    690 Posts 77 Posters 3.1m Views 70 Watching
      barnosch
      please do not use this thread for a complete other module and problem
      • cowboysdudeC Offline
        MMM-NOAA3 is in the works…
        It will be a little while but rest assured I’m working on it :)
        • Z Offline
          Zooooooom
          Finally updated the module, and I like the new look. However, I was wondering if there’s a toggle to hide the “Forecast” piece.
          Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @Zooooooom
            @Zooooooom
            You can’t hide it in css?
            Z 1 Reply Last reply Reply Quote 0
            • Z Offline
              Zooooooom @Mykle1
              I believe the last version had some toggles in the config which were quite nice to have, which is why I am asking if it’s there now. I took a quick look at the code, and wasn’t able to find anything like it.
              I would prefer not to mess with CSS files, because it would mean that updates might break my config.
                @Zooooooom said in MMM-NOAA - Another Weather Module:
                No sir. Your config is unaffected by your custom.css entries. In fact, it’s the very reason there is a custom.css file, so that you can make those changes without changing the module files and you don’t lose your changes when the module is updated.
                Z 1 Reply Last reply Reply Quote 1
                  cowboysdude Module Developer @Zooooooom
                  @Zooooooom put this in your custom.css file:
                  .MMM-NOAA .forehead {
                  display: none;
                  .MMM-NOAA .fmar {
                  display: none;
                  after you do a git pull to update your NOAA css file :)
                  Z 1 Reply Last reply Reply Quote 2
                  • Z Offline
                    Zooooooom @Mykle1
                    @Mykle1 Thanks, I didn’t realize that.
                    • Z Offline
                      Zooooooom @cowboysdude
                      @cowboysdude Awesome, thanks!
                        Peter
                        I am using NOAA version 1 because I like this more than version 2.
                        Is there any problem going to be in the future with version 1?
                        Peter
                          @Zooooooom
                          You are welcome, sir. I see that @cowboysdude has given you some direct assistance above so I will bow out gracefully. Props to @cowboysdude for his wonderful module and fantastic support.
                            cowboysdude Module Developer @Peter
                            @Peter said in MMM-NOAA - Another Weather Module:
                            Peter
                            Not sure what you mean. Do you mean you’d like to see future versions based on V1?
                              Peter @cowboysdude
                              @cowboysdude yes; there are not going to be any updates for version 1?
                              Peter
                                barnosch
                                Same for me.
                                I will stay with V1, since the new one is too fancy (and way to big) for me.
                                Hope it will not getting corrupted by any changes with the new versions.
                                • Y Offline
                                  yawns Moderator
                                  Ideal would be to use the same core and develope different templates which could be chosen via config.
                                    cowboysdude Module Developer @yawns
                                    @yawns said in MMM-NOAA - Another Weather Module:
                                    You would think that wouldn’t you? LOL
                                      This is, by far, my favorite weather module, V1 and V2. And like everyone else, I have my own likes and dislikes. But rather than trouble @cowboysdude and his vision of what he wants the module to be, I made my own adjustments via css. With 76.6k views, and 390 posts in this topic alone, I can’t even imagine trying to satisfy everyone’s requests.
                                      Forrest Gump: “That’s all I have to say about that.”
                                        soshea1
                                        Hey there,
                                        Im hoping that someone can help me out with an error on this module. I am a complete newbie to this, so please bare with me.
                                        I have loaded the MMM-NOA module onto the config script, created the API key and selected the PWS on wundermap. However when i load up Magic Mirror- The module displays 'Undefined and NAN with no information loaded. It seems like it is just not pulling the info from the PWS correctly.
                                        I followed the instructions correctly, but dont seem to be able to fix this.
                                        Thank you
                                          Mykle1 Project Sponsor Module Developer @soshea1
                                          @soshea1
                                          Did you try another PWS? They can fail. Also, post your config entry for NOAA here (in a code block) so we can have a look at it.
                                            soshea1 @Mykle1
                                            @Mykle1
                                            Yes i tried using multiple different PWS codes, and still none of them display.
                                            Ill try upload a picture in a separate reply of what displays.
                                            Thanks for any help
                                            /* Magic Mirror Config Sample
                                             * MIT Licensed.
                                            var config = {
        // - "localhost", "127.", "::1" to listen on loopback interface
                                            	port: 8080,
                                            	ipWhitelist: ["127.0.0.1", "::ffff:127", "::1"], // Set [] to allow all IP addresses
        // or add a specific IPv4 of 192.****** :
        // ["127.0.0.1", "::ffff:127", "::1", "::ffff:192."],
        // or IPv4 range of 192. --> 192.1 use CIDR format :
        // ["127.0.0.1", "::ffff:127.", "::1", "::ffff:192/28"],
                                            	language: "en",
                                            	timeFormat: 24,
                                            	units: "metric",
                                            			module: "alert",
                                            			module: "updatenotification",
                                            			position: "top_bar"
                                            			module: "clock",
                                            			position: "top_left"
                                            			header: "Canada Holidays",
                                            						symbol: "calendar-check-o ",
                                            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/39/Canada_Holidays.ics"
                                            			module: "compliments",
                                            			position: "lower_third"
                                            			disabled: true,
                                            			module: "currentweather",
                                            				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            			disabled: true,
                                            			module: "weatherforecast",
                                            			header: "Weather Forecast",
                                            				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            			module: "newsfeed",
                                            			position: "bottom_bar",
                                            				feeds: [
                                            						title: "New York Times",
                                            				showSourceTitle: true,
                                            				showPublishDate: true
                                            			disabled: false,
                                            			module: 'MMM-NOAA',
                                            			apiKey: "f78fa7e86*****",
                                            			useAir: false,
                                            			psw1: "IONTARIO1060",
                                            			lat: "43.177",
                                            			long: "-79.800",
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 34
                                            • 35
                                            • 20 / 35
