    690 Posts 77 Posters 2.9m Views 70 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @Peter
      @Peter said in MMM-NOAA - Another Weather Module:
      I am using NOAA version 1 because I like this more than version 2.
      Is there any problem going to be in the future with version 1?
      Peter
      Not sure what you mean. Do you mean you’d like to see future versions based on V1?
        Peter @cowboysdude
        @cowboysdude yes; there are not going to be any updates for version 1?
        Peter
          barnosch
          Same for me.
          I will stay with V1, since the new one is too fancy (and way to big) for me.
          Hope it will not getting corrupted by any changes with the new versions.
          • yawnsY Offline
            yawns Moderator
            Ideal would be to use the same core and develope different templates which could be chosen via config.
              cowboysdude Module Developer @yawns
              @yawns said in MMM-NOAA - Another Weather Module:
              You would think that wouldn’t you? LOL
                This is, by far, my favorite weather module, V1 and V2. And like everyone else, I have my own likes and dislikes. But rather than trouble @cowboysdude and his vision of what he wants the module to be, I made my own adjustments via css. With 76.6k views, and 390 posts in this topic alone, I can’t even imagine trying to satisfy everyone’s requests.
                Forrest Gump: “That’s all I have to say about that.”
                  soshea1
                  Hey there,
                  Im hoping that someone can help me out with an error on this module. I am a complete newbie to this, so please bare with me.
                  I have loaded the MMM-NOA module onto the config script, created the API key and selected the PWS on wundermap. However when i load up Magic Mirror- The module displays 'Undefined and NAN with no information loaded. It seems like it is just not pulling the info from the PWS correctly.
                  I followed the instructions correctly, but dont seem to be able to fix this.
                  Thank you
                    Mykle1 Project Sponsor Module Developer @soshea1
                    @soshea1
                    Did you try another PWS? They can fail. Also, post your config entry for NOAA here (in a code block) so we can have a look at it.
                      soshea1 @Mykle1
                      @Mykle1
                      Yes i tried using multiple different PWS codes, and still none of them display.
                      Ill try upload a picture in a separate reply of what displays.
                      Thanks for any help
                      /* Magic Mirror Config Sample
                       * MIT Licensed.
                      var config = {
                      	                      // - "localhost", "127.", "::1" to listen on loopback interface
                      	port: 8080,
                      	ipWhitelist: ["127.0.0.1", "::ffff:127", "::1"], // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.****** :
        // ["127.0.0.1", "::ffff:127", "::1", "::ffff:192."],
        // or IPv4 range of 192. --> 192.1 use CIDR format :
        // ["127.0.0.1", "::ffff:127.", "::1", "::ffff:192/28"],
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_left"
                      			header: "Canada Holidays",
                      						symbol: "calendar-check-o ",
                      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics"
                      			module: "compliments",
                      			position: "lower_third"
                      			disabled: true,
                      			module: "currentweather",
                      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                      			disabled: true,
                      			module: "weatherforecast",
                      			header: "Weather Forecast",
                      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                      			module: "newsfeed",
                      			position: "bottom_bar",
                      				feeds: [
                      						title: "New York Times",
                      				showSourceTitle: true,
                      				showPublishDate: true
                      			disabled: false,
                      			module: 'MMM-NOAA',
                      			apiKey: "f78fa7e86*****",
                      			useAir: false,
                      			psw1: "IONTARIO1060",
                      			lat: "43.177",
                      			long: "-79.800",
                      • yawnsY Offline
                        yawns Moderator
                        It is pws1, not psw1
                        And according to the readme you don’t need lat and long
                        • 37
                        • 38
                        • 39
                        • 40
                        • 41
                        • 68
                        • 69
                        • 39 / 69
