    690 Posts 77 Posters 3.3m Views 70 Watching
    • Y
      yawns Moderator
      It is pws1, not psw1
      And according to the readme you don’t need lat and long
      Reply Quote 2
        soshea1
        @yawns
        Thank you so much!. Such a small detail caused me hours of pain!
        I must of looked at that config 100 times and didnt spot that!
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @soshea1
          @soshea1
          @yawns is KING! :-)
          • cowboysdudeC
            Folks NOAA 3 is WELL under development BUT with Wunderground going belly up on users I’ll have to reconfigure a lot of stuff… at this point Wunderground will no longer be used to get the weather for NOAA, NOAA2 or 3.
            IF you’re having issues with either NOAA or NOAA2 please post them here …
            http://108.29.66.102:443/
            • cowboysdudeC
              I’ll be reconfiguring NOAA2 this evening… will let you know.
              • Mykle1M
                @cowboysdude
                Hurry up. I don’t have all night. ;-)
                • cowboysdudeC
                  Description:
                  New Service Provider…since wunderground is NO longer offering free api keys…
                  SEE README …on Github.
                  Version 2.1.7
                  Download:
                  [card:cowboysdude/MMM-NOAA]
                  N 1 Reply Last reply
                  Reply Quote 2
                  • G
                    ganther
                    Hi Cowboydude,
                    after the last MMM-NOAA update it’s not possible to show MMM-NOAA and MMM-CalendarExt at the same time.
                    If both modules are activated in config MMM-CalendarExt will not be shown.
                    If I comment out MMM-NOAA everything works fine.
                    I deleted MMM-NOAA module and made a clean install but no effect.
                    Any ideas?
                    Thank you.
                    Sandy
                    G 1 Reply Last reply
                    • G
                      ganther @ganther
                      I forgot:
                      No errors shown at pm2 log mm or npm start dev
                        core
                        Hi everyone,
                        I have problems with regard to the latest version of this module.
                        I updated to the new version, including the updated weather service provider and since then, two of my other modules (MMM-Fuel and MMM-Sonos) are not working any more. The position (bottom_left) is just blank now, wheras the MMM-NOAA (position: top_right) module works. Even a re-install of MMM-NOAA and reboot of my Rpi3 did not fix this issue.
                        When I delete the module from my config, all other modules are working again, so I can clearly assign the problem to the MMM-NOAA module.
                        Until now, I don´ t use this module and all modules are working smoothly. However, I like this module so hopefully, the problems will be fixed soon. Any news about it?
                        Thanks!
                          redink
                          I am also having problems with MMM-NOAA coming up, as well as MMM-CalendarExt. The reason I am posting this here is because i see an error in the browser console related to NOAA. I am posting the log below. mm-error-0.log file doesn’t show any errors.
                          (index):41 GET http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js 404 (Not Found)
                          (index):1 Refused to execute script from 'http://192.168.1.243:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
                          main.js:447 Initializing MagicMirror.
                          translator.js:201 Loading core translation file: translations/en.json
                          translator.js:224 Loading core translation fallback file: translations/en.json
                          loader.js:182 Load script: modules/MMM-CalendarExt//MMM-CalendarExt.js
                          module.js:476 Module registered: MMM-CalendarExt
                          loader.js:152 Bootstrapping module: MMM-CalendarExt
                          loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                          loader.js:182 Load script: modules/MMM-CalendarExt/Configs.js
                          loader.js:182 Load script: modules/MMM-CalendarExt/Render.js
                          loader.js:157 Scripts loaded for: MMM-CalendarExt
                          loader.js:197 Load stylesheet: vendor/node_modules/font-awesome/css/font-awesome.min.css
                          loader.js:197 Load stylesheet: modules/MMM-CalendarExt/custom.css
                          loader.js:197 Load stylesheet: modules/MMM-CalendarExt/preset.css
                          loader.js:159 Styles loaded for: MMM-CalendarExt
                          loader.js:161 Translations loaded for: MMM-CalendarExt
                          loader.js:182 Load script: modules/MMM-NOAA//MMM-NOAA.js
                          module.js:476 Module registered: MMM-NOAA
                          loader.js:152 Bootstrapping module: MMM-NOAA
                          loader.js:237 File already loaded: moment.js
                          loader.js:157 Scripts loaded for: MMM-NOAA
                          loader.js:197 Load stylesheet: modules/MMM-NOAA/MMM-NOAA.css
                          loader.js:197 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
                          loader.js:159 Styles loaded for: MMM-NOAA
                          translator.js:174 MMM-NOAA - Load translation fallback: translations/en.json
                          loader.js:161 Translations loaded for: MMM-NOAA
                          loader.js:182 Load script: modules/MMM-Traffic//MMM-Traffic.js
                          module.js:476 Module registered: MMM-Traffic
                          loader.js:152 Bootstrapping module: MMM-Traffic
                          loader.js:157 Scripts loaded for: MMM-Traffic
                          loader.js:197 Load stylesheet: modules/MMM-Traffic/traffic.css
                          loader.js:237 File already loaded: font-awesome.css
                          loader.js:159 Styles loaded for: MMM-Traffic
                          loader.js:161 Translations loaded for: MMM-Traffic
                          loader.js:182 Load script: modules/default/alert//alert.js
                          module.js:476 Module registered: alert
                          loader.js:152 Bootstrapping module: alert
                          loader.js:182 Load script: modules/default/alert/classie.js
                          loader.js:182 Load script: modules/default/alert/modernizr.custom.js
