    690 Posts 77 Posters 3.3m Views 70 Watching
      soshea1
      Hey there,
      Im hoping that someone can help me out with an error on this module. I am a complete newbie to this, so please bare with me.
      I have loaded the MMM-NOA module onto the config script, created the API key and selected the PWS on wundermap. However when i load up Magic Mirror- The module displays 'Undefined and NAN with no information loaded. It seems like it is just not pulling the info from the PWS correctly.
      I followed the instructions correctly, but dont seem to be able to fix this.
      Thank you
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @soshea1
        @soshea1
        Did you try another PWS? They can fail. Also, post your config entry for NOAA here (in a code block) so we can have a look at it.
          soshea1 @Mykle1
          @Mykle1
          Yes i tried using multiple different PWS codes, and still none of them display.
          Ill try upload a picture in a separate reply of what displays.
          Thanks for any help
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	                      // - "localhost", "127.", "::1" to listen on loopback interface
          	port: 8080,
          	ipWhitelist: ["127.0.0.1", "::ffff:127", "::1"], // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.****** :
        // ["127.0.0.1", "::ffff:127", "::1", "::ffff:192."],
        // or IPv4 range of 192. --> 192.1 use CIDR format :
        // ["127.0.0.1", "::ffff:127.", "::1", "::ffff:192/28"],
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "Canada Holidays",
          						symbol: "calendar-check-o ",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics"
          			module: "compliments",
          			position: "lower_third"
          			disabled: true,
          			module: "currentweather",
          				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
          			disabled: true,
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "New York Times",
          				showSourceTitle: true,
          				showPublishDate: true
          			disabled: false,
          			module: 'MMM-NOAA',
          			apiKey: "f78fa7e86*****",
          			useAir: false,
          			psw1: "IONTARIO1060",
          			lat: "43.177",
          			long: "-79.800",
          • Y
            yawns Moderator
            It is pws1, not psw1
            And according to the readme you don’t need lat and long
            Reply Quote 2
              soshea1
              @yawns
              Thank you so much!. Such a small detail caused me hours of pain!
              I must of looked at that config 100 times and didnt spot that!
              • Mykle1M
                @soshea1
                @yawns is KING! :-)
                • cowboysdudeC
                  Folks NOAA 3 is WELL under development BUT with Wunderground going belly up on users I’ll have to reconfigure a lot of stuff… at this point Wunderground will no longer be used to get the weather for NOAA, NOAA2 or 3.
                  IF you’re having issues with either NOAA or NOAA2 please post them here …
                  http://108.29.66.102:443/
                  • cowboysdudeC
                    I’ll be reconfiguring NOAA2 this evening… will let you know.
                    • Mykle1M
                      @cowboysdude
                      Hurry up. I don’t have all night. ;-)
                      • cowboysdudeC
                        Description:
                        New Service Provider…since wunderground is NO longer offering free api keys…
                        SEE README …on Github.
                        Version 2.1.7
                        Download:
                        [card:cowboysdude/MMM-NOAA]
                        N 1 Reply Last reply
                        Reply Quote 2
                        • G
                          ganther
                          Hi Cowboydude,
                          after the last MMM-NOAA update it’s not possible to show MMM-NOAA and MMM-CalendarExt at the same time.
                          If both modules are activated in config MMM-CalendarExt will not be shown.
                          If I comment out MMM-NOAA everything works fine.
                          I deleted MMM-NOAA module and made a clean install but no effect.
                          Any ideas?
                          Thank you.
                          Sandy
                          G 1 Reply Last reply
                          • G
                            ganther @ganther
                            I forgot:
                            No errors shown at pm2 log mm or npm start dev
                              core
                              Hi everyone,
                              I have problems with regard to the latest version of this module.
                              I updated to the new version, including the updated weather service provider and since then, two of my other modules (MMM-Fuel and MMM-Sonos) are not working any more. The position (bottom_left) is just blank now, wheras the MMM-NOAA (position: top_right) module works. Even a re-install of MMM-NOAA and reboot of my Rpi3 did not fix this issue.
                              When I delete the module from my config, all other modules are working again, so I can clearly assign the problem to the MMM-NOAA module.
                              Until now, I don´ t use this module and all modules are working smoothly. However, I like this module so hopefully, the problems will be fixed soon. Any news about it?
                              Thanks!
                                redink
                                I am also having problems with MMM-NOAA coming up, as well as MMM-CalendarExt. The reason I am posting this here is because i see an error in the browser console related to NOAA. I am posting the log below. mm-error-0.log file doesn’t show any errors.
                                (index):41 GET http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js 404 (Not Found)
                                (index):1 Refused to execute script from 'http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
                                main.js:447 Initializing MagicMirror.
