    MMM-NOAA
    68 Posts 15 Posters 58.8k Views 13 Watching
    • WayneRigleyW
      WayneRigley
      @cowboysdude Glad to say i have the NOAA Installed and working perfect will say better than any other weather module ive installed as the temps are perfect. my ONLY issue is the module does not seem to be auto-sizing to its position. as you can see its overlaying on top of the bottom bar… anyone have any thoughts or what i should start to attack first . ! Picture would not load so here is a link https://photos.app.goo.gl/VNkNaXwfMWWxyemN7
      Wayne R
        core
        hi,
        thanks for the help. I ran npm start dev and here is the log:
        1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
        2 info using npm@3.10.10
        3 info using node@v6.12.3
        4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
        5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
        5 verbose stack at Error (native)
        6 verbose cwd /home/pi
        7 error Linux 4.9.53-v7+
        8 error argv “/usr/bin/node” “/usr/bin/npm” “start” “dev”
        9 error node v6.12.3
        10 error npm v3.10.10
        11 error path /home/pi/package.json
        12 error code ENOENT
        13 error errno -2
        14 error syscall open
        15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
        16 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
        16 error enoent This is most likely not a problem with npm itself
        16 error enoent and is related to npm not being able to find a file.
        17 verbose exit [ -2, true ]
        anz ideas?
        idoodlerI 1 Reply Last reply
        • idoodlerI
          idoodler Module Developer @core
          @core Did you just execute npm start dev in your Raspberry Pi’s home directory?
          Follow the steps to successfully execute the command:
          • Stop any instance of MagicMirror (pm2 stop MagicMirror if you use pm2)
          • cd MagicMirror -> You need to go into the MagicMirror directory
          • Start MagicMirror with Dev Tools
            • If you are connected via SSH: DISPLAY=:0 nohup npm start dev &
            • If you are directly on your Raspberry Pi: npm start dev
            core
            first, thanks again for helping!
            here is the log after executing npm start dev in cd MagicMirror
            Starting MagicMirror: v2.1.3
            Loading config …
            Loading module helpers …
            No helper found for module: calendar_monthly.
            Module helper loaded: MMM-temp-ds18b20
            Module helper loaded: MMM-NOAA
            Module helper loaded: MMM-Sonos
            Module helper loaded: MMM-Fuel
            Module helper loaded: MMM-SystemStats
            All module helpers loaded.
            Starting server on port 8080 …
            Server started …
            Connecting socket for: MMM-temp-ds18b20
            Connecting socket for: MMM-NOAA
            Starting module: MMM-NOAA
            Connecting socket for: MMM-Sonos
            Sonos helper started …
            Connecting socket for: MMM-Fuel
            Starting module helper: MMM-Fuel
            Connecting socket for: MMM-SystemStats
            Starting module: newsfeed
            Sockets connected & modules started …
            Launching application.
            SONOS_UPDATE
            Create new news fetcher for url: http://rss.kicker.de/news/aktuell - Interval: 300000
            Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
            SONOS_UPDATE
            And here is my config file for MMM-NOAA:
            		disabled: false,
            		module: 'MMM-NOAA',
            			position: 'top_right',
            			config:
            			apiKey: "xxx",
            			useAir: true,
            			airKey: "xxx",
            			pws: "ISCHIFFE4",
            			showClock: false,
            			dformat: false,
            			format: "24",
            			ampm: true,
            			showGreet: false,
            			name: "",                  // Your name
            			showWind: true,
            			showDate: false,
            			showForecast: true,         //show bottom 3 day forecast
            			flash: true                 //Today in forecast flashes halo
            With this config of the Module, the following modules are shown on screen and running:
            MMM-NOAA
            Calendar_monthly
            MMM-temp-ds
            clock
            When I delete MMM-NOAA from the config, the following modules are shown on screen and running:
            Calendar_monthly
            clock
            MMM-temp-ds
            newsfeed
            MMM-Fuel
            MMM-Sonos
            MMM-SystemStats
            Thanks again for help!!
              core
              ok in addition I ran pm2 logs mm with regard to the issue.
              Here is the log:
              pi@magicpi:~ $ pm2 logs mm
              [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
              /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
              0|mm | at ClientRequest.emit (events.js:191:7)
              0|mm | at Socket.socketErrorListener (_http_client.js:358:9)
              0|mm | at emitOne (events.js:96:13)
              0|mm | TypeError: Cannot read property ‘statusCode’ of undefined
              0|mm | at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js:115:29)
              0|mm | at self.callback (/home/pi/MagicMirror/modules/MMM-Fuel/node_modules/request/request.js:186:22)
              0|mm | at Request.emit (events.js:191:7)
              0|mm | at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-Fuel/node_modules/request/request.js:878:8)
              0|mm | at TLSSocket.socketErrorListener (_http_client.js:358:9)
              0|mm | at TLSSocket.emit (events.js:191:7)
              0|mm | Failure: null
              /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
              0|mm | Sonos helper started …
              0|mm | Connecting socket for: MMM-Fuel
              0|mm | Starting module helper: MMM-Fuel
              0|mm | Connecting socket for: MMM-SystemStats
              0|mm | Connecting socket for: newsfeed
              0|mm | Starting module: newsfeed
              0|mm | Sockets connected & modules started …
              0|mm | Launching application.
