    Run MM on Ubuntu 16 VM
    31 Posts 11 Posters 33.6k Views 10 Watching
    • HrierebH Offline
      Hriereb @pepemujica
      @pepemujica said in Run MM on Ubuntu 16 VM:
      Hi @Mykle1 Thanks for the answer.
      I’ve started following the instructions, but I get the following error:
      0_1490032831021_upload-627b7d7b-12f7-443e-b447-8750893adc5b
      0_1490032896329_upload-f0ae1e26-6c2e-4c9d-a476-149c808e2b85
      Any idea why?
      I have the same kind of issue on ubuntu 18.04, did someone fix it? When someone says that it doesn’t run out of the box, what does this means?
        AxLed Module Developer @Hriereb
        @Hriereb
        Did you install “npm” and “node” as this sometimes isnt installed at ubuntu by default?
        AxLED
        HrierebH 1 Reply Last reply Reply Quote 0
        • HrierebH Offline
          Hriereb @AxLed
          @axled yes I did but nothing changed. Do you have to make it work on a virtual machine? How to enable it on Ubuntu?
          • justjim1220J Offline
            justjim1220 Module Developer
            @Mykle1
            ok, I now have both Ubuntu versions 16.04 and 18.04 up and running…
            I have Chrome, node.js, npm, & git installed…
            I have MagicMirror installed…
            Getting the following error with both versions…
            log file…
            1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
            2 info using npm@3.5.2
            3 info using node@v8.10.0
            5 info lifecycle magicmirror@2.4.1~prestart: magicmirror@2.4.1
            6 silly lifecycle magicmirror@2.4.1~prestart: no script for prestart, continuing
            7 info lifecycle magicmirror@2.4.1~start: magicmirror@2.4.1
            8 verbose lifecycle magicmirror@2.4.1~start: unsafe-perm in lifecycle true
            9 verbose lifecycle magicmirror@2.4.1~start: PATH: /usr/share/npm/bin/node-gyp-bin:/home/wes/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
            10 verbose lifecycle magicmirror@2.4.1~start: CWD: /home/wes/MagicMirror
            11 silly lifecycle magicmirror@2.4.1~start: Args: [ '-c', 'sh run-start.sh' ]
            12 info lifecycle magicmirror@2.4.1~start: Failed to exec start script
            13 verbose stack Error: magicmirror@2.4.1 start: `sh run-start.sh`
            13 verbose stack spawn ENOENT
            13 verbose stack     at ChildProcess.<anonymous> (/usr/share/npm/lib/utils/spawn.js:17:16)
            13 verbose stack     at emitTwo (events.js:126:13)
            13 verbose stack     at ChildProcess.emit (events.js:214:7)
            13 verbose stack     at maybeClose (internal/child_process.js:925:16)
            13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
            14 verbose pkgid magicmirror@2.4.1
            15 verbose cwd /home/wes/MagicMirror
            16 error Linux 4.15.0-29-generic
            17 error argv "/usr/bin/node" "/usr/bin/npm" "start"
            18 error node v8.10.0
            19 error npm  v3.5.2
            20 error file sh
            21 error code ELIFECYCLE
            22 error errno ENOENT
            23 error syscall spawn
            24 error magicmirror@2.4.1 start: `sh run-start.sh`
            24 error spawn ENOENT
            25 error Failed at the magicmirror@2.4.1 start script 'sh run-start.sh'.
            25 error Make sure you have the latest version of node.js and npm installed.
            25 error If you do, this is most likely a problem with the magicmirror package,
            25 error not with npm itself.
            25 error Tell the author that this fails on your system:
            25 error     sh run-start.sh
            25 error You can get information on how to open an issue for this project with:
            25 error     npm bugs magicmirror
            25 error Or if that isn't available, you can get their info via:
            25 error     npm owner ls magicmirror
            25 error There is likely additional logging output above.
            26 verbose exit [ 1, true ]
            Got any ideas?
            Jim Hallock - 1995
            N Mykle1M 2 Replies Last reply Reply Quote 0
            • N Offline
              NoNameRo @justjim1220
              @justjim1220 said in Run MM on Ubuntu 16 VM:
              Upgrade npm with
              npm install -g npm@latest
                Mykle1 Project Sponsor Module Developer @justjim1220
                Got any ideas?
