    Run MM on Ubuntu 16 VM
    31 Posts 11 Posters 32.7k Views 10 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @Mykle1
      @mykle1
      Still getting this…
      doesn’t matter if i’m in Ubuntu 16.04 OR 18.04
      and it doesn’t matter if I’m in home directory OR the root directory…
      is there a different way to run MM other than ‘npm start’?
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
        AxLed Module Developer
        @justjim1220
        did you try to start the “Server only” mode an open a browser on Ubuntu with IP of your MM?
        To start Server only do node serveronly in your MagicMirror directory.
        Maybe this helps to find the problem.
        AxLED
        justjim1220J 1 Reply Last reply Reply Quote 1
          A Former User @justjim1220
          @justjim1220
          try this.
          sudo apt-get install libgconf-2-4
            justjim1220 Module Developer @AxLed
            @axled
            Thanks, that worked!!!
            :winking_face: :winking_face: :smiling_face: :smiling_face: :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes: :smiling_face_with_sunglasses: :smiling_face_with_sunglasses:
            Jim Hallock - 1995
              reitrac
              Hello everyone,
              3months later, I hope it’s not too late :)
              @AxLed i’m trying to use “node serveronly” but have this error :
              WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
              I followed @Mykle1 tutorial to create default config.js but this not works.
              Any idea ? (My internet connection works)
              Thanks.
                A Former User @reitrac
                @reitrac
                Your config.js might have some misspell or wrong syntax.
                  reitrac
                  My config.js is by default :D
                  I just changed “en” by “fr”.
                  I’ll try to find config.js on Git and come back to you.
                  Thanks.
                  EDIT :
                  I downloaded the latest config.js from : https://github.com/MichMich/MagicMirror/blob/master/config/config.js.sample
                  And not works :'(
                  Mykle1M ? justjim1220J 3 Replies Last reply Reply Quote 0
                    Mykle1 Project Sponsor Module Developer @reitrac
                    @reitrac
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "US Holidays",
                    						symbol: "calendar-check-o ",
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "currentweather",
                    				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                    			module: "weatherforecast",
                    			header: "Weather Forecast",
                    				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                    				showSourceTitle: true,
                    				showPublishDate: true
                      @reitrac
                      I can bet you have missed comma after language:"fr". 95% of syntax error was that thing in my case. :D
                        reitrac
                        @Mykle1 @Sean Didn’t works with the default config … I don’t know why.
                          justjim1220 Module Developer @reitrac
                          @reitrac
                          Did you change the name of the config file from ‘config.js.sample’ to ‘config.js’ ?
                          Jim Hallock - 1995
                            reitrac
                            @justjim1220 Yeah of course :)
                            I followed @Mykle1 tutorial.
                            EDIT :
                            If can help, I’m using VirtualBox on MAC with UBUNTU 16.04 LTS
                              reitrac
                              Hey,
                              i tried tu remove and reinstall MM.
                              Here is the new error :
                              VirtualBox:~/MagicMirror$ node serveronly/
                              module.js:328
                                  throw err;
                              Error: Cannot find module 'express'
                                  at Function.Module._resolveFilename (module.js:326:15)
                                  at Function.Module._load (module.js:277:25)
                                  at Module.require (module.js:354:17)
                                  at require (internal/module.js:12:17)
                                  at Object.<anonymous> (/home/monagraphic/MagicMirror/js/server.js:8:15)
                                  at Module._compile (module.js:410:26)
                                  at Object.Module._extensions..js (module.js:417:10)
                                  at Module.load (module.js:344:32)
                                  at Function.Module._load (module.js:301:12)
                              Some one can help me ?
                              EDIT :
                              It works, i launch a second time “npm install”.