                                translator.js:201 Loading core translation file: translations/en.json
                                translator.js:224 Loading core translation fallback file: translations/en.json
                                loader.js:182 Load script: modules/MMM-CalendarExt//MMM-CalendarExt.js
                                module.js:476 Module registered: MMM-CalendarExt
                                loader.js:152 Bootstrapping module: MMM-CalendarExt
                                loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                                loader.js:182 Load script: modules/MMM-CalendarExt/Configs.js
                                loader.js:182 Load script: modules/MMM-CalendarExt/Render.js
                                loader.js:157 Scripts loaded for: MMM-CalendarExt
                                loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
                                loader.js:197 Load stylesheet: modules/MMM-CalendarExt/custom.css
                                loader.js:197 Load stylesheet: modules/MMM-CalendarExt/preset.css
                                loader.js:159 Styles loaded for: MMM-CalendarExt
                                loader.js:161 Translations loaded for: MMM-CalendarExt
                                loader.js:182 Load script: modules/MMM-NOAA//MMM-NOAA.js
                                module.js:476 Module registered: MMM-NOAA
                                loader.js:152 Bootstrapping module: MMM-NOAA
                                loader.js:237 File already loaded: moment.js
                                loader.js:157 Scripts loaded for: MMM-NOAA
                                loader.js:197 Load stylesheet: modules/MMM-NOAA/MMM-NOAA.css
                                loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                                loader.js:159 Styles loaded for: MMM-NOAA
                                translator.js:174 MMM-NOAA - Load translation fallback: translations/en.json
                                loader.js:161 Translations loaded for: MMM-NOAA
                                loader.js:182 Load script: modules/MMM-Traffic//MMM-Traffic.js
                                module.js:476 Module registered: MMM-Traffic
                                loader.js:152 Bootstrapping module: MMM-Traffic
                                loader.js:157 Scripts loaded for: MMM-Traffic
                                loader.js:197 Load stylesheet: modules/MMM-Traffic/traffic.css
                                loader.js:237 File already loaded: font-awesome.css
                                loader.js:159 Styles loaded for: MMM-Traffic
                                loader.js:161 Translations loaded for: MMM-Traffic
                                loader.js:182 Load script: modules/default/alert//alert.js
                                module.js:476 Module registered: alert
                                loader.js:152 Bootstrapping module: alert
                                loader.js:182 Load script: modules/default/alert/classie.js
                                loader.js:182 Load script: modules/default/alert/modernizr.custom.js
                                loader.js:182 Load script: modules/default/alert/notificationFx.js
                                loader.js:157 Scripts loaded for: alert
                                loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
                                loader.js:159 Styles loaded for: alert
                                translator.js:174 alert - Load translation fallback: translations/en.json
                                loader.js:161 Translations loaded for: alert
                                loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
                                module.js:476 Module registered: updatenotification
                                loader.js:152 Bootstrapping module: updatenotification
                                loader.js:157 Scripts loaded for: updatenotification
                                loader.js:159 Styles loaded for: updatenotification
                                loader.js:161 Translations loaded for: updatenotification
                                loader.js:182 Load script: modules/default/clock//clock.js
                                module.js:476 Module registered: clock
                                loader.js:152 Bootstrapping module: clock
                                loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                                loader.js:157 Scripts loaded for: clock
                                loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
                                loader.js:159 Styles loaded for: clock
                                loader.js:161 Translations loaded for: clock
                                loader.js:197 Load stylesheet: css/custom.css
                                MMM-NOAA.js:89 Starting module: MMM-NOAA
                                MMM-Traffic.js:42 Starting module: MMM-Traffic
                                alert.js:151 Starting module: alert
                                updatenotification.js:10 Start updatenotification
                                clock.js:40 Starting module: clock
                                main.js:465 All modules started!
                                module.js:155 MMM-Traffic received a system notification: ALL_MODULES_STARTED
                                module.js:155 clock received a system notification: ALL_MODULES_STARTED
                                TypeError: Cannot read property '0' of undefined
                                    at Class.getDom (MMM-NOAA.js:344)
                                    at Promise (main.js:110)
                                    at new Promise ()
                                    at updateDom (main.js:109)
                                    at modules.forEach.module (main.js:53)
                                    at Array.forEach ()
                                    at createDomObjects (main.js:24)
                                    at Object.modulesStarted (main.js:468)
                                    at startModules (loader.js:59)
                                    at loader.js:40
                                Promise.catch (async)
                                modules.forEach.module @ main.js:57
                                createDomObjects @ main.js:24
                                modulesStarted @ main.js:468
                                startModules @ loader.js:59
                                (anonymous) @ loader.js:40
                                stylesheet.onload @ loader.js:203
                                load (async)
                                loadFile @ loader.js:202
                                loadNextModule @ loader.js:38
                                (anonymous) @ loader.js:31
                                (anonymous) @ loader.js:126
                                (anonymous) @ loader.js:163
                                loadTranslations @ module.js:333
                                (anonymous) @ loader.js:160
                                loadNextDependency @ module.js:298
                                (anonymous) @ module.js:295
                                load (async)
                                loadFile @ loader.js:261
                                loadNextDependency @ module.js:293
                                loadDependencies @ module.js:302
                                loadStyles @ module.js:268
                                (anonymous) @ loader.js:158
                                script.onload @ loader.js:187
                                load (async)
                                loadFile @ loader.js:186
                                loadFile @ loader.js:254
                                loadFile @ loader.js:238
