      Peter @cowboysdude
      @cowboysdude yes; there are not going to be any updates for version 1?
      Peter
        barnosch
        Same for me.
        I will stay with V1, since the new one is too fancy (and way to big) for me.
        Hope it will not getting corrupted by any changes with the new versions.
        • Y
          yawns Moderator
          Ideal would be to use the same core and develope different templates which could be chosen via config.
          Reply Quote 2
          • cowboysdudeC
            cowboysdude Module Developer @yawns
            @yawns said in MMM-NOAA - Another Weather Module:
            You would think that wouldn’t you? LOL
            • Mykle1M
              This is, by far, my favorite weather module, V1 and V2. And like everyone else, I have my own likes and dislikes. But rather than trouble @cowboysdude and his vision of what he wants the module to be, I made my own adjustments via css. With 76.6k views, and 390 posts in this topic alone, I can’t even imagine trying to satisfy everyone’s requests.
              Forrest Gump: “That’s all I have to say about that.”
              Reply Quote 2
                soshea1
                Hey there,
                Im hoping that someone can help me out with an error on this module. I am a complete newbie to this, so please bare with me.
                I have loaded the MMM-NOA module onto the config script, created the API key and selected the PWS on wundermap. However when i load up Magic Mirror- The module displays 'Undefined and NAN with no information loaded. It seems like it is just not pulling the info from the PWS correctly.
                I followed the instructions correctly, but dont seem to be able to fix this.
                Thank you
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @soshea1
                  @soshea1
                  Did you try another PWS? They can fail. Also, post your config entry for NOAA here (in a code block) so we can have a look at it.
                    soshea1 @Mykle1
                    @Mykle1
                    Yes i tried using multiple different PWS codes, and still none of them display.
                    Ill try upload a picture in a separate reply of what displays.
                    Thanks for any help
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	                      // - "localhost", "127.", "::1" to listen on loopback interface
                    	port: 8080,
                    	ipWhitelist: ["127.0.0.1", "::ffff:127", "::1"], // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.****** :
        // ["127.0.0.1", "::ffff:127", "::1", "::ffff:192."],
        // or IPv4 range of 192. --> 192.1 use CIDR format :
        // ["127.0.0.1", "::ffff:127.", "::1", "::ffff:192/28"],
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "Canada Holidays",
                    						symbol: "calendar-check-o ",
                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics"
                    			module: "compliments",
                    			position: "lower_third"
                    			disabled: true,
                    			module: "currentweather",
                    				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                    			disabled: true,
                    			module: "weatherforecast",
                    			header: "Weather Forecast",
                    				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                    				showSourceTitle: true,
                    				showPublishDate: true
                    			disabled: false,
                    			module: 'MMM-NOAA',
                    			apiKey: "f78fa7e86*****",
                    			useAir: false,
                    			psw1: "IONTARIO1060",
                    			lat: "43.177",
                    			long: "-79.800",
                    • Y
                      yawns Moderator
                      It is pws1, not psw1
                      And according to the readme you don’t need lat and long
                      Reply Quote 2
                        soshea1
                        @yawns
                        Thank you so much!. Such a small detail caused me hours of pain!
                        I must of looked at that config 100 times and didnt spot that!
                        • Mykle1M
                          @soshea1
                          @yawns is KING! :-)
                          • cowboysdudeC
                            Folks NOAA 3 is WELL under development BUT with Wunderground going belly up on users I’ll have to reconfigure a lot of stuff… at this point Wunderground will no longer be used to get the weather for NOAA, NOAA2 or 3.
                            IF you’re having issues with either NOAA or NOAA2 please post them here …
                            http://108.29.66.102:443/
                            • cowboysdudeC
                              I’ll be reconfiguring NOAA2 this evening… will let you know.
                              • Mykle1M
                                @cowboysdude
                                Hurry up. I don’t have all night. ;-)
                                • cowboysdudeC
                                  Description:
                                  New Service Provider…since wunderground is NO longer offering free api keys…
                                  SEE README …on Github.
                                  Version 2.1.7
                                  Download:
                                  [card:cowboysdude/MMM-NOAA]
                                  N 1 Reply Last reply
                                  Reply Quote 2
                                  • G
                                    ganther
                                    Hi Cowboydude,
                                    after the last MMM-NOAA update it’s not possible to show MMM-NOAA and MMM-CalendarExt at the same time.
                                    If both modules are activated in config MMM-CalendarExt will not be shown.
                                    If I comment out MMM-NOAA everything works fine.
                                    I deleted MMM-NOAA module and made a clean install but no effect.
                                    Any ideas?
                                    Thank you.
                                    Sandy
                                    G 1 Reply Last reply
                                    • G
                                      ganther @ganther
                                      I forgot:
                                      No errors shown at pm2 log mm or npm start dev
                                        core
                                        Hi everyone,
                                        I have problems with regard to the latest version of this module.
                                        I updated to the new version, including the updated weather service provider and since then, two of my other modules (MMM-Fuel and MMM-Sonos) are not working any more. The position (bottom_left) is just blank now, wheras the MMM-NOAA (position: top_right) module works. Even a re-install of MMM-NOAA and reboot of my Rpi3 did not fix this issue.
