    [MMM-OnScreenMenu] Simple On-Screen Menu for controlling the MagicMirror²
    25 Posts 15 Posters 25.6k Views 19 Watching
    • cowboysdudeC Offline
      I’ll have to test that on my touch screen ;)
      Looks great!
        shbatm Module Developer
        New version posted with expanded options:
        Version 0.1.3
        • Added menu options for minimizing, toggle fullscreen mode, opening DevTools, stopping MM via PM2,
        • Added delayed menu items (e.g. call a function after a certain timeout–like to turn off the mirror after X seconds)
        • Added external control of the menu/functions from other modules via notifications–includes the ability to call any function the module knows how to handle, even if it’s not in the menu. This lets you use modules like MMM-Buttons or MMM-MPR121 to control the menu.
        See the full details of everything the menu can do on the GitHub README:
        [card:shbatm/MMM-OnScreenMenu]
        Remember to re-run npm install after updating:
        cd ~/MagicMirror/modules/MMM-OnScreenMenu
        git pull
        npm install
        Mykle1M 1 Reply Last reply Reply Quote 3
        • cruunnerrC Offline
          cruunnerr
          Thats pretty cool. Now i could install a button for each menu option :)
          I like buttons. so i like this module. lol ^^
          Impressive work. Thank you very much.
            Mykle1 Project Sponsor Module Developer @shbatm
            @shbatm
            Don’t know how I missed this one. Excellent work, sir! :-)
              M1K3rSz
              Really cool module , i’ve installed it, looks great!
              But ummzzzh i’ve touched on the button Turn off Display, but after a restart mirror shows no display , maybe a stupid question but how can i turn it on again?
                @M1K3rSz – Glad you tried it! Sorry you ran into some trouble.
                To get the monitor back on:
                1. Via ssh: tvservice --preferred && sudo chvt 6 && sudo chvt 7
                  • Sets the HDMI output back on to preferred settings, then changes the virtual terminal off of then back on to the desktop channel. This is the same command that most modules that turn on the monitor uses.
                2. Via notification sent from another module, such as MMM-Remote-Control:
                  • Notification: ‘ONSCREENMENU_PROCESS_ACTION’,
                    Payload: { actionName:‘monitorOn’ }
                The Monitor Off menu item is best used when you have another module that wakes up the mirror (PIR sensor, button, etc.).
                  M1K3rSz @shbatm
                  @shbatm thanks for the quick reply, ive got it work again ;)
                    sharmstr Project Sponsor
                    Is there a way to disable hovering all together? I’m using an IR frame and while it does work, the issue is with hovering and closing the menu. Clicking the close (X) icon doesnt work because the cursor is still hovering over the menu, therefore keeping the menu open. You need to click somewhere else on the screen to get it to close. I looked for a way to disable hovering all together since I think that will solve the issue, but couldnt find a way.
                      dylan
                      Hi, is there any way to register multiple items in a single button?
                      Something such as (and I’ve tried this ;) )…
                      moduleToggle1: {
                          title: "TL> Clock etc",
                          icon: "eye-slash",
                          names: {
                      Sorry if this is obvious, just a noob here!! Either way - this is an amazing plugin!!!
                        alifsuria @cowboysdude
                        @cowboysdude are you creating touchscreen magic mirror?can you teach me?are you using raspbian or window 10 iot core?i saw a video that magic mirror touchscreen with menu and gesture for volume etc…i dont know where to start…please help
                          MODULE UPDATED
                          This module has been updated to Version 0.2.1 in the develop channel.
                          Major Changes:
                          • Removed all of the server-side functions in favor of using MMM-Remote-Control pending PR#104. When using this version, you will need to also have MMM-Remote-Control Version 2.0.0 or above installed for all functions to work. This is a strategic move to allow simplification of this module and focus on the front-end, while MMMRC handles the heavy lifting on the back-end.
                          • You can now use MMMRC as a menu item, or the whole menu:
                          Once the pull request is accepted for MMM-Remote-Control, this will be merged into the master branch.
                            bugman61
                            Thanks for the great module, it has solved a lot of the issues I had when I was using carousel to organize my modules.
                            Is there a way to set a default hidden/displayed for each module in the menu when starting? I have my MM set up with the clock and a photo slideshow to always be displayed, and then I have 4 ModuleToggles set to show other information when needed (calendar, weather, etc). I would like to be able to start MM with these other modules hidden as opposed to having everything open automatically and having to close each one manually. Alternatively a timer to close modules automatically after XX seconds would work as well. That would also allow us to open a module and see the info and walk away without having to close it manually.
                              shbatm Module Developer @bugman61
                              @bugman61 said in [MMM-OnScreenMenu] Simple On-Screen Menu for controlling the MagicMirror²:
                              My recommendation would be to use something like MMM-Carousel w/ Navigation to put everything in different slides. You can set the timeout to 0 to keep it on the slide you have chosen, and then add menu items to jump to each slide (this is what I use on one of my mirrors, combined with MMM-KeyBindings to allow control from a bluetooth remote).
                              You can look at MMM-Module-Scheduler to implement this now, or create an issue on GitHub for this module and when I get a chance, I will add the ability to allow multiple actions assigned to a single menu item. This module already has the ability to send delayed actions–multiple actions would allow you to (1) send a switch to slide X action and then a (2) delayed action–after x seconds switch back to home slide.
                                bugman61 @shbatm
                                @shbatm said in [MMM-OnScreenMenu] Simple On-Screen Menu for controlling the MagicMirror²:
                                This is how I initially had by mirror set up. However I ran into issues with a php form I had in MMM-iFrame-Ping not working correctly. The form worked fine displayed on its own, but I was never able to get the submit buttons to work properly when it was a part of the Carousel. That led me to your module where the form has worked perfectly.
                                  robiv8
                                  Beginner question!
                                  With the module “Remote Control” you enter the address in the browser xxx:8080/remote.html
                                  Then you have the menu.
                                  How does it work with OnScreenMenu, or does not work there.
                                    shbatm Module Developer @robiv8
                                    @robiv8 OnScreenMenu puts a little floating button on your mirror (either visible always, or only visible when you hover over that corner) and gives you a menu on the mirror’s screen itself. The new version has an option to use MMM-Remote-Control and basically takes a small mini version of the “/remote.html” page and puts it in an iFrame on the MIrror’s screen.
                                    Basically – Remote Control is a remote (phone, another computer, etc.) and OSM is for the actual mirror, if you have a touchscreen, or use a mouse, keyboard, or physical remote (w/ MMM-KeyBindings).
                                      robiv8
                                      Thanks for the explanation
                                        mrcpu55
                                        I just installed Magic Mirror and still learning all the idiosyncrasies of the system. I installed the OnScreenMenu (stable) version and I just found this forum topic. I see there is a new version in the developer channel.
                                        Can I install the developer version (0.2) on top of the current version? How would I completely remove the older version if I have to?
                                        Thanks for all the great work!
                                          Mykle1 Project Sponsor Module Developer @mrcpu55
                                          @mrcpu55 said in [MMM-OnScreenMenu] Simple On-Screen Menu for controlling the MagicMirror²:
                                          You can simply rename the current folder in the MagicMirror/modules folder. Then install the developer version. If that works well for you then you can delete the previous folder that you renamed. If the new version does not work for you then you can remove the new version folder and rename the previous version folder back to the way it was.
                                            mrcpu55
                                            Thanks for the quick reply! I will try this out.
