      soshea1
      @yawns
      Thank you so much!. Such a small detail caused me hours of pain!
      I must of looked at that config 100 times and didnt spot that!
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @soshea1
        @soshea1
        @yawns is KING! :-)
        • cowboysdudeC
          Folks NOAA 3 is WELL under development BUT with Wunderground going belly up on users I’ll have to reconfigure a lot of stuff… at this point Wunderground will no longer be used to get the weather for NOAA, NOAA2 or 3.
          IF you’re having issues with either NOAA or NOAA2 please post them here …
          http://108.29.66.102:443/
          • cowboysdudeC
            I’ll be reconfiguring NOAA2 this evening… will let you know.
            • Mykle1M
              @cowboysdude
              Hurry up. I don’t have all night. ;-)
              • cowboysdudeC
                Description:
                New Service Provider…since wunderground is NO longer offering free api keys…
                SEE README …on Github.
                Version 2.1.7
                Download:
                [card:cowboysdude/MMM-NOAA]
                N 1 Reply Last reply Reply Quote 2
                • G
                  ganther
                  Hi Cowboydude,
                  after the last MMM-NOAA update it’s not possible to show MMM-NOAA and MMM-CalendarExt at the same time.
                  If both modules are activated in config MMM-CalendarExt will not be shown.
                  If I comment out MMM-NOAA everything works fine.
                  I deleted MMM-NOAA module and made a clean install but no effect.
                  Any ideas?
                  Thank you.
                  Sandy
                  • G
                    ganther @ganther
                    I forgot:
                    No errors shown at pm2 log mm or npm start dev
                      core
                      Hi everyone,
                      I have problems with regard to the latest version of this module.
                      I updated to the new version, including the updated weather service provider and since then, two of my other modules (MMM-Fuel and MMM-Sonos) are not working any more. The position (bottom_left) is just blank now, wheras the MMM-NOAA (position: top_right) module works. Even a re-install of MMM-NOAA and reboot of my Rpi3 did not fix this issue.
                      When I delete the module from my config, all other modules are working again, so I can clearly assign the problem to the MMM-NOAA module.
                      Until now, I don´ t use this module and all modules are working smoothly. However, I like this module so hopefully, the problems will be fixed soon. Any news about it?
                      Thanks!
                        redink
                        I am also having problems with MMM-NOAA coming up, as well as MMM-CalendarExt. The reason I am posting this here is because i see an error in the browser console related to NOAA. I am posting the log below. mm-error-0.log file doesn’t show any errors.
                        (index):41 GET http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js 404 (Not Found)
                        (index):1 Refused to execute script from 'http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
                        main.js:447 Initializing MagicMirror.
                        translator.js:201 Loading core translation file: translations/en.json
                        translator.js:224 Loading core translation fallback file: translations/en.json
                        loader.js:182 Load script: modules/MMM-CalendarExt//MMM-CalendarExt.js
                        module.js:476 Module registered: MMM-CalendarExt
                        loader.js:152 Bootstrapping module: MMM-CalendarExt
                        loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                        loader.js:182 Load script: modules/MMM-CalendarExt/Configs.js
                        loader.js:182 Load script: modules/MMM-CalendarExt/Render.js
                        loader.js:157 Scripts loaded for: MMM-CalendarExt
                        loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
                        loader.js:197 Load stylesheet: modules/MMM-CalendarExt/custom.css
                        loader.js:197 Load stylesheet: modules/MMM-CalendarExt/preset.css
                        loader.js:159 Styles loaded for: MMM-CalendarExt
                        loader.js:161 Translations loaded for: MMM-CalendarExt
                        loader.js:182 Load script: modules/MMM-NOAA//MMM-NOAA.js
                        module.js:476 Module registered: MMM-NOAA
                        loader.js:152 Bootstrapping module: MMM-NOAA
                        loader.js:237 File already loaded: moment.js
                        loader.js:157 Scripts loaded for: MMM-NOAA
                        loader.js:197 Load stylesheet: modules/MMM-NOAA/MMM-NOAA.css
                        loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                        loader.js:159 Styles loaded for: MMM-NOAA
                        translator.js:174 MMM-NOAA - Load translation fallback: translations/en.json
                        loader.js:161 Translations loaded for: MMM-NOAA
                        loader.js:182 Load script: modules/MMM-Traffic//MMM-Traffic.js
                        module.js:476 Module registered: MMM-Traffic
                        loader.js:152 Bootstrapping module: MMM-Traffic
                        loader.js:157 Scripts loaded for: MMM-Traffic
                        loader.js:197 Load stylesheet: modules/MMM-Traffic/traffic.css
                        loader.js:237 File already loaded: font-awesome.css
                        loader.js:159 Styles loaded for: MMM-Traffic
                        loader.js:161 Translations loaded for: MMM-Traffic
                        loader.js:182 Load script: modules/default/alert//alert.js
                        module.js:476 Module registered: alert
                        loader.js:152 Bootstrapping module: alert
                        loader.js:182 Load script: modules/default/alert/classie.js
                        loader.js:182 Load script: modules/default/alert/modernizr.custom.js
                        loader.js:182 Load script: modules/default/alert/notificationFx.js