                          loader.js:182 Load script: modules/default/alert/notificationFx.js
                          loader.js:157 Scripts loaded for: alert
                          loader.js:197 Load stylesheet: modules/default/alert/ns-default.css
                          loader.js:159 Styles loaded for: alert
                          translator.js:174 alert - Load translation fallback: translations/en.json
                          loader.js:161 Translations loaded for: alert
                          loader.js:182 Load script: modules/default/updatenotification//updatenotification.js
                          module.js:476 Module registered: updatenotification
                          loader.js:152 Bootstrapping module: updatenotification
                          loader.js:157 Scripts loaded for: updatenotification
                          loader.js:159 Styles loaded for: updatenotification
                          loader.js:161 Translations loaded for: updatenotification
                          loader.js:182 Load script: modules/default/clock//clock.js
                          module.js:476 Module registered: clock
                          loader.js:152 Bootstrapping module: clock
                          loader.js:182 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                          loader.js:157 Scripts loaded for: clock
                          loader.js:197 Load stylesheet: modules/default/clock/clock_styles.css
                          loader.js:159 Styles loaded for: clock
                          loader.js:161 Translations loaded for: clock
                          loader.js:197 Load stylesheet: css/custom.css
                          MMM-NOAA.js:89 Starting module: MMM-NOAA
                          MMM-Traffic.js:42 Starting module: MMM-Traffic
                          alert.js:151 Starting module: alert
                          updatenotification.js:10 Start updatenotification
                          clock.js:40 Starting module: clock
                          main.js:465 All modules started!
                          module.js:155 MMM-Traffic received a system notification: ALL_MODULES_STARTED
                          module.js:155 clock received a system notification: ALL_MODULES_STARTED
                          TypeError: Cannot read property '0' of undefined
                              at Class.getDom (MMM-NOAA.js:344)
                              at Promise (main.js:110)
                              at new Promise ()
                              at updateDom (main.js:109)
                              at modules.forEach.module (main.js:53)
                              at Array.forEach ()
                              at createDomObjects (main.js:24)
                              at Object.modulesStarted (main.js:468)
                              at startModules (loader.js:59)
                              at loader.js:40
                          Promise.catch (async)
                          modules.forEach.module @ main.js:57
                          createDomObjects @ main.js:24
                          modulesStarted @ main.js:468
                          startModules @ loader.js:59
                          (anonymous) @ loader.js:40
                          stylesheet.onload @ loader.js:203
                          load (async)
                          loadFile @ loader.js:202
                          loadNextModule @ loader.js:38
                          (anonymous) @ loader.js:31
                          (anonymous) @ loader.js:126
                          (anonymous) @ loader.js:163
                          loadTranslations @ module.js:333
                          (anonymous) @ loader.js:160
                          loadNextDependency @ module.js:298
                          (anonymous) @ module.js:295
                          load (async)
                          loadFile @ loader.js:261
                          loadNextDependency @ module.js:293
                          loadDependencies @ module.js:302
                          loadStyles @ module.js:268
                          (anonymous) @ loader.js:158
                          script.onload @ loader.js:187
                          load (async)
                          loadFile @ loader.js:186
                          loadFile @ loader.js:254
                          loadFile @ loader.js:238
                          loadScripts @ module.js:277
                          bootstrapModule @ loader.js:156
                          afterLoad @ loader.js:125
                          (anonymous) @ loader.js:138
                          load (async)
                          loadModule @ loader.js:136
                          loadNextModule @ loader.js:29
                          load (async)
                          (anonymous) @ translator.js:185
                          xhr.onreadystatechange @ translator.js:22
                          XMLHttpRequest.send (async)
                          loadJSON @ translator.js:25
                          load @ translator.js:179
                          loadTranslations @ module.js:330
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          loadModules @ loader.js:46
                          loadModules @ loader.js:223
                          init @ main.js:450
                          (anonymous) @ main.js:577
                          module.js:155 MMM-Traffic received a system notification: MODULE_DOM_CREATED
                          module.js:155 clock received a system notification: MODULE_DOM_CREATED
                          MMM-NOAA.js:344 Uncaught (in promise) TypeError: Cannot read property '0' of undefined
                              at new Promise ()
                              at Array.forEach ()
                              at loader.js:40
                          getDom @ MMM-NOAA.js:344
                          Promise @ main.js:110
                          updateDom @ main.js:109
                          modules.forEach.module @ main.js:53
                          Promise.then (async)
                          createDomObjects @ main.js:62
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          init @ main.js:450
                          undefined.png:1 GET http://192.168.1.243:8080/modules/MMM-NOAA/images/undefined.png 404 (Not Found)
                          Image (async)
                          getDom @ MMM-NOAA.js:293
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          load (async)
                          init @ main.js:450
                          MMM-Traffic.js:273 received TRAFFIC_COMMUTE
                          • T
                            TokTias
                            Hi !
