    MMM-Gas
    56 Posts 13 Posters 44.5k Views 12 Watching
    • richland007R
      richland007 @3d
      @3d thank you for the tip did not know that …and of course i would get values, i am in the middle of Dallas and Plano what was i thinking LOL… and i also get values for Costco and Sams that i asked a few posts above…so that’s a good thing cause we always use those 99% of the time as a small business.
      Anyhow the issue remains just “Updating…”
      D
      3 1 Reply Last reply Reply Quote 0
        3d @richland007
        @richland007 Excellent. I am having the same issue as well and can’t figure it out yet.
        BTW, I lived in Plano as well…actually graduated from Univ Texas Dallas and Baylor Law. Plano is a great place. Glad I could help a bit.
        • cowboysdudeC
          Yes they’ve changed their page so the data it’s asking for is incorrect. I will fix it when I can get some time to do it… Sorry everyone.
            mochman Module Developer
            @cowboysdude I just sent you a pull request that should fix their new page.
            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 2
            • cowboysdudeC
              cowboysdude Module Developer @mochman
              @mochman said in MMM-Gas:
              I got it and it’s been merged!! HUGE Thank you for fixing this…time is killing me right now :)
              "You can now get fuel data for regular (default), mid-grade, premium, and diesel. I also threw in a way to sort by price or distance (default). I saw you had an items variable in the default config section as well. I assume that was to only show X number of items. I added that to your for loop that iterates through the gas array. "
              He not only fixed it but enhanced it to make it 100% even better! Here’s an example config:
                        disabled: false,
                        module: "MMM-Gas",
                           zip: "14904",
                           items: 10,
                           typeGas: "",	//premium, mid-grade, diesel, or blank for regular
                           sortBy: "price" 	//distance, price
              See the // notes for added features! Thank you again @mochman
              Do a git pull to update and update your config accordingly :)
              3 1 Reply Last reply Reply Quote 1
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @mochman
                Well done, sir! Well done!
                  3d @cowboysdude
                  @cowboysdude and @mochman … WOW, nice work!
                  The only thing I had to fix was put the ITEMS in quotes…the proper syntax for me was:
                  items: "10",
                    mochman Module Developer @3d
                    @3d Hmm, the code is supposed to use that variable as an integer. What kind of error were you getting when you had items: 10,?
                    Edit: Guess it doesn’t matter. Math.min() still works using a string.
                      3d @mochman
                      @mochman It wasn’t loading the config.js. So I just stepped through line by line until if failed. Once if failed I put the 10 in quotations and it loaded.
                      • justjim1220J
                        justjim1220 Module Developer
                        Ok, so I deleted my current GAS module. and reinstalled it.
                        I went to the website to check my zip code, which is good.
                        I tried it with & without the quotes around the 10.
                        Still not working for me… :slightly_frowning_face:
                        Jim Hallock - 1995
                        • justjim1220J
                          NVM!!!
                          When in doubt, Reboot it out!!!
                          :smiling_face_with_sunglasses:
                          Jim Hallock - 1995
                            rob73
                            Is there any way to remove the Distance column? I live in a small town and dont really need the distances on the display. I hunted around the files a little bit and didnt see anything that I could maybe edit or delete that would remove it.
                            Rob
                              @rob73 I haven’t tried this to see how it looks, but you may just be able to comment out a few of the lines in MMM-Gas.js
                              Try commenting out the last 2 lines of this code in the getDom() function.
                               var td5 = document.createElement("td");
                               td5.innerHTML = dist;
                               TDrow.appendChild(td5);
                               weatherTable.appendChild(TDrow);
                              It should look like this when you’re done.
                              //TDrow.appendChild(td5);
                              //weatherTable.appendChild(TDrow);
                              You should also comment out this part as well.
                              var bjumpy = document.createElement("th");
                              bjumpy.setAttribute("style", "text-align:center");
                              bjumpy.classList.add("xsmall");
                              bjumpy.innerHTML = "Distance";
                              //xFCRow.appendChild(bjumpy);
                              //weatherTable.appendChild(xFCRow);
                                rob73 @mochman
                                @mochman … Awesome… I followed your instructions and it worked! Thank you! I would have never figured that out on my own…
                                Thanks again!
                                Rob
                                • cowboysdudeC
                                  New config option to hide or show distance column.
                                  example config:
                                            disabled: false,
                                            module: "MMM-Gas",
                                               zip: "14904",
                                               items: 10,
                                               sortBy: "price", 	//distance, price
                                         distance: false //default is true, so using true just don't use distance in your config
                                  DO a git pull in the MagicMirror/modules/MMM-Gas dir to update!
                                  AND a HUGE Thanks to @mochman for all the help!!!
                                  • Mykle1M
                                    @cowboysdude
                                    Thanks. I really like this module alot. Very nice options and I love the mouse overs. Fantastic work! :thumbsup:
                                      rob73
                                      Awesome!
                                      • richland007R
                                        richland007
                                        Is this still working?? It was working flawlessly for me before but i turned the MM off for like 3 months when i was doing some work around the house and when i turned it back on i do not see anything on my list of gas stations.
                                        It just says updated at this time and date but nothing listed.
                                        I did a git pull thinking that something might have been updated in those 3 months but nothing changed.
                                        Anyone else experiencing difficulties ???
                                        D
                                        Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 0
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @richland007
                                          @richland007 said in MMM-Gas:
                                          I just did a git pull on my current installation and everything seems to be working just fine.
                                          Have you made any modifications? Are there any errors being reported in the terminal or dev console?
                                          • cowboysdudeC
                                            cowboysdude Module Developer @richland007
                                            @richland007 Do a git pull as things did change and I updated it a month ago or so.
