    690 Posts 77 Posters 2.9m Views 70 Watching
      Peter @cowboysdude
      @cowboysdude yes; there are not going to be any updates for version 1?
      Peter
        barnosch
        Same for me.
        I will stay with V1, since the new one is too fancy (and way to big) for me.
        Hope it will not getting corrupted by any changes with the new versions.
        • yawnsY Offline
          yawns Moderator
          Ideal would be to use the same core and develope different templates which could be chosen via config.
          • cowboysdudeC Offline
            cowboysdude Module Developer @yawns
            @yawns said in MMM-NOAA - Another Weather Module:
            You would think that wouldn’t you? LOL
              This is, by far, my favorite weather module, V1 and V2. And like everyone else, I have my own likes and dislikes. But rather than trouble @cowboysdude and his vision of what he wants the module to be, I made my own adjustments via css. With 76.6k views, and 390 posts in this topic alone, I can’t even imagine trying to satisfy everyone’s requests.
              Forrest Gump: “That’s all I have to say about that.”
                soshea1
                Hey there,
                Im hoping that someone can help me out with an error on this module. I am a complete newbie to this, so please bare with me.
                I have loaded the MMM-NOA module onto the config script, created the API key and selected the PWS on wundermap. However when i load up Magic Mirror- The module displays 'Undefined and NAN with no information loaded. It seems like it is just not pulling the info from the PWS correctly.
                I followed the instructions correctly, but dont seem to be able to fix this.
                Thank you
                  Mykle1 Project Sponsor Module Developer @soshea1
                  @soshea1
                  Did you try another PWS? They can fail. Also, post your config entry for NOAA here (in a code block) so we can have a look at it.
                    soshea1 @Mykle1
                    @Mykle1
                    Yes i tried using multiple different PWS codes, and still none of them display.
                    Ill try upload a picture in a separate reply of what displays.
                    Thanks for any help
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	                      // - "localhost", "127.", "::1" to listen on loopback interface
                    	port: 8080,
                    	ipWhitelist: ["127.0.0.1", "::ffff:127", "::1"], // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.****** :
        // ["127.0.0.1", "::ffff:127", "::1", "::ffff:192."],
        // or IPv4 range of 192. --> 192.1 use CIDR format :
        // ["127.0.0.1", "::ffff:127.", "::1", "::ffff:192/28"],
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "Canada Holidays",
                    						symbol: "calendar-check-o ",
                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics"
                    			module: "compliments",
                    			position: "lower_third"
                    			disabled: true,
                    			module: "currentweather",
                    				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                    			disabled: true,
                    			module: "weatherforecast",
                    			header: "Weather Forecast",
                    				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                    				showSourceTitle: true,
                    				showPublishDate: true
                    			disabled: false,
                    			module: 'MMM-NOAA',
                    			apiKey: "f78fa7e86*****",
                    			useAir: false,
                    			psw1: "IONTARIO1060",
                    			lat: "43.177",
                    			long: "-79.800",
                    • yawnsY Offline
                      yawns Moderator
                      It is pws1, not psw1
                      And according to the readme you don’t need lat and long
                        soshea1
                        @yawns
                        Thank you so much!. Such a small detail caused me hours of pain!
                        I must of looked at that config 100 times and didnt spot that!
                        • 38
                        • 39
                        • 40
                        • 41
                        • 42
                        • 68
                        • 69
                        • 40 / 69