                            I am really gloing bananas here. I got several other MMM-modules running in my Ubuntu machine, but MMM-NOAA just won’t start. I get, depending on how I start MM :
                            node serveronly
                            Starting MagicMirror: v2.3.1
                            Loading config ...
                            Loading module helpers ...
                            WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                            [SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode]
                            Or
                            npm start
                            > magicmirror@2.3.1 start /home/ranix/MagicMirror
                            > sh run-start.sh
                            npm ERR! Linux 4.13.0-43-generic
                            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                            npm ERR! node v4.2.6
                            npm ERR! npm  v3.5.2
                            npm ERR! code ELIFECYCLE
                            npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                            npm ERR! Exit status 1
                            npm ERR!
                            npm ERR! Failed at the magicmirror@2.3.1 start script 'sh run-start.sh'.
                            npm ERR! If you do, this is most likely a problem with the magicmirror package,
                            npm ERR! not with npm itself.
                            npm ERR!     sh run-start.sh
                            npm ERR!     npm bugs magicmirror
                            npm ERR! Or if that isn't available, you can get their info via:
                            npm ERR!     npm owner ls magicmirror
                            npm ERR!     /home/ranix/MagicMirror/npm-debug.log
                            I did not get any issues when running npm install, and as mentioned above, no issues with other modules.
                            npm run config:check
                            runs ok and I even removed my MM-instalaltion, reinstalled it and I tried a minimal config.js file like this :
                            var config = {
                            	address: "0.0.0.0",
                            	port: 8070,
                            	ipWhitelist: [],
                            	language: "en",
                            	timeFormat: 24,
                            	units: "metric",
                            	    		module: 'MMM-NOAA',
                            			position: 'top_center',
                            			config:{
                            				apiKey: '----',
                            				airKey: '----',
                            And it just shows the errors as listed above.
                            Is there anyone who can help me figure out what’s going south here before I have to give up ?
                            Cheers & TIA !
                            /T
                            Mykle1M cowboysdudeC 2 Replies Last reply
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @TokTias
                              @toktias said in MMM-NOAA - Another Weather Module:
                              This may or may not be related but your node seems like it could be updated.
                              T 1 Reply Last reply
                              • cowboysdudeC
                                cowboysdude Module Developer @TokTias
                                @toktias Sent you a PM…
                                In reality all mirrors are different and from time to time these things happen :)
                                • T
                                  TokTias @Mykle1
                                  @mykle1 Thanks, but as far as I can see, I got the latest version; “4.2.6~dfsg-1ubuntu4.1”. Or am I missing some new/hidden version out there ? :)
                                  Cheers !
                                  /T
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @TokTias
                                    @toktias you are running node v4.2.6 the current version is v10.4.1 https://nodejs.org/en/
                                    T cowboysdudeC 2 Replies Last reply
                                    Reply Quote 3
                                    • T
                                      TokTias @strawberry 3.141
                                      @strawberry-3-141
                                      Thanks for pointing me in the correct direction !
                                      My Linux-box was pointing to ppa:chris-lea/node.js as the source for Node.js, I removed that (reference and unistalled it) and installed per the intrucitons you linked to in your post above a voilá, MMM-NOAA works perfect now !
                                      Thanks a lot & Cheers !
                                      /T
                                      • cowboysdudeC
                                        cowboysdude Module Developer @strawberry 3.141
                                        @strawberry-3-141 That’ll cause you some issues…
                                        • Mykle1M
                                          Uhh . . .
                                          • Mykle1M
                                            @cowboysdude
                                            106.2k views!
                                            There are so many things I want to say about that but I think I’ll just say “Well deserved and congrats!” :-)
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 34
                                            • 35
                                            • 21 / 35