                                        When I delete the module from my config, all other modules are working again, so I can clearly assign the problem to the MMM-NOAA module.
                                        Until now, I don´ t use this module and all modules are working smoothly. However, I like this module so hopefully, the problems will be fixed soon. Any news about it?
                                        Thanks!
                                          redink
                                          I am also having problems with MMM-NOAA coming up, as well as MMM-CalendarExt. The reason I am posting this here is because i see an error in the browser console related to NOAA. I am posting the log below. mm-error-0.log file doesn’t show any errors.
                                          (index):41 GET http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js 404 (Not Found)
                                          (index):1 Refused to execute script from 'http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
                                          main.js:447 Initializing MagicMirror.
                                          translator.js:201 Loading core translation file: translations/en.json
                                          translator.js:224 Loading core translation fallback file: translations/en.json
                                          loader.js:182 Load script: modules/MMM-CalendarExt//MMM-CalendarExt.js
                                          module.js:476 Module registered: MMM-CalendarExt
                                          loader.js:152 Bootstrapping module: MMM-CalendarExt
                                          loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                                          loader.js:182 Load script: modules/MMM-CalendarExt/Configs.js
                                          loader.js:182 Load script: modules/MMM-CalendarExt/Render.js
                                          loader.js:157 Scripts loaded for: MMM-CalendarExt
                                          loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
                                          loader.js:197 Load stylesheet: modules/MMM-CalendarExt/custom.css
                                          loader.js:197 Load stylesheet: modules/MMM-CalendarExt/preset.css
                                          loader.js:159 Styles loaded for: MMM-CalendarExt
                                          loader.js:161 Translations loaded for: MMM-CalendarExt
                                          loader.js:182 Load script: modules/MMM-NOAA//MMM-NOAA.js
                                          module.js:476 Module registered: MMM-NOAA
                                          loader.js:152 Bootstrapping module: MMM-NOAA
                                          loader.js:237 File already loaded: moment.js
                                          loader.js:157 Scripts loaded for: MMM-NOAA
                                          loader.js:197 Load stylesheet: modules/MMM-NOAA/MMM-NOAA.css
                                          loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                                          loader.js:159 Styles loaded for: MMM-NOAA
                                          translator.js:174 MMM-NOAA - Load translation fallback: translations/en.json
                                          loader.js:161 Translations loaded for: MMM-NOAA
                                          loader.js:182 Load script: modules/MMM-Traffic//MMM-Traffic.js
                                          module.js:476 Module registered: MMM-Traffic
                                          loader.js:152 Bootstrapping module: MMM-Traffic
                                          loader.js:157 Scripts loaded for: MMM-Traffic
                                          loader.js:197 Load stylesheet: modules/MMM-Traffic/traffic.css
                                          loader.js:237 File already loaded: font-awesome.css
                                          loader.js:159 Styles loaded for: MMM-Traffic
                                          loader.js:161 Translations loaded for: MMM-Traffic
                                          loader.js:182 Load script: modules/default/alert//alert.js
                                          module.js:476 Module registered: alert
                                          loader.js:152 Bootstrapping module: alert
                                          loader.js:182 Load script: modules/default/alert/classie.js
                                          loader.js:182 Load script: modules/default/alert/modernizr.custom.js
                                          loader.js:182 Load script: modules/default/alert/notificationFx.js
                                          loader.js:157 Scripts loaded for: alert
                                          loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
                                          loader.js:159 Styles loaded for: alert
                                          translator.js:174 alert - Load translation fallback: translations/en.json
                                          loader.js:161 Translations loaded for: alert
                                          loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
                                          module.js:476 Module registered: updatenotification
                                          loader.js:152 Bootstrapping module: updatenotification
                                          loader.js:157 Scripts loaded for: updatenotification
                                          loader.js:159 Styles loaded for: updatenotification
                                          loader.js:161 Translations loaded for: updatenotification
                                          loader.js:182 Load script: modules/default/clock//clock.js
                                          module.js:476 Module registered: clock
                                          loader.js:152 Bootstrapping module: clock
                                          loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                                          loader.js:157 Scripts loaded for: clock
                                          loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
                                          loader.js:159 Styles loaded for: clock
                                          loader.js:161 Translations loaded for: clock
                                          loader.js:197 Load stylesheet: css/custom.css
                                          MMM-NOAA.js:89 Starting module: MMM-NOAA
                                          MMM-Traffic.js:42 Starting module: MMM-Traffic
                                          alert.js:151 Starting module: alert
                                          updatenotification.js:10 Start updatenotification
                                          clock.js:40 Starting module: clock
                                          main.js:465 All modules started!