                Why are you using sudo npm start? You shouldn’t use sudo to install MM or run MM. That can lead to problems. Also, it shouldn’t matter but for the sake of conformity I always install MM in the home directory
                justjim1220J 2 Replies Last reply Reply Quote 0
                  justjim1220 Module Developer @Mykle1
                  @mykle1
                  so I have everything now installed in the root but still getting nowhere with getting the mirror to start up and run…:worried_face:
                  Jim Hallock - 1995
                    @mykle1
                    Still getting this…
                    doesn’t matter if i’m in Ubuntu 16.04 OR 18.04
                    and it doesn’t matter if I’m in home directory OR the root directory…
                    is there a different way to run MM other than ‘npm start’?
                    Jim Hallock - 1995
                      @justjim1220
                      did you try to start the “Server only” mode an open a browser on Ubuntu with IP of your MM?
                      To start Server only do node serveronly in your MagicMirror directory.
                      Maybe this helps to find the problem.
                      AxLED
                      justjim1220J 1 Reply Last reply Reply Quote 1
                        A Former User @justjim1220
                        @justjim1220
                        try this.
                        sudo apt-get install libgconf-2-4
                          justjim1220 Module Developer @AxLed
                          @axled
                          Thanks, that worked!!!
                          :winking_face: :winking_face: :smiling_face: :smiling_face: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :smiling_face_with_sunglasses: :smiling_face_with_sunglasses:
                          Jim Hallock - 1995
                            reitrac
                            Hello everyone,
                            3months later, I hope it’s not too late :)
                            @AxLed i’m trying to use “node serveronly” but have this error :
                            WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                            I followed @Mykle1 tutorial to create default config.js but this not works.
                            Any idea ? (My internet connection works)
                            Thanks.
                              A Former User @reitrac
                              @reitrac
                              Your config.js might have some misspell or wrong syntax.
                                reitrac
                                My config.js is by default :D
                                I just changed “en” by “fr”.
                                I’ll try to find config.js on Git and come back to you.
                                Thanks.
                                EDIT :
                                I downloaded the latest config.js from : https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
                                And not works :'(
                                Mykle1M ? justjim1220J 3 Replies Last reply Reply Quote 0
                                  Mykle1 Project Sponsor Module Developer @reitrac
                                  @reitrac
                                  /* Magic Mirror Config Sample
                                   * MIT Licensed.
                                  var config = {
                                  	port: 8080,
                                  	language: "en",
                                  	timeFormat: 24,
                                  	units: "metric",
                                  			module: "alert",
                                  			module: "updatenotification",
                                  			position: "top_bar"
                                  			module: "clock",
                                  			position: "top_left"
                                  			header: "US Holidays",
                                  						symbol: "calendar-check-o ",
                                  			module: "compliments",
                                  			position: "lower_third"
                                  			module: "currentweather",
                                  				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                                  			module: "weatherforecast",
                                  			header: "Weather Forecast",
                                  				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                  			module: "newsfeed",
                                  			position: "bottom_bar",
                                  				feeds: [
                                  						title: "New York Times",
                                  				showSourceTitle: true,
                                  				showPublishDate: true
                                    @reitrac
                                    I can bet you have missed comma after language:"fr". 95% of syntax error was that thing in my case. :D
                                      reitrac
                                      @Mykle1 @Sean Didn’t works with the default config … I don’t know why.
                                        justjim1220 Module Developer @reitrac
                                        @reitrac
                                        Did you change the name of the config file from ‘config.js.sample’ to ‘config.js’ ?
                                        Jim Hallock - 1995
                                          reitrac
                                          @justjim1220 Yeah of course :)
                                          I followed @Mykle1 tutorial.
                                          EDIT :
                                          If can help, I’m using VirtualBox on MAC with UBUNTU 16.04 LTS
                                            reitrac
                                            Hey,
                                            i tried tu remove and reinstall MM.
                                            Here is the new error :
                                            VirtualBox:~/MagicMirror$ node serveronly/
                                            module.js:328
                                                throw err;
                                            Error: Cannot find module 'express'
                                                at Function.Module._resolveFilename (module.js:326:15)
                                                at Function.Module._load (module.js:277:25)
                                                at Module.require (module.js:354:17)
                                                at require (internal/module.js:12:17)
                                                at Object.<anonymous> (/home/monagraphic/MagicMirror/js/server.js:8:15)
                                                at Module._compile (module.js:410:26)
                                                at Object.Module._extensions..js (module.js:417:10)
                                                at Module.load (module.js:344:32)
                                                at Function.Module._load (module.js:301:12)
                                            Some one can help me ?
                                            EDIT :
                                            It works, i launch a second time “npm install”.
