    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 567.6k Views 43 Watching
    • evroomE Offline
      evroom
      Both modules display matches and standings.
      https://github.com/master117/MagicMirror-FootballLeagues
      https://github.com/LukeSkywalker92/MMM-SoccerLiveScore
      Differences might be in the extra possibilities of the api and therefore additional possibilities for the module.
      For example football-data.org v2 can show you the squad.
      MagicMirror version: 2.37.0
      • strawberry 3.141S Offline
        I updated the module to work with api v2. One problem that I figured out so far is that the api no longer provides links to the club logos, therefore I added a config option logos to hide them.
        It’s under construction and can be tested on the develop branch
        git checkout develop
        [card:fewieden/MMM-soccer]
        • evroomE Offline
          evroom
          @strawberry-3-141 ,
          I have it running. Added “NETHERLANDS”, 2003.
          I found out that v1 is still available, but only for pre-World Cup stuff.
          But that means you can use v1 for the logos:
          http://api.football-data.org/v1/teams/57
          http://upload.wikimedia.org/wikipedia/en/5/53/Arsenal_FC.svg
          You could add a separate league number_league name_team_logo.json file, with a collection of team logos.
          Per league, per team.
          Then users can add missing logos themselves and perhaps share their collection with you to be put on github.
          Just an idea.
          In the meantime I will try to contact the football-data.org person to ask what happened to the logos in v2.
          Hope you are not offended when I say that SoccerLiveScore has it all.
          Except for 2 things that are unique for your module:
          focus and number of teams to show on the table.
          Cannot say if the sources of data is equally well maintained, so cannot say if it is worth the trouble of coding, unless it brings you pleasure.
            strawberry 3.141 Project Sponsor Module Developer @evroom
            @evroom well we had problems in v1 already that logos were taken down due to copyrights and I sent the api owner updated links, that were never added, so I don’t think that it will come back in v2. For the same reason I also don’t want to host the files on github. I think mostly the german league was the problem, why I added a logic to overwrite broken image links from the api.
            It looked like this:
            		'CLUBNAME': 'https://CLUBLOGO.svg'
            if you want to start collecting the logo links in an object where the key is the club name then i can add them to my list. But I don’t have the time to do so myself.
            • evroomE Offline
              evroom
              @strawberry-3-141 ,
              Thanks for the background info.
              Did not know it was an issue before, but then again I am a novice MM user.
              Time and mood is always an issue.
              Better for cold evenings or weekends, not when it is 35 degrees and having spent 8 hours behind a PC in a relatively hot office 😀
                I just released version 2 of this module
                Added
                • Club logo downloader
                • New config option logos.
                • Swedish translations
                • Doclets.io integration
                • Contributing guidelines
                • Issue template
                • Pull request template
                • Editor config
                Changed
                • Switched from Api v1 to v2.
                • Updated league ids.
                • Switched rendering from js to nunjuck template.
                • Updated travis-ci config.
                • Disabled markdown lint rules MD024 and MD026
                • evroomE Offline
                  evroom
                  Great job on version 2.0.
                  I have it running.
                  Added Eredivisie and some logos; all fine.
                  Just one question.
                  In your example your header is left aligned and shows “1. BUNDESLIGA 2015/16”.
                  Not updated to show the version 2.0 example.
                  When I choose the Bundesliga I just get “BUNDESLIGA” and it is right aligned.
                  How do I get it at least left aligned ?
                  I tried adding this to the custom.css, but it doesn’t work:
                  .MMM-soccer .header {
                      text-align: left;
                    @evroom your try was pretty close, the correct one is
                    .MMM-soccer header {
                       text-align: left;
                    the header is not a class, but a tag, that’s why you don’t have a leading . there.
                    It also depends on the position of the module, if you have it e.g. in top_left it’s automatically on the left.
                    • evroomE Offline
                      evroom
                      @strawberry-3-141
                      Thanks, works like a charm.
                      Any possibility to introduce a rotation option, in order to rotate the standings of the leagues in “show” or “leagues” ?
                        @evroom rotation is currently only supported for voice
                          surger13 Project Sponsor
                          I cant get it to work again, not even with the new version.
                          Where is the mistake?