                        loader.js:157 Scripts loaded for: alert
                        loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
                        loader.js:159 Styles loaded for: alert
                        translator.js:174 alert - Load translation fallback: translations/en.json
                        loader.js:161 Translations loaded for: alert
                        loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
                        module.js:476 Module registered: updatenotification
                        loader.js:152 Bootstrapping module: updatenotification
                        loader.js:157 Scripts loaded for: updatenotification
                        loader.js:159 Styles loaded for: updatenotification
                        loader.js:161 Translations loaded for: updatenotification
                        loader.js:182 Load script: modules/default/clock//clock.js
                        module.js:476 Module registered: clock
                        loader.js:152 Bootstrapping module: clock
                        loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                        loader.js:157 Scripts loaded for: clock
                        loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
                        loader.js:159 Styles loaded for: clock
                        loader.js:161 Translations loaded for: clock
                        loader.js:197 Load stylesheet: css/custom.css
                        MMM-NOAA.js:89 Starting module: MMM-NOAA
                        MMM-Traffic.js:42 Starting module: MMM-Traffic
                        alert.js:151 Starting module: alert
                        updatenotification.js:10 Start updatenotification
                        clock.js:40 Starting module: clock
                        main.js:465 All modules started!
                        module.js:155 MMM-Traffic received a system notification: ALL_MODULES_STARTED
                        module.js:155 clock received a system notification: ALL_MODULES_STARTED
                        TypeError: Cannot read property '0' of undefined
                            at Class.getDom (MMM-NOAA.js:344)
                            at Promise (main.js:110)
                            at new Promise ()
                            at updateDom (main.js:109)
                            at modules.forEach.module (main.js:53)
                            at Array.forEach ()
                            at createDomObjects (main.js:24)
                            at Object.modulesStarted (main.js:468)
                            at startModules (loader.js:59)
                            at loader.js:40
                        Promise.catch (async)
                        modules.forEach.module @ main.js:57
                        createDomObjects @ main.js:24
                        modulesStarted @ main.js:468
                        startModules @ loader.js:59
                        (anonymous) @ loader.js:40
                        stylesheet.onload @ loader.js:203
                        load (async)
                        loadFile @ loader.js:202
                        loadNextModule @ loader.js:38
                        (anonymous) @ loader.js:31
                        (anonymous) @ loader.js:126
                        (anonymous) @ loader.js:163
                        loadTranslations @ module.js:333
                        (anonymous) @ loader.js:160
                        loadNextDependency @ module.js:298
                        (anonymous) @ module.js:295
                        load (async)
                        loadFile @ loader.js:261
                        loadNextDependency @ module.js:293
                        loadDependencies @ module.js:302
                        loadStyles @ module.js:268
                        (anonymous) @ loader.js:158
                        script.onload @ loader.js:187
                        load (async)
                        loadFile @ loader.js:186
                        loadFile @ loader.js:254
                        loadFile @ loader.js:238
                        loadScripts @ module.js:277
                        bootstrapModule @ loader.js:156
                        afterLoad @ loader.js:125
                        (anonymous) @ loader.js:138
                        load (async)
                        loadModule @ loader.js:136
                        loadNextModule @ loader.js:29
                        load (async)
                        (anonymous) @ translator.js:185
                        xhr.onreadystatechange @ translator.js:22
                        XMLHttpRequest.send (async)
                        loadJSON @ translator.js:25
                        load @ translator.js:179
                        loadTranslations @ module.js:330
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        loadModules @ loader.js:46
                        loadModules @ loader.js:223
                        init @ main.js:450
                        (anonymous) @ main.js:577
                        module.js:155 MMM-Traffic received a system notification: MODULE_DOM_CREATED
                        module.js:155 clock received a system notification: MODULE_DOM_CREATED
                        MMM-NOAA.js:344 Uncaught (in promise) TypeError: Cannot read property '0' of undefined
                            at new Promise ()
                            at Array.forEach ()
                            at loader.js:40
                        getDom @ MMM-NOAA.js:344
                        Promise @ main.js:110
                        updateDom @ main.js:109
                        modules.forEach.module @ main.js:53
                        Promise.then (async)
                        createDomObjects @ main.js:62
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        init @ main.js:450
                        undefined.png:1 GET http://192.168.1.243:8080/modules/MMM-NOAA/images/undefined.png 404 (Not Found)
                        Image (async)
                        getDom @ MMM-NOAA.js:293
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        load (async)
                        init @ main.js:450
                        MMM-Traffic.js:273 received TRAFFIC_COMMUTE
                        • T
                          TokTias
                          Hi !