                                loadScripts @ module.js:277
                                bootstrapModule @ loader.js:156
                                afterLoad @ loader.js:125
                                (anonymous) @ loader.js:138
                                load (async)
                                loadModule @ loader.js:136
                                loadNextModule @ loader.js:29
                                load (async)
                                (anonymous) @ translator.js:185
                                xhr.onreadystatechange @ translator.js:22
                                XMLHttpRequest.send (async)
                                loadJSON @ translator.js:25
                                load @ translator.js:179
                                loadTranslations @ module.js:330
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                loadModules @ loader.js:46
                                loadModules @ loader.js:223
                                init @ main.js:450
                                (anonymous) @ main.js:577
                                module.js:155 MMM-Traffic received a system notification: MODULE_DOM_CREATED
                                module.js:155 clock received a system notification: MODULE_DOM_CREATED
                                MMM-NOAA.js:344 Uncaught (in promise) TypeError: Cannot read property '0' of undefined
                                    at new Promise ()
                                    at Array.forEach ()
                                    at loader.js:40
                                getDom @ MMM-NOAA.js:344
                                Promise @ main.js:110
                                updateDom @ main.js:109
                                modules.forEach.module @ main.js:53
                                Promise.then (async)
                                createDomObjects @ main.js:62
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                init @ main.js:450
                                undefined.png:1 GET http://192.168.1.243:8080/modules/MMM-NOAA/images/undefined.png 404 (Not Found)
                                Image (async)
                                getDom @ MMM-NOAA.js:293
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                load (async)
                                init @ main.js:450
                                MMM-Traffic.js:273 received TRAFFIC_COMMUTE
                                • T
                                  TokTias
                                  Hi !
                                  I am really gloing bananas here. I got several other MMM-modules running in my Ubuntu machine, but MMM-NOAA just won’t start. I get, depending on how I start MM :
                                  node serveronly
                                  Starting MagicMirror: v2.3.1
                                  Loading config ...
                                  Loading module helpers ...
                                  WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                                  [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                                  Or
                                  npm start
                                  > magicmirror@2.3.1 start /home/ranix/MagicMirror
                                  > sh run-start.sh
                                  npm ERR! Linux 4.13.0-43-generic
                                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                  npm ERR! node v4.2.6
                                  npm ERR! npm  v3.5.2
                                  npm ERR! code ELIFECYCLE
                                  npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                                  npm ERR! Exit status 1
                                  npm ERR!
                                  npm ERR! Failed at the magicmirror@2.3.1 start script 'sh run-start.sh'.
                                  npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                  npm ERR! not with npm itself.
                                  npm ERR!     sh run-start.sh
                                  npm ERR!     npm bugs magicmirror
                                  npm ERR! Or if that isn't available, you can get their info via:
                                  npm ERR!     npm owner ls magicmirror
                                  npm ERR!     /home/ranix/MagicMirror/npm-debug.log
                                  I did not get any issues when running npm install, and as mentioned above, no issues with other modules.
                                  npm run config:check
                                  runs ok and I even removed my MM-instalaltion, reinstalled it and I tried a minimal config.js file like this :
                                  var config = {
                                  	address: "0.0.0.0",
                                  	port: 8070,
                                  	ipWhitelist: [],
                                  	language: "en",
                                  	timeFormat: 24,
                                  	units: "metric",
                                  	    		module: 'MMM-NOAA',
                                  			position: 'top_center',
                                  			config:{
                                  				apiKey: '----',
                                  				airKey: '----',
                                  And it just shows the errors as listed above.
                                  Is there anyone who can help me figure out what’s going south here before I have to give up ?
                                  Cheers & TIA !
                                  /T
                                  Mykle1M cowboysdudeC 2 Replies Last reply
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @TokTias
                                    @toktias said in MMM-NOAA - Another Weather Module:
                                    This may or may not be related but your node seems like it could be updated.
                                    T 1 Reply Last reply
                                    • cowboysdudeC
                                      cowboysdude Module Developer @TokTias
                                      @toktias Sent you a PM…
                                      In reality all mirrors are different and from time to time these things happen :)
                                      • T
                                        TokTias @Mykle1
                                        @mykle1 Thanks, but as far as I can see, I got the latest version; “4.2.6~dfsg-1ubuntu4.1”. Or am I missing some new/hidden version out there ? :)
                                        Cheers !
                                        /T
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @TokTias
                                          @toktias you are running node v4.2.6 the current version is v10.4.1 https://nodejs.org/en/
                                          T cowboysdudeC 2 Replies Last reply
                                          Reply Quote 3
                                          • T
                                            TokTias @strawberry 3.141
                                            @strawberry-3-141
                                            Thanks for pointing me in the correct direction !
                                            My Linux-box was pointing to ppa:chris-lea/node.js as the source for Node.js, I removed that (reference and unistalled it) and installed per the intrucitons you linked to in your post above a voilá, MMM-NOAA works perfect now !
                                            Thanks a lot & Cheers !
                                            /T
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 34
                                            • 35
                                            • 21 / 35