              0|mm | SONOS_UPDATE
              0|mm | Create new news fetcher for url: http://rss.kicker.de/news/aktuell - Interval: 300000
              0|mm | Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
              0|mm |
              0|mm | > magicmirror@2.1.3 start /home/pi/MagicMirror
              0|mm | > sh run-start.sh
              0|mm |
              idoodlerI 2 Replies Last reply
              • idoodlerI
                • idoodlerI
                  @core Can you remove MMM-Fule from your `config.json. There is an unhandled error with this module.
                    core
                    Hi
                    thanks, I will try it.
                    Just for my understanding: I should delete the MMM-Fuel module from my config.js (or is config.json another file)?
                    Sorry I m noob.
                    Thank you very much!
                    • idoodlerI
                      @core Sorry, its the config.js file.
                      • cowboysdudeC
                        cowboysdude Module Developer @WayneRigley
                        @waynerigley Thank you!
                        What you can do is not show the top scrolling forecast and that should lift up the module above the bottom line…
                        I made this to work on a 32" mirror so it’s kinda big I know :)
                        There’s also NOAA1 that is much shorter but doesn’t look like NOAA2…
                        • cowboysdudeC
                          cowboysdude Module Developer @core
                          @core What version of NOAA are you running? If you’re using NOAA2 85% of that config isn’t even used …
                          Check the readme file on github
                            core
                            Thanks all for your help!
                            @idoodler I deleted MMM-Fuel from my config.js. Nothing changed, the other modules mentioned before won‘t work…this seems to be a problem with MMM-NOAA „blocking“ other modules.
                            @cowboysdude I run the latest version, even tried a re-installation. I adjusted the config to the current version, i.e only using apiKey and airKey as shwon in the readme.
                            Any more ideas…?
                              core
                              Ok i tried another weather module instead of mmm–noaa.
                              Everything is on screen and works perfectly.
                              So (in my case) mmm–noaa causes the problems.
                              Anyway I would like to stick to mmm–noaa for its better visualization and tools.
                              I appreciate any help and solutions.
                              Thanks!
                              idoodlerI Mykle1M 2 Replies Last reply
                              • idoodlerI
                                @core You can open the MagicMirror Interface in Chrome on your desktop, open the Development Tools („F12“ on Windows) head over to „Console“ and check for anything red.
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @core
                                  @core
                                  I don’t like to speak for someone else but in this case . . .
                                  @cowboysdude is a personal friend of mine. He is currently in the middle of a massive re-write of NOAA, and that’s after he puts in long days at his day job. I’m sure he’ll investigate this issue when he can. In the meantime, which version of NOAA are you running. I see CBD asked you but you didn’t answer him. :-/
                                  WayneRigleyW 1 Reply Last reply
                                  • WayneRigleyW
                                    WayneRigley @Mykle1
                                    @mykle1 im hanging on the side till the new release… thanks for the heads up
                                    Wayne R
                                      core
                                      @idoodler thanks for your help, I will try it!
                                      @Mykle1 I know that CBD is currently working on an update for this module and I understand that this is very time consuming. I think I will wait for the new version :)
                                      With regard to CBD question: I wrote him (see my prevoius post) that I am using the latest version of this module (V 2.1.7).
                                      @core said in MMM-NOAA:
                                      Any more ideas…?
                                      Best regards!
                                      Mykle1M 1 Reply Last reply
                                      • Mykle1M
                                        Yes, you did. My bad.
                                        • G
                                          ganther
                                          Same behavior with my mirror.
                                          After latest MMM-NOAA update my MMM-CalendarExt doesn‘t work anymore. No errors in logs.
                                          I was forced to deactivate NOAA. :(
                                          • evroomE
                                            evroom
                                            I installed MMM-NOAA V2.0 just now, but the lines necessary in the config.js struck me as being too little.
                                            No ‘position’, etc, just the api’s.
                                            I read that it takes:
                                            language: “en”,
                                            timeFormat: 24,
                                            units: “metric”,
                                            from the config.js, but then still I am missing info like ‘location’, ‘locationID’, etc.
                                            How does it know which city to take ?
                                            What weather information is currently displayed ? England due to “en” ? :-)
                                            In github I read:
                                            “In this new Version you can select up to 3 different weather locations like in this example.”
                                            but I fail to see this.
                                            Could you please provide me with a correct config.js entry for this otherwise good looking module ??
                                            And airvisual.com refuses to give me api (does not send me the confirmation mail), but that not a fault of the module.
                                            Best regards,
                                            Erik-Jan
                                            MagicMirror version: 2.37.0
                                            Mykle1M cowboysdudeC 2 Replies Last reply
                                            • 3 / 4
