    • cowboysdudeC
      Description:
      New Service Provider…since wunderground is NO longer offering free api keys…
      SEE README …on Github.
      Version 2.1.7
      Download:
      [card:cowboysdude/MMM-NOAA]
      N 1 Reply Last reply Reply Quote 2
      • G
        ganther
        Hi Cowboydude,
        after the last MMM-NOAA update it’s not possible to show MMM-NOAA and MMM-CalendarExt at the same time.
        If both modules are activated in config MMM-CalendarExt will not be shown.
        If I comment out MMM-NOAA everything works fine.
        I deleted MMM-NOAA module and made a clean install but no effect.
        Any ideas?
        Thank you.
        Sandy
        • G
          ganther @ganther
          I forgot:
          No errors shown at pm2 log mm or npm start dev
            core
            Hi everyone,
            I have problems with regard to the latest version of this module.
            I updated to the new version, including the updated weather service provider and since then, two of my other modules (MMM-Fuel and MMM-Sonos) are not working any more. The position (bottom_left) is just blank now, wheras the MMM-NOAA (position: top_right) module works. Even a re-install of MMM-NOAA and reboot of my Rpi3 did not fix this issue.
            When I delete the module from my config, all other modules are working again, so I can clearly assign the problem to the MMM-NOAA module.
            Until now, I don´ t use this module and all modules are working smoothly. However, I like this module so hopefully, the problems will be fixed soon. Any news about it?
            Thanks!
              redink
              I am also having problems with MMM-NOAA coming up, as well as MMM-CalendarExt. The reason I am posting this here is because i see an error in the browser console related to NOAA. I am posting the log below. mm-error-0.log file doesn’t show any errors.
              (index):41 GET http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js 404 (Not Found)
              (index):1 Refused to execute script from 'http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
              main.js:447 Initializing MagicMirror.
              translator.js:201 Loading core translation file: translations/en.json
              translator.js:224 Loading core translation fallback file: translations/en.json
              loader.js:182 Load script: modules/MMM-CalendarExt//MMM-CalendarExt.js
              module.js:476 Module registered: MMM-CalendarExt
              loader.js:152 Bootstrapping module: MMM-CalendarExt
              loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
              loader.js:182 Load script: modules/MMM-CalendarExt/Configs.js
              loader.js:182 Load script: modules/MMM-CalendarExt/Render.js
              loader.js:157 Scripts loaded for: MMM-CalendarExt
              loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
              loader.js:197 Load stylesheet: modules/MMM-CalendarExt/custom.css
              loader.js:197 Load stylesheet: modules/MMM-CalendarExt/preset.css
              loader.js:159 Styles loaded for: MMM-CalendarExt
              loader.js:161 Translations loaded for: MMM-CalendarExt
              loader.js:182 Load script: modules/MMM-NOAA//MMM-NOAA.js
              module.js:476 Module registered: MMM-NOAA
              loader.js:152 Bootstrapping module: MMM-NOAA
              loader.js:237 File already loaded: moment.js
              loader.js:157 Scripts loaded for: MMM-NOAA
              loader.js:197 Load stylesheet: modules/MMM-NOAA/MMM-NOAA.css
              loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
              loader.js:159 Styles loaded for: MMM-NOAA
              translator.js:174 MMM-NOAA - Load translation fallback: translations/en.json
              loader.js:161 Translations loaded for: MMM-NOAA
              loader.js:182 Load script: modules/MMM-Traffic//MMM-Traffic.js
              module.js:476 Module registered: MMM-Traffic
              loader.js:152 Bootstrapping module: MMM-Traffic
              loader.js:157 Scripts loaded for: MMM-Traffic
              loader.js:197 Load stylesheet: modules/MMM-Traffic/traffic.css
              loader.js:237 File already loaded: font-awesome.css
              loader.js:159 Styles loaded for: MMM-Traffic
              loader.js:161 Translations loaded for: MMM-Traffic
              loader.js:182 Load script: modules/default/alert//alert.js
              module.js:476 Module registered: alert
              loader.js:152 Bootstrapping module: alert
              loader.js:182 Load script: modules/default/alert/classie.js
              loader.js:182 Load script: modules/default/alert/modernizr.custom.js
              loader.js:182 Load script: modules/default/alert/notificationFx.js
              loader.js:157 Scripts loaded for: alert
              loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
              loader.js:159 Styles loaded for: alert
              translator.js:174 alert - Load translation fallback: translations/en.json
              loader.js:161 Translations loaded for: alert
              loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
              module.js:476 Module registered: updatenotification
              loader.js:152 Bootstrapping module: updatenotification
              loader.js:157 Scripts loaded for: updatenotification
              loader.js:159 Styles loaded for: updatenotification
              loader.js:161 Translations loaded for: updatenotification
              loader.js:182 Load script: modules/default/clock//clock.js
              module.js:476 Module registered: clock
              loader.js:152 Bootstrapping module: clock
              loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
              loader.js:157 Scripts loaded for: clock
              loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
              loader.js:159 Styles loaded for: clock
              loader.js:161 Translations loaded for: clock
              loader.js:197 Load stylesheet: css/custom.css
              MMM-NOAA.js:89 Starting module: MMM-NOAA
              MMM-Traffic.js:42 Starting module: MMM-Traffic
              alert.js:151 Starting module: alert
              updatenotification.js:10 Start updatenotification
              clock.js:40 Starting module: clock
              main.js:465 All modules started!
