    MMM-MyWastePickup (Toronto waste collection schedule)
    69 Posts 16 Posters 66.4k Views 17 Watching
    • twosquirrelsT Offline
      twosquirrels @j.e.f.f
      @j.e.f.f
      Ohh right, number of weeks. I was thinking it was number of events. Makes sense!
      • WayneRigleyW Offline
        WayneRigley
        OK, First off Jeff, thank you for this. i cloned and installed and ran the test file you had and everything is working perfectly. So i started to make my own Custom file exactly how you said and no matter what i still continue to get a “loading” so i switch back to your file and it works. I have no idea what im doing wrong.!0_1527603197851_Custom.jpg
        Wayne R
        twosquirrelsT 1 Reply Last reply Reply Quote 0
          twosquirrels @WayneRigley
          @waynerigley The screenshot of your google drive isn’t helpful, because the final result likely has leading/trailing blank spaces, or some other issue that prevents it from parsing correctly. Edit schedule_custom.csv directly at the command line on your raspberry pi.
          WayneRigleyW 1 Reply Last reply Reply Quote 0
            WayneRigley @twosquirrels
            @twosquirrels Thank you for the FAST reply… as im new to this please bare with me. im using putty and VNC and FIleZilla while using this. I made the excel on google and downloaded it to my laptop in CSV with the correct name. then filezilla to get it to the folder. can you give me a command to check what you need me to do. thanks in advance !
            Wayne R
              @waynerigley
              In putty, once you ssh into your raspberry pi, do:
              cd /home/pi/MagicMirror/modules/MMM-MyWastePickup
              Then:
              sudo nano schedule_custom.csv
              You’re now viewing the contents of schedule_custom.csv. I don’t remember if it included a sample or not, but just edit/type/paste your data here. When done, press Control X to exit. It will ask to save, and say “Y” for yes. The contents of the file should look like my post above from 2 months ago.
                @twosquirrels said in MMM-MyWastePickup (Toronto waste collection schedule):
                Thank you for that, new tool for me to remember ! well take a look, it all looks ok to me…0_1527608436847_edit.png
                Wayne R
                  @waynerigley Remove the double quotes from your entire file. For example, it should look like this:
                  Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree
                  Not this:
                  "Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree"
                  Also, remove them from the beginning and end of all following lines.
                  WayneRigleyW 1 Reply Last reply Reply Quote 1
                    @twosquirrels HA guess what ! IT WORKED ! omg thank you so much ! Thank you Thank You Thank You.
                    Wayne R
                      @waynerigley Great! As tiny as this module is, it’s one of the things I appreciate most about the magic mirror. There’s no API to depend on… just a plain old text file that I update once a year.
                      WayneRigleyW 2 Replies Last reply Reply Quote 0
                        @twosquirrels Yes, size dont matter its the quality and this is %100 Quality. its always a battle to check and get things out on time here being so busy. but now its in place its perfect ! Thank you so Much for your time. now to configure my timelines as our local dept just has a cal. no worries tho it will give me something to do now till the end of the day
                        Wayne R
                          @twosquirrels One question for you is; if Gargabe is being picked up on the 14th at am we put the garbage out on the 13th before bed. so should i put the date on the custom as 13th. only reason is i notice the text string showing “today” on the screen.
                          Wayne R
                            @waynerigley The way the module is written, it wants to tell you the day that garbage is picked up. For me, I put the trash out the same morning as it’s picked up a couple hours later. So in my situation, it makes sense. For you, indeed setting all dates back one day would work. However, you might also want to clarify the header of the module for others reading it. For example, the default is:
                              header: 'Waste & Recycling',
                            If you set all dates back, you may want to change it to:
                              header: 'When to put out Waste & Recycling',
                            • I Offline
                              imchrisrein
                              Thanks for writing this one, it will be a big help for my girlfriend who just moved in. It took quite some time trying to figure out the code and then tailor it to my local schedule but it works and looks great. Toronto published their 2019 schedule online but the titles had spaces and the year format was wrong for some days.
                              Wednesday = Paper recycling and big household pickup
                              Thursday = Garbage pickup
                              Monday = Garbage and glass/plastic recycling
                              Such a neat module - thanks again.
                              • W Offline
                                wizz
                                Question about this module.
                                Is it any way to change the icons as i got two trash bin that are in the same color and size the only difference is that one is marked with number 1 and the other number 2 and the collections is every
                                Thursday and garbage can 1 on uneven week and garbage can 2 on even week so can these dates be entered manually? since in my area there is nothing for pickup published on the internet.
                                Or is it some other modules like this that can do this ?
                                  twosquirrels
                                  This has always been my most reliable and dead simple module. However, I reinstalled my raspberry pi yesterday and MMM-MyWastePickup no longer works. It sits at “Loading…” forever. I know how to edit the schedule.csv file as I’ve been doing it for over a year. It just refuses to work and I have no idea why.
                                    module: 'MMM-MyWastePickup',
                                    position: 'top_left',
                                    header: 'My Waste Collection',
                                      collectionCalendar: 'Custom'
                                  J StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                    j.e.f.f Project Sponsor Module Developer @twosquirrels
                                    @twosquirrels any errors show up either in the log or in Electron’s console?
                                      MYLE-01
                                      Thanks alsum
                                      BUT took me 3 hours to get it going
                                      and it was me
                                      weeksToDisplay: 4
                                       to
                                      weeksToDisplay: "4"
                                      THANKS GUYS :clinking_beer_mugs:
                                      • U Offline
                                        uppynz
                                        I’m loving this simple little module! I’m just trying to work out how I show only collections and not the blank days in between. I’ve tried adjusting the config variables but don’t seem to be getting the desired results. Ideally I only want to see the next two upcoming collections (what ever they may be)
                                        		header: 'Wheelie Bin Collections',
                                        • StoffbeuteluweS Offline
                                          Stoffbeuteluwe Project Sponsor @twosquirrels
                                          @twosquirrels for me it works …
                                          • KamiSchamiK Offline
                                            KamiSchami
                                            Hi, how can i change the date format? I live in Germany. Thank you.
                                            Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                                            • 3 / 4
