B&W themed hallway mirror with 32” display
17 Posts 10 Posters 18.8k Views 10 Watching
    dmd
    I’ve been lurking in the forums and now I present you my mirror:
    You can find more pictures and details on Google photos
    (There’s comment on every photo)
    This mirror has been in the making for the last 6 months or so. I purchased Rpi 3 for 20 euros (25 dollars) on last black friday, 24th October 2017. At first I thought what to do with it. I was tempted to have some sort of screen where I could see what’s playing on Spotify while making food and such so I don’t have to unlock iPad or phone everytime for this. I didn’t have any suitable space in my living room. I remembered I had read about MagicMirror sometime earlier and that was it. I had hallway mirror in the hallway and that seemed to be the only place where I could ”hide” the display. Luckily while making the mirror MMM-NowPlayingOnSpotify module was released :winking_face: :headphone:
    This started search for display for at least 30” at around christmas time. The idea was to put it in vertical position at top of the mirror while covering the whole upper area and being wide enough so that I could see my whole upper body on the mirror. Of course it had to be as bright as possible while being thin at the same time. After about one month of search I found used 32” LG signage series info display, 32WL30MS-B.
    Next I had to find suitable frame. I didn’t want the mirror to stand out really and the goal was to make it look as any standard mirror while hiding the thickness of the display, 3,56 cm. I found planing mill which seemed to have pretty perfect frame for my display and it just needed some cuts with circular saw at the back side to fit it in. Sorry, I don’t have any pictures for the cutting part. Yes, the frame is pretty massive, it’s 5,8 cm thick and 4 meters of frame weights 5,5 kg all alone!
    I’m from Finland and here we have sauna in almost every building. I thought it would be cool to have the temperature shown in the mirror. Luckily I found out that MMM-temp-ds18b20 module was perfect for this. DS18B20 sensors can handle 125C temperatures so I wired one of them to the sauna which is behind the mirror. The other one lies at the bottom of the mirror showing the hallway temperature.
    More pictures:
    These modules are installed (at the time of writing):
    top
    clock
    MMM-AlexaPi (AlexaPi as core)
    currentweather
    MMM-temp-ds18b20
    weatherforecast
    mid
    compliments
    bottom
    MMM-Carousel, switching the following
    calendar_monthly
    MMM-quote-of-the-day
    MMM-Formula1
    MMM-GoogleFit
    newsfeed
    and
    MMM-PIR-Sensor
    Screenshots:
    Feel free to comment or ask questions!
    M 1 Reply Last reply Jun 24, 2018, 12:32 AM Reply Quote 7
      Mykle1 Project Sponsor Module Developer @dmd
      @dmd
      Well done, young man!
      • K Offline
        Kimzer
        Looks pretty damned awesome! Well done!
        Did u loosen the pir sensor from the board? Clever, havent thought of that!
          dmd
          @Mykle1 Not sure if I’m that young anymore but thank you Mykle1! :slightly_smiling_face:
          @Kimzer Yes, the pir sensor was removed from the board and soldered to the wires. I didn’t want the wires to be too long however.
          M 1 Reply Last reply Jun 25, 2018, 1:55 AM Reply Quote 0
            @dmd said in B&W themed hallway mirror with 32” display:
            I see your reflection in your mirror. You’re young. :-)
              justjim1220 Module Developer
              Very Nice!!! Love it!!!
              "Life's Too Short To Dance With Ugly People"
              Jim Hallock - 1995
                canadrian
                Great job!
                • G Offline
                  gashion
                  Hieno peili!
                  Onko ollut mitään ongelmia ohjelmiston asennuksen kanssa?
                  D 1 Reply Last reply Jul 3, 2018, 8:34 AM Reply Quote 0
                    dmd @gashion
                    @gashion said in B&W themed hallway mirror with 32” display:
                    Hieno peili!
                    Kiitos! MagicMirror asentui automaattiasennuksella ja kaikki modulit ongelmitta. Raspbian Strechin asennukseen käytin Etcheriä
                    Perusasennukseen käytin tätä ohjetta:
                    https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                    Strech päivittynyt hieman tuon jälkeen eli valikot löytyy hieman eri kohdista. OpenWeatherMap ei tietääkseni jaa enää ilmaisia api avaimia eli sääennusteen saamisesta toimimaan tällä hetkellä en osaa sanoa.
                    *Same in English. Did you had any problems installing the software?
                    No, MagicMirror software installed with automatic install. For Raspian Strech I used Etcher image tool. All the modules installed with no problem. Not sure if you can get weather forecast working at the moment as OpenWeatherMap doesn’t provide free api keys anymore. *
                    G 1 Reply Last reply Sep 7, 2018, 10:12 AM Reply Quote 0
                    • AnubisFA Offline
                      AnubisF
                      Moi,
                      Mitä peiliä sinä käytit, tavalinen tai olet tilannut joku erikoista ?
                      D 1 Reply Last reply Jul 16, 2018, 8:38 AM Reply Quote 0