                          I am really gloing bananas here. I got several other MMM-modules running in my Ubuntu machine, but MMM-NOAA just won’t start. I get, depending on how I start MM :
                          node serveronly
                          Starting MagicMirror: v2.3.1
                          Loading config ...
                          Loading module helpers ...
                          WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                          [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                          Or
                          npm start
                          > magicmirror@2.3.1 start /home/ranix/MagicMirror
                          > sh run-start.sh
                          npm ERR! Linux 4.13.0-43-generic
                          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                          npm ERR! node v4.2.6
                          npm ERR! npm  v3.5.2
                          npm ERR! code ELIFECYCLE
                          npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the magicmirror@2.3.1 start script 'sh run-start.sh'.
                          npm ERR! If you do, this is most likely a problem with the magicmirror package,
                          npm ERR! not with npm itself.
                          npm ERR!     sh run-start.sh
                          npm ERR!     npm bugs magicmirror
                          npm ERR! Or if that isn't available, you can get their info via:
                          npm ERR!     npm owner ls magicmirror
                          npm ERR!     /home/ranix/MagicMirror/npm-debug.log
                          I did not get any issues when running npm install, and as mentioned above, no issues with other modules.
                          npm run config:check
                          runs ok and I even removed my MM-instalaltion, reinstalled it and I tried a minimal config.js file like this :
                          var config = {
                          	address: "0.0.0.0",
                          	port: 8070,
                          	ipWhitelist: [],
                          	language: "en",
                          	timeFormat: 24,
                          	units: "metric",
                          	    		module: 'MMM-NOAA',
                          			position: 'top_center',
                          			config:{
                          				apiKey: '----',
                          				airKey: '----',
                          And it just shows the errors as listed above.
                          Is there anyone who can help me figure out what’s going south here before I have to give up ?
                          Cheers & TIA !
                          /T
                          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @TokTias
                            @toktias said in MMM-NOAA - Another Weather Module:
                            This may or may not be related but your node seems like it could be updated.
                            • cowboysdudeC
                              cowboysdude Module Developer @TokTias
                              @toktias Sent you a PM…
                              In reality all mirrors are different and from time to time these things happen :)
                              • T
                                TokTias @Mykle1
                                @mykle1 Thanks, but as far as I can see, I got the latest version; “4.2.6~dfsg-1ubuntu4.1”. Or am I missing some new/hidden version out there ? :)
                                Cheers !
                                /T
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @TokTias
                                  @toktias you are running node v4.2.6 the current version is v10.4.1 https://nodejs.org/en/
                                  T cowboysdudeC 2 Replies Last reply Reply Quote 3
                                  • T
                                    TokTias @strawberry 3.141
                                    @strawberry-3-141
                                    Thanks for pointing me in the correct direction !
                                    My Linux-box was pointing to ppa:chris-lea/node.js as the source for Node.js, I removed that (reference and unistalled it) and installed per the intrucitons you linked to in your post above a voilá, MMM-NOAA works perfect now !
                                    Thanks a lot & Cheers !
                                    /T
                                    • cowboysdudeC
                                      cowboysdude Module Developer @strawberry 3.141
                                      @strawberry-3-141 That’ll cause you some issues…
                                      • Mykle1M
                                        Uhh . . .
                                        • Mykle1M
                                          @cowboysdude
                                          106.2k views!
                                          There are so many things I want to say about that but I think I’ll just say “Well deserved and congrats!” :-)
                                            jhujube
                                            May be a stupid question, but with the new provider (weatherbit.io), where do i set my location? if this was set when i signed in for my apiKey, i didn’t enter any information to locate me…
                                            Thanks in advance.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 34
                                            • 35
                                            • 21 / 35