                          module: "MMM-soccer",
                          			disabled: false,
                          			position: "bottom_left",
                          			header: "",
                          				colored: true,
                          				show: 'GERMANY',
                          				logos: false,
                          				focus_on: {
                          					"GERMANY": "Erzgebirge Aue"
                          				max_teams: 5,
                          				leagues: {
                          					"GERMANY": "BL2",
                          • evroomE Offline
                            evroom
                            Hi @surger13 ,
                            You do not have the api_key specified.
                            The README says:
                            api_key: false,
                            But for me this does not work.
                            I registered at https://www.football-data.org/client/register and the resulting api_key is working fine.
                            api_key: 'xxxxd62e29754e10b56029399458xxxx',
                            This is a fake key, use the one you get after registering.
                            Good luck.
                              strawberry 3.141 Project Sponsor Module Developer @surger13
                              @surger13 sadly the second german bundesliga is not in the free plan https://www.football-data.org/coverage it would cost 49€ a month.
                                surger13 Project Sponsor @strawberry 3.141
                                @strawberry-3-141
                                I suspected that. Really a pity. That was different in the past.
                                Nevertheless, thank you.
                                • T Offline
                                  Tobi91
                                  Hi everyone,
                                  I also have problems to get the module to work.
                                  My config:
                                  		disabled: false,
                                  				   api_key: 'My API-key',
                                      			   colored: false,
                                      			   show: 'GERMANY',
                                     				   focus_on: false,
                                     				   max_teams: false,
                                     				   logos: false,
                                      			   leagues: {
                                        			  	    "GERMANY": "BL1",
                                  None of my modules will work (black screen) as soon as I start the mirror with this module enabled.
                                  I tried switching several " to ’ but I am not sure which to use. The online description and the default values in the config readme seem to be different.
                                  I would be glad if someone could help me.
                                  Thank you.
                                  • evroomE Offline
                                    evroom
                                    Did you not just forget the starting { ?
                                    Like this:
                                      disabled: false,
                                        colored: false,
                                        show: 'GERMANY',
                                        focus_on: false,
                                        max_teams: false,
                                        logos: false,
                                        leagues: {
                                          "GERMANY": "BL1",
                                    Did you run:
                                    cd ~/MagicMirror; npm run config:check
                                    • T Offline
                                      Tobi91
                                      thank you for your fast response.
                                      I was not missing an open bracket (Sry forgot to put it in the message).
                                      I could not run config:check. Even though I updated my Magic Mirror to the latest version, it seems I am missing the script.
                                      But I put my config into a syntax checker and there are no errors.
                                      Thanks again.
                                        mrSnatz
                                        I would like to display several leagues. But my module shows only “Loading …”.
                                        Where is the mistake? Do you have any tip
                                                position: "bottom_right",
                                                    api_key: "XXXX129ce6f9XXXXXXXXXXXXXXXXX",
                                                    colored: "true",
                                                    logos: "true",
                                                    leagues:{
                                                      "GERMANY": "BL1",
                                                      "GERMANY": "DFB",
                                                      "GERMANY": "BL2",
                                                      "EUROPE": "CL",
                                                      "WORLD": "WC",
                                        • evroomE Offline
                                          evroom
                                          @mrSnatz said in MMM-Soccer - Soccer Standings:
                                          Do you have any tip
                                          Try this:
                                              module: 'MMM-soccer',
                                              position: 'bottom_right',
                                                  api_key: 'XXXX129ce6f9XXXXXXXXXXXXXXXXX',
                                                  colored: true,
                                                  logos: true,
                                                  leagues: {
                                                    GERMANY: 'BL1',
                                                    GERMANY: 'DFB',
                                                    GERMANY: 'BL2',
                                                    EUROPE: 'CL',
                                                    WORLD: 'WC',
                                          • evroomE Offline
                                            evroom
                                            Btw,
                                            Not all leagues are for free:
                                            So, for example DFB and BL2 will not work.
                                            You might need to remove those or comment them (with //).
                                            And you might need this entry:
                                            show: 'GERMANY',
                                            But I am not sure what the connection is between this and the leagues entries.
                                            • 10
                                            • 11
                                            • 9 / 11
