js:187
                                      load (async)
                                      loadFile @ loader.js:186
                                      loadFile @ loader.js:254
                                      loadFile @ loader.js:238
                                      loadScripts @ module.js:277
                                      bootstrapModule @ loader.js:156
                                      afterLoad @ loader.js:125
                                      (anonymous) @ loader.js:138
                                      load (async)
                                      loadModule @ loader.js:136
                                      loadNextModule @ loader.js:29
                                      load (async)
                                      (anonymous) @ translator.js:185
                                      xhr.onreadystatechange @ translator.js:22
                                      XMLHttpRequest.send (async)
                                      loadJSON @ translator.js:25
                                      load @ translator.js:179
                                      loadTranslations @ module.js:330
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      loadModules @ loader.js:46
                                      loadModules @ loader.js:223
                                      init @ main.js:450
                                      (anonymous) @ main.js:577
                                      module.js:155 MMM-Traffic received a system notification: MODULE_DOM_CREATED
                                      module.js:155 clock received a system notification: MODULE_DOM_CREATED
                                      MMM-NOAA.js:344 Uncaught (in promise) TypeError: Cannot read property '0' of undefined
                                          at new Promise ()
                                          at Array.forEach ()
                                          at loader.js:40
                                      getDom @ MMM-NOAA.js:344
                                      Promise @ main.js:110
                                      updateDom @ main.js:109
                                      modules.forEach.module @ main.js:53
                                      Promise.then (async)
                                      createDomObjects @ main.js:62
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      init @ main.js:450
                                      undefined.png:1 GET http://192.168.1.243:8080/modules/MMM-NOAA/images/undefined.png 404 (Not Found)
                                      Image (async)
                                      getDom @ MMM-NOAA.js:293
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      load (async)
                                      init @ main.js:450
                                      MMM-Traffic.js:273 received TRAFFIC_COMMUTE
                                      • T
                                        TokTias
                                        Hi !
                                        I am really gloing bananas here. I got several other MMM-modules running in my Ubuntu machine, but MMM-NOAA just won’t start. I get, depending on how I start MM :
                                        node serveronly
                                        Starting MagicMirror: v2.3.1
                                        Loading config ...
                                        Loading module helpers ...
                                        WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                                        [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                                        Or
                                        npm start
                                        > magicmirror@2.3.1 start /home/ranix/MagicMirror
                                        > sh run-start.sh
                                        npm ERR! Linux 4.13.0-43-generic
                                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                        npm ERR! node v4.2.6
                                        npm ERR! npm  v3.5.2
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                                        npm ERR! Exit status 1
                                        npm ERR!
                                        npm ERR! Failed at the magicmirror@2.3.1 start script 'sh run-start.sh'.
                                        npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                        npm ERR! not with npm itself.
                                        npm ERR!     sh run-start.sh
                                        npm ERR!     npm bugs magicmirror
                                        npm ERR! Or if that isn't available, you can get their info via:
                                        npm ERR!     npm owner ls magicmirror
                                        npm ERR!     /home/ranix/MagicMirror/npm-debug.log
                                        I did not get any issues when running npm install, and as mentioned above, no issues with other modules.
                                        npm run config:check
                                        runs ok and I even removed my MM-instalaltion, reinstalled it and I tried a minimal config.js file like this :
                                        var config = {
                                        	address: "0.0.0.0",
                                        	port: 8070,
                                        	ipWhitelist: [],
                                        	language: "en",
                                        	timeFormat: 24,
                                        	units: "metric",
                                        	    		module: 'MMM-NOAA',
                                        			position: 'top_center',
                                        			config:{
                                        				apiKey: '----',
                                        				airKey: '----',
                                        And it just shows the errors as listed above.
                                        Is there anyone who can help me figure out what’s going south here before I have to give up ?
                                        Cheers & TIA !
                                        /T
                                        Mykle1M cowboysdudeC 2 Replies Last reply
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @TokTias
                                          @toktias said in MMM-NOAA - Another Weather Module:
                                          This may or may not be related but your node seems like it could be updated.
                                          T 1 Reply Last reply
                                          • cowboysdudeC
                                            cowboysdude Module Developer @TokTias
                                            @toktias Sent you a PM…
                                            In reality all mirrors are different and from time to time these things happen :)
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 34
                                            • 35
                                            • 20 / 35
