    My 42" multitouch Philips MagicMirror Display
    19 Posts 9 Posters 23.5k Views 9 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @M1K3rSz
      @M1K3rSz
      Nice work, sir. :-)
        M1K3rSz @Mykle1
        @Mykle1 thanks ;)
        i know , i ordered a usb microphone when it wil arrive i wil try lucy for sure!!
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @M1K3rSz
          Fantastic! Let me know how it goes. :-)
          • Cyberdale008C
            Cyberdale008
            Looks very nice!! Interested how your touch screen works out.
            • emloweE
              emlowe Module Developer
              Hello-Lucy is unlikely to work well on an rpi though, correct? At least this is my understanding…
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @emlowe
                @emlowe said in My 42" multitouch Philips MagicMirror Display:
                It will work . . . with some latency. Depends on what you consider an adequate response time. You can NOT use the animated face. This will certainly bring the Pi to a halt. :-/
                • V
                  viren_nitin
                  Heey @M1K3rSz ik heb een vraagje, ik kom zelf ook uit Den Haag en ik probeer bustimes op mijn MM2 te zetten, alleen lukt het me niet. Ik kan de timepointcode niet vinden voor tram 12 richting Duindorp. Kan jij me misschien verder helpen?
                  cirdanC Mykle1M M 3 Replies Last reply
                  • cirdanC
                    cirdan @viren_nitin
                    @viren_nitin just request http://v0.ovapi.nl/line/HTM_12_2 in your browser and search the resulting json with search on a page for TimingPointName for the stop you want to use. E.g I find Tholensestraat. The next field is the tpc
                    TimingPointName":"Tholensestraat","TimingPointCode":"32000806"
                    Good luck
                    Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
                    M V 2 Replies Last reply
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @viren_nitin
                      @viren_nitin said in My 42" multitouch Philips MagicMirror Display:
                      I’m going to assume that cirdan (The Shipwright) has helped you without going to my translator. :-)
                        M1K3rSz @viren_nitin
                          M1K3rSz @cirdan
                          @cirdan said in My 42" multitouch Philips MagicMirror Display:
                          Good luck
                          Sorry , ik was een paar daagjes buiten de stad !
                          dus zie je vraag te laat, neem aan dat cirdan je uit de brand heeft geholpen
                            PaulB
                            Dear @M1K3rSz , your LED’s look pretty cool. Did they come with your monitor or did you installed it after you bought your screen? Furthermore I would like to know what they are there fore? Screen activisation ore even showing you which component is not working correctly?
                            Thanks in advantage for your answer :)
                            Kind regards from Hamburg, Germany,
                            Paul
                              A Former User
                              che casa incasinata
                              • V
                                viren_nitin @cirdan
                                @cirdan Thank You! It worked.
                                cirdanC 1 Reply Last reply
                                • cirdanC
                                  cirdan @viren_nitin
                                  @viren_nitin nice, good luck catching your bus
                                  • peemoellerP
                                    peemoeller