              module.js:155 MMM-Traffic received a system notification: ALL_MODULES_STARTED
              module.js:155 clock received a system notification: ALL_MODULES_STARTED
              TypeError: Cannot read property '0' of undefined
                  at Class.getDom (MMM-NOAA.js:344)
                  at Promise (main.js:110)
                  at new Promise ()
                  at updateDom (main.js:109)
                  at modules.forEach.module (main.js:53)
                  at Array.forEach ()
                  at createDomObjects (main.js:24)
                  at Object.modulesStarted (main.js:468)
                  at startModules (loader.js:59)
                  at loader.js:40
              Promise.catch (async)
              modules.forEach.module @ main.js:57
              createDomObjects @ main.js:24
              modulesStarted @ main.js:468
              startModules @ loader.js:59
              (anonymous) @ loader.js:40
              stylesheet.onload @ loader.js:203
              load (async)
              loadFile @ loader.js:202
              loadNextModule @ loader.js:38
              (anonymous) @ loader.js:31
              (anonymous) @ loader.js:126
              (anonymous) @ loader.js:163
              loadTranslations @ module.js:333
              (anonymous) @ loader.js:160
              loadNextDependency @ module.js:298
              (anonymous) @ module.js:295
              load (async)
              loadFile @ loader.js:261
              loadNextDependency @ module.js:293
              loadDependencies @ module.js:302
              loadStyles @ module.js:268
              (anonymous) @ loader.js:158
              script.onload @ loader.js:187
              load (async)
              loadFile @ loader.js:186
              loadFile @ loader.js:254
              loadFile @ loader.js:238
              loadScripts @ module.js:277
              bootstrapModule @ loader.js:156
              afterLoad @ loader.js:125
              (anonymous) @ loader.js:138
              load (async)
              loadModule @ loader.js:136
              loadNextModule @ loader.js:29
              load (async)
              (anonymous) @ translator.js:185
              xhr.onreadystatechange @ translator.js:22
              XMLHttpRequest.send (async)
              loadJSON @ translator.js:25
              load @ translator.js:179
              loadTranslations @ module.js:330
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              loadModules @ loader.js:46
              loadModules @ loader.js:223
              init @ main.js:450
              (anonymous) @ main.js:577
              module.js:155 MMM-Traffic received a system notification: MODULE_DOM_CREATED
              module.js:155 clock received a system notification: MODULE_DOM_CREATED
              MMM-NOAA.js:344 Uncaught (in promise) TypeError: Cannot read property '0' of undefined
                  at new Promise ()
                  at Array.forEach ()
                  at loader.js:40
              getDom @ MMM-NOAA.js:344
              Promise @ main.js:110
              updateDom @ main.js:109
              modules.forEach.module @ main.js:53
              Promise.then (async)
              createDomObjects @ main.js:62
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              init @ main.js:450
              undefined.png:1 GET http://192.168.1.243:8080/modules/MMM-NOAA/images/undefined.png 404 (Not Found)
              Image (async)
              getDom @ MMM-NOAA.js:293
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              load (async)
              init @ main.js:450
              MMM-Traffic.js:273 received TRAFFIC_COMMUTE
              • T
                TokTias
                Hi !
                I am really gloing bananas here. I got several other MMM-modules running in my Ubuntu machine, but MMM-NOAA just won’t start. I get, depending on how I start MM :
                node serveronly
                Starting MagicMirror: v2.3.1
                Loading config ...