                                          module.js:155 MMM-Traffic received a system notification: ALL_MODULES_STARTED
                                          module.js:155 clock received a system notification: ALL_MODULES_STARTED
                                          TypeError: Cannot read property '0' of undefined
                                              at Class.getDom (MMM-NOAA.js:344)
                                              at Promise (main.js:110)
                                              at new Promise ()
                                              at updateDom (main.js:109)
                                              at modules.forEach.module (main.js:53)
                                              at Array.forEach ()
                                              at createDomObjects (main.js:24)
                                              at Object.modulesStarted (main.js:468)
                                              at startModules (loader.js:59)
                                              at loader.js:40
                                          Promise.catch (async)
                                          modules.forEach.module @ main.js:57
                                          createDomObjects @ main.js:24
                                          modulesStarted @ main.js:468
                                          startModules @ loader.js:59
                                          (anonymous) @ loader.js:40
                                          stylesheet.onload @ loader.js:203
                                          load (async)
                                          loadFile @ loader.js:202
                                          loadNextModule @ loader.js:38
                                          (anonymous) @ loader.js:31
                                          (anonymous) @ loader.js:126
                                          (anonymous) @ loader.js:163
                                          loadTranslations @ module.js:333
                                          (anonymous) @ loader.js:160
                                          loadNextDependency @ module.js:298
                                          (anonymous) @ module.js:295
                                          load (async)
                                          loadFile @ loader.js:261
                                          loadNextDependency @ module.js:293
                                          loadDependencies @ module.js:302
                                          loadStyles @ module.js:268
                                          (anonymous) @ loader.js:158
                                          script.onload @ loader.js:187
                                          load (async)
                                          loadFile @ loader.js:186
                                          loadFile @ loader.js:254
                                          loadFile @ loader.js:238
                                          loadScripts @ module.js:277
                                          bootstrapModule @ loader.js:156
                                          afterLoad @ loader.js:125
                                          (anonymous) @ loader.js:138
                                          load (async)
                                          loadModule @ loader.js:136
                                          loadNextModule @ loader.js:29
                                          load (async)
                                          (anonymous) @ translator.js:185
                                          xhr.onreadystatechange @ translator.js:22
                                          XMLHttpRequest.send (async)
                                          loadJSON @ translator.js:25
                                          load @ translator.js:179
                                          loadTranslations @ module.js:330
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          loadModules @ loader.js:46
                                          loadModules @ loader.js:223
                                          init @ main.js:450
                                          (anonymous) @ main.js:577
                                          module.js:155 MMM-Traffic received a system notification: MODULE_DOM_CREATED
                                          module.js:155 clock received a system notification: MODULE_DOM_CREATED
                                          MMM-NOAA.js:344 Uncaught (in promise) TypeError: Cannot read property '0' of undefined
                                              at new Promise ()
                                              at Array.forEach ()
                                              at loader.js:40
                                          getDom @ MMM-NOAA.js:344
                                          Promise @ main.js:110
                                          updateDom @ main.js:109
                                          modules.forEach.module @ main.js:53
                                          Promise.then (async)
                                          createDomObjects @ main.js:62
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          init @ main.js:450
                                          undefined.png:1 GET http://192.168.1.243:8080/modules/MMM-NOAA/images/undefined.png 404 (Not Found)
                                          Image (async)
                                          getDom @ MMM-NOAA.js:293
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          load (async)
                                          init @ main.js:450
                                          MMM-Traffic.js:273 received TRAFFIC_COMMUTE
                                          • T
                                            TokTias
                                            Hi !
                                            I am really gloing bananas here. I got several other MMM-modules running in my Ubuntu machine, but MMM-NOAA just won’t start. I get, depending on how I start MM :
                                            node serveronly
                                            Starting MagicMirror: v2.3.1
                                            Loading config ...
                                            Loading module helpers ...
                                            WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                                            [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                                            Or
                                            npm start
                                            > magicmirror@2.3.1 start /home/ranix/MagicMirror
                                            > sh run-start.sh
                                            npm ERR! Linux 4.13.0-43-generic
                                            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                            npm ERR! node v4.2.6
                                            npm ERR! npm  v3.5.2
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                                            npm ERR! Exit status 1
                                            npm ERR!
                                            npm ERR! Failed at the magicmirror@2.3.1 start script 'sh run-start.sh'.
                                            npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                            npm ERR! not with npm itself.
                                            npm ERR!     sh run-start.sh
                                            npm ERR!     npm bugs magicmirror
                                            npm ERR! Or if that isn't available, you can get their info via:
                                            npm ERR!     npm owner ls magicmirror
                                            npm ERR!     /home/ranix/MagicMirror/npm-debug.log
                                            I did not get any issues when running npm install, and as mentioned above, no issues with other modules.
                                            npm run config:check
                                            runs ok and I even removed my MM-instalaltion, reinstalled it and I tried a minimal config.js file like this :
                                            var config = {
                                            	address: "0.0.0.0",
                                            	port: 8070,
                                            	ipWhitelist: [],
                                            	language: "en",
                                            	timeFormat: 24,
                                            	units: "metric",
                                            	    		module: 'MMM-NOAA',
                                            			position: 'top_center',
                                            			config:{
                                            				apiKey: '----',
                                            				airKey: '----',
                                            And it just shows the errors as listed above.
                                            Is there anyone who can help me figure out what’s going south here before I have to give up ?
                                            Cheers & TIA !
                                            /T
                                            Mykle1M cowboysdudeC 2 Replies Last reply
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 34
                                            • 35
                                            • 20 / 35
