    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 545.5k Views 43 Watching
      surger13 Project Sponsor
      I cant get it to work again, not even with the new version.
      Where is the mistake?
      module: "MMM-soccer",
      			disabled: false,
      			position: "bottom_left",
      			header: "",
      				colored: true,
      				show: 'GERMANY',
      				logos: false,
      				focus_on: {
      					"GERMANY": "Erzgebirge Aue"
      				max_teams: 5,
      				leagues: {
      					"GERMANY": "BL2",
      • evroomE Offline
        evroom
        Hi @surger13 ,
        You do not have the api_key specified.
        The README says:
        api_key: false,
        But for me this does not work.
        I registered at https://www.football-data.org/client/register and the resulting api_key is working fine.
        api_key: 'xxxxd62e29754e10b56029399458xxxx',
        This is a fake key, use the one you get after registering.
        Good luck.
        MagicMirror version: 2.35.0
        Test environment:
        MagicMirror version: 2.36.0-develop
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @surger13
          @surger13 sadly the second german bundesliga is not in the free plan https://www.football-data.org/coverage it would cost 49€ a month.
            surger13 Project Sponsor @strawberry 3.141
            @strawberry-3-141
            I suspected that. Really a pity. That was different in the past.
            Nevertheless, thank you.
            • T Offline
              Tobi91
              Hi everyone,
              I also have problems to get the module to work.
              My config:
              		disabled: false,
              				   api_key: 'My API-key',
                  			   colored: false,
                  			   show: 'GERMANY',
                 				   focus_on: false,
                 				   max_teams: false,
                 				   logos: false,
                  			   leagues: {
                    			  	    "GERMANY": "BL1",
              None of my modules will work (black screen) as soon as I start the mirror with this module enabled.
              I tried switching several " to ’ but I am not sure which to use. The online description and the default values in the config readme seem to be different.
              I would be glad if someone could help me.
              Thank you.
              • evroomE Offline
                evroom
                Did you not just forget the starting { ?
                Like this:
                  disabled: false,
                    colored: false,
                    show: 'GERMANY',
                    focus_on: false,
                    max_teams: false,
                    logos: false,
                    leagues: {
                      "GERMANY": "BL1",
                Did you run:
                cd ~/MagicMirror; npm run config:check
                Test environment:
                • T Offline
                  Tobi91
                  thank you for your fast response.
                  I was not missing an open bracket (Sry forgot to put it in the message).
                  I could not run config:check. Even though I updated my Magic Mirror to the latest version, it seems I am missing the script.
                  But I put my config into a syntax checker and there are no errors.
                  Thanks again.
                    mrSnatz
                    I would like to display several leagues. But my module shows only “Loading …”.
                    Where is the mistake? Do you have any tip
                            position: "bottom_right",
                                api_key: "XXXX129ce6f9XXXXXXXXXXXXXXXXX",
                                colored: "true",
                                logos: "true",
                                leagues:{
                                  "GERMANY": "BL1",
                                  "GERMANY": "DFB",
                                  "GERMANY": "BL2",
                                  "EUROPE": "CL",
                                  "WORLD": "WC",
                    • evroomE Offline
                      evroom
                      @mrSnatz said in MMM-Soccer - Soccer Standings:
                      Do you have any tip
                      Try this:
                          module: 'MMM-soccer',
                          position: 'bottom_right',
                              api_key: 'XXXX129ce6f9XXXXXXXXXXXXXXXXX',
                              colored: true,
                              logos: true,
                              leagues: {
                                GERMANY: 'BL1',
                                GERMANY: 'DFB',
                                GERMANY: 'BL2',
                                EUROPE: 'CL',
                                WORLD: 'WC',
                      Test environment:
                      • evroomE Offline
                        evroom
                        Btw,
                        Not all leagues are for free:
                        So, for example DFB and BL2 will not work.
                        You might need to remove those or comment them (with //).
                        And you might need this entry:
                        show: 'GERMANY',
                        But I am not sure what the connection is between this and the leagues entries.
                        Test environment:
                          mrSnatz
                          @evroom said in MMM-Soccer - Soccer Standings:
                          show: ‘GERMANY’,
                          OK. Thank you very much. Have excluded the paid. Now it works.
                          • zdenekZ Offline
                            zdenek
                            hi all, can be the module used for whatever league from he full list of leagues fromhttp://api.football-data.org/v2/competitions ? In my case
                            {"id":2062,"name":"Czech Republic"},"name":"Synot Liga","code":null,"emblemUrl":null,"plan":"TIER_FOUR","currentSeason":{"id":171,"startDate":"2018-07-20","endDate":"2019-04-27","currentMatchday":30,"winner":null},"numberOfAvailableSeasons":2,"lastUpdated":"2019-06-02T06:20:02Z"}
                            or any idea, any module for Czech league?
                            thanks, Zdeněk
                            • evroomE Offline
                              evroom
                              @zdenek
                              Unfortunately for you: no
                              See this list for free and paid competitions:
                              Test environment:
                              zdenekZ 1 Reply Last reply Reply Quote 0
                              • zdenekZ Offline
                                zdenek @evroom
                                uaaaaaa a litttle bit expencive… so, I’ll have to look for solution based on iFrame or smthg and get the info from here https://www.fortunaliga.cz/rozpis-zapasu/2020?type=2&id_stage=1&month=0&round=0
                                thx
                                • evroomE Offline
                                  evroom
                                  Hi MMM-soccer users,
                                  Perhaps some of you experience the same issue as me and the Magic Mirror shows “Loading”.
