    MMM-NOAA
    68 Posts 15 Posters 58.4k Views 13 Watching
    • idoodlerI
      idoodler Module Developer @core
      • idoodlerI
        @core Can you remove MMM-Fule from your `config.json. There is an unhandled error with this module.
          core
          Hi
          thanks, I will try it.
          Just for my understanding: I should delete the MMM-Fuel module from my config.js (or is config.json another file)?
          Sorry I m noob.
          Thank you very much!
          idoodlerI 1 Reply Last reply Reply Quote 0
          • idoodlerI
            @core Sorry, its the config.js file.
            • cowboysdudeC
              cowboysdude Module Developer @WayneRigley
              @waynerigley Thank you!
              What you can do is not show the top scrolling forecast and that should lift up the module above the bottom line…
              I made this to work on a 32" mirror so it’s kinda big I know :)
              There’s also NOAA1 that is much shorter but doesn’t look like NOAA2…
              • cowboysdudeC
                cowboysdude Module Developer @core
                @core What version of NOAA are you running? If you’re using NOAA2 85% of that config isn’t even used …
                Check the readme file on github
                  core
                  Thanks all for your help!
                  @idoodler I deleted MMM-Fuel from my config.js. Nothing changed, the other modules mentioned before won‘t work…this seems to be a problem with MMM-NOAA „blocking“ other modules.
                  @cowboysdude I run the latest version, even tried a re-installation. I adjusted the config to the current version, i.e only using apiKey and airKey as shwon in the readme.
                  Any more ideas…?
                    core
                    Ok i tried another weather module instead of mmm–noaa.
                    Everything is on screen and works perfectly.
                    So (in my case) mmm–noaa causes the problems.
                    Anyway I would like to stick to mmm–noaa for its better visualization and tools.
                    I appreciate any help and solutions.
                    Thanks!
                    idoodlerI Mykle1M 2 Replies Last reply Reply Quote 0
                    • idoodlerI
                      @core You can open the MagicMirror Interface in Chrome on your desktop, open the Development Tools („F12“ on Windows) head over to „Console“ and check for anything red.
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @core
                        @core
                        I don’t like to speak for someone else but in this case . . .
                        @cowboysdude is a personal friend of mine. He is currently in the middle of a massive re-write of NOAA, and that’s after he puts in long days at his day job. I’m sure he’ll investigate this issue when he can. In the meantime, which version of NOAA are you running. I see CBD asked you but you didn’t answer him. :-/
                        WayneRigleyW 1 Reply Last reply Reply Quote 1
                        • WayneRigleyW
                          WayneRigley @Mykle1
                          @mykle1 im hanging on the side till the new release… thanks for the heads up
                          Wayne R
                            core
                            @idoodler thanks for your help, I will try it!
                            @Mykle1 I know that CBD is currently working on an update for this module and I understand that this is very time consuming. I think I will wait for the new version :)
                            With regard to CBD question: I wrote him (see my prevoius post) that I am using the latest version of this module (V 2.1.7).
                            @core said in MMM-NOAA:
                            Any more ideas…?
                            Best regards!
                            • Mykle1M
                              Yes, you did. My bad.
                              • G
                                ganther
                                Same behavior with my mirror.
                                After latest MMM-NOAA update my MMM-CalendarExt doesn‘t work anymore. No errors in logs.
                                I was forced to deactivate NOAA. :(
                                • evroomE
                                  evroom
                                  I installed MMM-NOAA V2.0 just now, but the lines necessary in the config.js struck me as being too little.
                                  No ‘position’, etc, just the api’s.
                                  I read that it takes:
                                  language: “en”,
                                  timeFormat: 24,
                                  units: “metric”,
                                  from the config.js, but then still I am missing info like ‘location’, ‘locationID’, etc.
                                  How does it know which city to take ?
                                  What weather information is currently displayed ? England due to “en” ? :-)
                                  In github I read:
                                  “In this new Version you can select up to 3 different weather locations like in this example.”
                                  but I fail to see this.
                                  Could you please provide me with a correct config.js entry for this otherwise good looking module ??
                                  And airvisual.com refuses to give me api (does not send me the confirmation mail), but that not a fault of the module.
                                  Best regards,
                                  Erik-Jan
                                  MagicMirror version: 2.37.0
                                  Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @evroom
                                    @evroom
                                    This is from the readme.
                                        disabled: false,
                                        module: 'MMM-NOAA',
                                        position: 'top_right',
                                    	apiKey: "YOUR API KEY",    // https://www.wunderground.com/weather/api  select the middle plan...
                                    	airKey: "YOUR API KEY",    // IF you want Air Quality Index
                                    	pws: "KNYELMIR13",         // go here to find your pws: https://www.wunderground.com/wundermap
                                    And this is mine
                                                disabled: false,
                                                module: 'MMM-NOAA',
                                                position: 'top_left',
                                                    apiKey: "MY API KEY", // https://www.wunderground.com/weather/api  select the middle plan...
                                                    airKey: "MY AIR KEY", // IF you want Air Quality Index
                                                    pws1: "KNYNEWYO103", // go here to find your pws: https://www.wunderground.com/wundermap
                                                    animationSpeed: 0,
                                    • cowboysdudeC
                                      cowboysdude Module Developer @evroom
                                      @evroom Yes that used to be true…the readme is wrong, sorry. The old weather used to be wunderground and since they quit their free api I had to use a different provider and it works for one location only.
                                      There is no longer a need to use “PWS”…as the new api doesn’t use that. That’s an old wunderground requirement.
                                      At the moment this is all that’s required to make it work…
                                                  disabled: false,
                                                  module: 'MMM-NOAA',
                                                  	apiKey: "xxxxxx",
                                      		airKey: "xxxxx"
                                      I am also working to eliminate the airKey in that version…
                                      • evroomE
                                        evroom
                                        @cowboysdude
                                        Thanks for answering (@Mykle1 too).
                                        It is working, with just the apiKey in the config, but where does it take the location from?
                                        You say it works for one location only, is that a location I can determine, or is it a location that is hard coded somewhere?
                                        I like the temperatures it is showing, but is the weather I can expect in my location? :-)
                                        • Mykle1M
                                          @evroom
                                          Ok, my bad on my previous answer. My apologies. :-/
                                          At the risk of answering in error again, I will say that the module determines your location (geo-location or some such)
                                          • cowboysdudeC
                                            @evroom It automatically gets the latitude and longitude and uses that :)
                                            • 3 / 4