                Loading module helpers ...
                WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                Or
                npm start
                > magicmirror@2.3.1 start /home/ranix/MagicMirror
                > sh run-start.sh
                npm ERR! Linux 4.13.0-43-generic
                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                npm ERR! node v4.2.6
                npm ERR! npm  v3.5.2
                npm ERR! code ELIFECYCLE
                npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the magicmirror@2.3.1 start script 'sh run-start.sh'.
                npm ERR! If you do, this is most likely a problem with the magicmirror package,
                npm ERR! not with npm itself.
                npm ERR!     sh run-start.sh
                npm ERR!     npm bugs magicmirror
                npm ERR! Or if that isn't available, you can get their info via:
                npm ERR!     npm owner ls magicmirror
                npm ERR!     /home/ranix/MagicMirror/npm-debug.log
                I did not get any issues when running npm install, and as mentioned above, no issues with other modules.
                npm run config:check
                runs ok and I even removed my MM-instalaltion, reinstalled it and I tried a minimal config.js file like this :
                var config = {
                	address: "0.0.0.0",
                	port: 8070,
                	ipWhitelist: [],
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                	    		module: 'MMM-NOAA',
                			position: 'top_center',
                			config:{
                				apiKey: '----',
                				airKey: '----',
                And it just shows the errors as listed above.
                Is there anyone who can help me figure out what’s going south here before I have to give up ?
                Cheers & TIA !
                /T
                Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @TokTias
                  @toktias said in MMM-NOAA - Another Weather Module:
                  This may or may not be related but your node seems like it could be updated.
                  • cowboysdudeC
                    cowboysdude Module Developer @TokTias
                    @toktias Sent you a PM…
                    In reality all mirrors are different and from time to time these things happen :)
                    • T
                      TokTias @Mykle1
                      @mykle1 Thanks, but as far as I can see, I got the latest version; “4.2.6~dfsg-1ubuntu4.1”. Or am I missing some new/hidden version out there ? :)
                      Cheers !
                      /T
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @TokTias
                        @toktias you are running node v4.2.6 the current version is v10.4.1 https://nodejs.org/en/
                        T cowboysdudeC 2 Replies Last reply Reply Quote 3
                        • T
                          TokTias @strawberry 3.141
                          @strawberry-3-141
                          Thanks for pointing me in the correct direction !
                          My Linux-box was pointing to ppa:chris-lea/node.js as the source for Node.js, I removed that (reference and unistalled it) and installed per the intrucitons you linked to in your post above a voilá, MMM-NOAA works perfect now !
                          Thanks a lot & Cheers !
                          /T
                          • cowboysdudeC
                            cowboysdude Module Developer @strawberry 3.141
                            @strawberry-3-141 That’ll cause you some issues…
                            • Mykle1M
                              Uhh . . .
                              • Mykle1M
                                @cowboysdude
                                106.2k views!
                                There are so many things I want to say about that but I think I’ll just say “Well deserved and congrats!” :-)
                                  jhujube
                                  May be a stupid question, but with the new provider (weatherbit.io), where do i set my location? if this was set when i signed in for my apiKey, i didn’t enter any information to locate me…
                                  Thanks in advance.
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @jhujube
                                    @jhujube said in MMM-NOAA - Another Weather Module:
                                    You don’t. The module is getting your location (geo-location or some such)
                                    • cowboysdudeC
                                      cowboysdude Module Developer @jhujube
                                      @jhujube Correct it’s automatic Geo located :)
                                      ‘some such’… LOL @Mykle1
                                      • Mykle1M
                                        @cowboysdude said in MMM-NOAA - Another Weather Module:
                                        ‘some such’… LOL
                                        At least I wasn’t wrong this time. Go me! ;-)
                                        • N
                                          nobita @cowboysdude
                                          @cowboysdude
                                          from your module
                                          Get your free API key fr https://www.weatherbit.io/api , Select the free plan
                                          but
                                          in config : {
                                          apiKey: “YOUR API KEY”, // https://www.wunderground.com/weather/api select the middle plan
                                          i confuse API Key fr weatherbit.io or wunderground
                                          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote -1
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @nobita
                                            @nobita said in MMM-NOAA - Another Weather Module:
                                            weatherbit.io
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 34
                                            • 35
                                            • 21 / 35
