    Run MM on Ubuntu 16 VM
    31 Posts 11 Posters 33.7k Views 10 Watching
      pepemujica
      Hi everyone!
      I’m looking foward to start developing the MM, but at the moment in my country I can’t get a raspi.
      Is it any chance to start trying on a ubuntu 16 VM?
      Kind regards
      • Y Offline
        yawns Moderator
        Of course. You can also run it on a Windows machine or a Mac. It won’t run “out of the box” as it does on raspbian, but it works
          pepemujica
          @yawns Great! And is there any step by step guide for noobs like me?
            Mykle1 Project Sponsor Module Developer @pepemujica
            @pepemujica said in Run MM on Ubuntu 16 VM:
            Follow the Manual Installation instructions on this page: About half way down the page:
            https://github.com/MichMich/MagicMirror
            It worked for me. I installed uBuntu on a laptop and then installed MagicMirror using those directions.
              pepemujica
              Hi @Mykle1 Thanks for the answer.
              I’ve started following the instructions, but I get the following error:
              0_1490032831021_upload-627b7d7b-12f7-443e-b447-8750893adc5b
              0_1490032896329_upload-f0ae1e26-6c2e-4c9d-a476-149c808e2b85
              Any idea why?
              Mykle1M A HrierebH 3 Replies Last reply Reply Quote 0
                Any idea why?
                This is just a guess but I think I remember hearing that MagicMirror has to be installed in your Home directory. I see that you installed it in /home/christain/.
                You can try the process again (if you want to) but install MagicMirror as soon as you open a new terminal. Don’t change directories.
                I hope this helps
                  pepemujica
                  @Mykle1 still having the same problem :(
                    @pepemujica
                    Ok, someone will help you at some point. I don’t know if it matters but I’m running uBuntu 16.04 LTS, not as a VM
                      amanzimdwini @pepemujica
                      @pepemujica
                      run sudo npm install in MagicMirror
                        rtlucht78 @Mykle1
                        @Mykle1 Did you get this to work on your device running Ubuntu 16.04? I am trying this on an old tablet running Ubuntu Mate 16.04.
                          Mykle1 Project Sponsor Module Developer @rtlucht78
                          @rtlucht78
                          Yes, I have one laptop running ubuntu 16.04 and a netbook running ubuntu 14.04. Both are running MM
                          • HrierebH Offline
                            Hriereb @pepemujica
                            Any idea why?
                            I have the same kind of issue on ubuntu 18.04, did someone fix it? When someone says that it doesn’t run out of the box, what does this means?
                              AxLed Module Developer @Hriereb
                              @Hriereb
                              Did you install “npm” and “node” as this sometimes isnt installed at ubuntu by default?
                              AxLED
                              HrierebH 1 Reply Last reply Reply Quote 0
                              • HrierebH Offline
                                Hriereb @AxLed
                                @axled yes I did but nothing changed. Do you have to make it work on a virtual machine? How to enable it on Ubuntu?
                                • justjim1220J Offline
                                  justjim1220 Module Developer
                                  @Mykle1
                                  ok, I now have both Ubuntu versions 16.04 and 18.04 up and running…
                                  I have Chrome, node.js, npm, & git installed…
                                  I have MagicMirror installed…
                                  Getting the following error with both versions…
                                  log file…
                                  1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                  2 info using npm@3.5.2
                                  3 info using node@v8.10.0
                                  5 info lifecycle magicmirror@2.4.1~prestart: magicmirror@2.4.1
                                  6 silly lifecycle magicmirror@2.4.1~prestart: no script for prestart, continuing
                                  7 info lifecycle magicmirror@2.4.1~start: magicmirror@2.4.1
                                  8 verbose lifecycle magicmirror@2.4.1~start: unsafe-perm in lifecycle true
                                  9 verbose lifecycle magicmirror@2.4.1~start: PATH: /usr/share/npm/bin/node-gyp-bin:/home/wes/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
                                  10 verbose lifecycle magicmirror@2.4.1~start: CWD: /home/wes/MagicMirror
                                  11 silly lifecycle magicmirror@2.4.1~start: Args: [ '-c', 'sh run-start.sh' ]
                                  12 info lifecycle magicmirror@2.4.1~start: Failed to exec start script
                                  13 verbose stack Error: magicmirror@2.4.1 start: `sh run-start.sh`
                                  13 verbose stack spawn ENOENT
                                  13 verbose stack     at ChildProcess.<anonymous> (/usr/share/npm/lib/utils/spawn.js:17:16)
                                  13 verbose stack     at emitTwo (events.js:126:13)
                                  13 verbose stack     at ChildProcess.emit (events.js:214:7)
                                  13 verbose stack     at maybeClose (internal/child_process.js:925:16)
                                  13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                                  14 verbose pkgid magicmirror@2.4.1
                                  15 verbose cwd /home/wes/MagicMirror
                                  16 error Linux 4.15.0-29-generic
                                  17 error argv "/usr/bin/node" "/usr/bin/npm" "start"
                                  18 error node v8.10.0
                                  19 error npm  v3.5.2
                                  20 error file sh
                                  21 error code ELIFECYCLE
                                  22 error errno ENOENT
                                  23 error syscall spawn
                                  24 error magicmirror@2.4.1 start: `sh run-start.sh`
                                  24 error spawn ENOENT
                                  25 error Failed at the magicmirror@2.4.1 start script 'sh run-start.sh'.
                                  25 error Make sure you have the latest version of node.js and npm installed.
                                  25 error If you do, this is most likely a problem with the magicmirror package,
                                  25 error not with npm itself.
                                  25 error Tell the author that this fails on your system:
                                  25 error     sh run-start.sh
                                  25 error You can get information on how to open an issue for this project with:
                                  25 error     npm bugs magicmirror
                                  25 error Or if that isn't available, you can get their info via:
                                  25 error     npm owner ls magicmirror
                                  25 error There is likely additional logging output above.
                                  26 verbose exit [ 1, true ]
                                  Got any ideas?
                                  Jim Hallock - 1995
                                  N Mykle1M 2 Replies Last reply Reply Quote 0
                                  • N Offline
                                    NoNameRo @justjim1220
                                    @justjim1220 said in Run MM on Ubuntu 16 VM:
                                    Upgrade npm with
                                    npm install -g npm@latest
                                      Mykle1 Project Sponsor Module Developer @justjim1220
                                      Got any ideas?
                                      Why are you using sudo npm start? You shouldn’t use sudo to install MM or run MM. That can lead to problems. Also, it shouldn’t matter but for the sake of conformity I always install MM in the home directory
                                      justjim1220J 2 Replies Last reply Reply Quote 0
                                        justjim1220 Module Developer @Mykle1
                                        @mykle1
                                        so I have everything now installed in the root but still getting nowhere with getting the mirror to start up and run…:worried_face:
                                        Jim Hallock - 1995
                                          @mykle1
                                          Still getting this…
                                          doesn’t matter if i’m in Ubuntu 16.04 OR 18.04
                                          and it doesn’t matter if I’m in home directory OR the root directory…
                                          is there a different way to run MM other than ‘npm start’?
                                          Jim Hallock - 1995
                                            @justjim1220
                                            did you try to start the “Server only” mode an open a browser on Ubuntu with IP of your MM?
                                            To start Server only do node serveronly in your MagicMirror directory.
                                            Maybe this helps to find the problem.
                                            AxLED
                                            justjim1220J 1 Reply Last reply Reply Quote 1