                                  The problem most likely it is caused due to the fact that round 1 for most competitions still needs to be played.
                                  For example for de Eredivisie I get this using a test script:
                                  Response:\n{"filters":{},"competition":{"id":2003,"area":{"id":2163,"name":"Netherlands"},"name":"Eredivisie","code":"DED","plan":"TIER_ONE","lastUpdated":"2019-05-28T23:44:43Z"},"season":{"id":481,"startDate":"2019-08-09","endDate":"2020-05-25","currentMatchday":1,"winner":null},"standings":[]}
                                  As the standings array is empty, the module is struggling.
                                  Perhaps better if it would show “No standings available” in this case, but for the moment is will show what it shows.
                                  I have sent a mail to the football-org developer, if it would be possible to send a round 0 standing / table, with the clubs in alphabetic order.
                                  Test environment:
                                    Version 2.0.1
                                    Added
                                    • French translations (Thanks to https://github.com/laventin85)
                                    Changed
                                    • Readme config example
                                    • Github config files
                                    https://github.com/fewieden/MMM-soccer
                                    [card:fewieden/MMM-soccer]
                                      Version 2.1.0
                                      Requires version >= 2.14 of MagicMirror!
                                      Added
                                      • Integrated MMM-Modal
                                      Changed
                                      • Using remote logos
                                      • Preview pictures
                                      Fixed
                                      • Fade effect
                                      • Focus_on in modal highlights correct team
                                      • Help modal shows correct voice commands
                                      Removed
                                      • Logo downloader
                                      • Doclet integration
                                      • E Offline
                                        Egnos
                                        I tried the module but on the MM I don’t see anything.
                                        My config.js
                                        				disabled: false,
                                        					api_key: false,
                                        					colored: true,
                                        					show: 'ITALY',
                                        					focus_on: false,
                                        					logos: true,
                                        					max_teams: false,
                                        					leagues: {ITALY: 'SA'},
                                        MM output:
                                        pi@MagicMirror:~/MagicMirror $ npm start
                                        > magicmirror@2.10.1 start /home/pi/MagicMirror
                                        > ./run-start.sh
                                        [02:57:33.259] [LOG]    Starting MagicMirror: v2.10.1
                                        [02:57:33.272] [LOG]    Loading config ...
                                        [02:57:33.282] [LOG]    Loading module helpers ...
                                        [02:57:33.286] [LOG]    No helper found for module: alert.
                                        [02:57:33.382] [LOG]    Initializing new module helper ...
                                        [02:57:33.384] [LOG]    Module helper loaded: updatenotification
                                        [02:57:33.386] [LOG]    No helper found for module: clock.
                                        [02:57:34.112] [LOG]    Initializing new module helper ...
                                        [02:57:34.113] [LOG]    Module helper loaded: calendar
                                        [02:57:34.114] [LOG]    No helper found for module: compliments.
                                        [02:57:34.115] [LOG]    No helper found for module: currentweather.
                                        [02:57:34.122] [LOG]    No helper found for module: weatherforecast.
                                        [02:57:34.176] [LOG]    Initializing new module helper ...
                                        [02:57:34.177] [LOG]    Module helper loaded: newsfeed
                                        [02:57:34.829] [LOG]    Initializing new module helper ...
                                        [02:57:34.830] [LOG]    Module helper loaded: MMM-soccer
                                        [02:57:34.831] [LOG]    All module helpers loaded.
                                        [02:57:34.832] [LOG]    Starting server on port 8080 ...
                                        [02:57:34.856] [LOG]    Server started ...
                                        [02:57:34.858] [LOG]    Connecting socket for: updatenotification
                                        [02:57:34.859] [LOG]    Connecting socket for: calendar
                                        [02:57:34.860] [LOG]    Starting node helper for: calendar
                                        [02:57:34.861] [LOG]    Connecting socket for: newsfeed
                                        [02:57:34.862] [LOG]    Starting module: newsfeed
                                        [02:57:34.863] [LOG]    Connecting socket for: MMM-soccer
                                        [02:57:34.864] [LOG]    Starting module: MMM-soccer
                                        [02:57:34.865] [LOG]    Sockets connected & modules started ...
                                        [02:57:35.140] [LOG]    Launching application.
                                        [02:57:38.216] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                                        [02:57:38.364] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                        Where am I wrong?
                                        Can you help me?
                                        Thanks.
                                          strawberry 3.141 Project Sponsor Module Developer @Egnos
                                          @Egnos Requires version >= 2.14 of MagicMirror!
                                          Your mirror is not up to date
                                          E 1 Reply Last reply Reply Quote 1
                                          • E Offline
                                            Egnos @strawberry 3.141
                                            @strawberry-3-141 ok thanks!
                                            I have updated Magic Mirror to the latest version.
                                            Now I only see “LOADING IN PROGRESS”, below the error:
                                            [ERROR] Getting league table: 403 Forbidden
                                            Where am I wrong now?
                                            Many Thanks.
                                            • 10
                                            • 11
                                            • 9 / 11
