    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.8k Views 43 Watching
    • T
      Tobi91
      thank you for your fast response.
      I was not missing an open bracket (Sry forgot to put it in the message).
      I could not run config:check. Even though I updated my Magic Mirror to the latest version, it seems I am missing the script.
      But I put my config into a syntax checker and there are no errors.
      Thanks again.
        mrSnatz
        I would like to display several leagues. But my module shows only “Loading …”.
        Where is the mistake? Do you have any tip
                module: "MMM-soccer",
                position: "bottom_right",
                    api_key: "XXXX129ce6f9XXXXXXXXXXXXXXXXX",
                    colored: "true",
                    logos: "true",
                    leagues:{
                      "GERMANY": "BL1",
                      "GERMANY": "DFB",
                      "GERMANY": "BL2",
                      "EUROPE": "CL",
                      "WORLD": "WC",
        • evroomE
          evroom
          @mrSnatz said in MMM-Soccer - Soccer Standings:
          Do you have any tip
          Try this:
              module: 'MMM-soccer',
              position: 'bottom_right',
                  api_key: 'XXXX129ce6f9XXXXXXXXXXXXXXXXX',
                  colored: true,
                  logos: true,
                  leagues: {
                    GERMANY: 'BL1',
                    GERMANY: 'DFB',
                    GERMANY: 'BL2',
                    EUROPE: 'CL',
                    WORLD: 'WC',
          MagicMirror version: 2.37.0
          • evroomE
            evroom
            Btw,
            Not all leagues are for free:
            https://www.football-data.org/coverage
            So, for example DFB and BL2 will not work.
            You might need to remove those or comment them (with //).
            And you might need this entry:
            show: 'GERMANY',
            But I am not sure what the connection is between this and the leagues entries.
              mrSnatz
              @evroom said in MMM-Soccer - Soccer Standings:
              show: ‘GERMANY’,
              OK. Thank you very much. Have excluded the paid. Now it works.
              • zdenekZ
                zdenek
                hi all, can be the module used for whatever league from he full list of leagues fromhttp://api.football-data.org/v2/competitions ? In my case
                {"id":2062,"name":"Czech Republic"},"name":"Synot Liga","code":null,"emblemUrl":null,"plan":"TIER_FOUR","currentSeason":{"id":171,"startDate":"2018-07-20","endDate":"2019-04-27","currentMatchday":30,"winner":null},"numberOfAvailableSeasons":2,"lastUpdated":"2019-06-02T06:20:02Z"}
                or any idea, any module for Czech league?
                thanks, Zdeněk
                • evroomE
                  evroom
                  @zdenek
                  Unfortunately for you: no
                  See this list for free and paid competitions:
                  zdenekZ 1 Reply Last reply
                  • zdenekZ
                    zdenek @evroom
                    uaaaaaa a litttle bit expencive… so, I’ll have to look for solution based on iFrame or smthg and get the info from here https://www.fortunaliga.cz/rozpis-zapasu/2020?type=2&id_stage=1&month=0&round=0
                    thx
                    • evroomE
                      evroom
                      Hi MMM-soccer users,
                      Perhaps some of you experience the same issue as me and the Magic Mirror shows “Loading”.
                      The problem most likely it is caused due to the fact that round 1 for most competitions still needs to be played.
                      For example for de Eredivisie I get this using a test script:
                      Response:\n{"filters":{},"competition":{"id":2003,"area":{"id":2163,"name":"Netherlands"},"name":"Eredivisie","code":"DED","plan":"TIER_ONE","lastUpdated":"2019-05-28T23:44:43Z"},"season":{"id":481,"startDate":"2019-08-09","endDate":"2020-05-25","currentMatchday":1,"winner":null},"standings":[]}
                      As the standings array is empty, the module is struggling.
                      Perhaps better if it would show “No standings available” in this case, but for the moment is will show what it shows.
                      I have sent a mail to the football-org developer, if it would be possible to send a round 0 standing / table, with the clubs in alphabetic order.
                      • strawberry 3.141S
                        Version 2.0.1
                        Added
                        • French translations (Thanks to https://github.com/laventin85)
                        Changed
                        • Readme config example
                        • Github config files
                        https://github.com/fewieden/MMM-soccer
                        [card:fewieden/MMM-soccer]
                        • strawberry 3.141S
                          Version 2.1.0
                          Requires version >= 2.14 of MagicMirror!
                          Added
                          • Integrated MMM-Modal
                          Changed
                          • Using remote logos
                          • Preview pictures
                          Fixed
                          • Fade effect
                          • Focus_on in modal highlights correct team
                          • Help modal shows correct voice commands
                          Removed
                          • Logo downloader
                          • Doclet integration
                          • E
                            Egnos
                            I tried the module but on the MM I don’t see anything.
                            My config.js
                            				disabled: false,
                            					api_key: false,
                            					colored: true,
                            					show: 'ITALY',
                            					focus_on: false,
                            					logos: true,
                            					max_teams: false,
                            					leagues: {ITALY: 'SA'},
                            MM output:
                            pi@MagicMirror:~/MagicMirror $ npm start
                            > magicmirror@2.10.1 start /home/pi/MagicMirror
                            > ./run-start.sh
                            [02:57:33.259] [LOG]    Starting MagicMirror: v2.10.1
                            [02:57:33.272] [LOG]    Loading config ...
                            [02:57:33.282] [LOG]    Loading module helpers ...
                            [02:57:33.286] [LOG]    No helper found for module: alert.
                            [02:57:33.382] [LOG]    Initializing new module helper ...
                            [02:57:33.384] [LOG]    Module helper loaded: updatenotification
                            [02:57:33.386] [LOG]    No helper found for module: clock.
                            [02:57:34.112] [LOG]    Initializing new module helper ...
                            [02:57:34.113] [LOG]    Module helper loaded: calendar
                            [02:57:34.114] [LOG]    No helper found for module: compliments.
                            [02:57:34.115] [LOG]    No helper found for module: currentweather.
                            [02:57:34.122] [LOG]    No helper found for module: weatherforecast.
                            [02:57:34.176] [LOG]    Initializing new module helper ...
                            [02:57:34.177] [LOG]    Module helper loaded: newsfeed
                            [02:57:34.829] [LOG]    Initializing new module helper ...
                            [02:57:34.830] [LOG]    Module helper loaded: MMM-soccer
                            [02:57:34.831] [LOG]    All module helpers loaded.
                            [02:57:34.832] [LOG]    Starting server on port 8080 ...
                            [02:57:34.856] [LOG]    Server started ...
                            [02:57:34.858] [LOG]    Connecting socket for: updatenotification
                            [02:57:34.859] [LOG]    Connecting socket for: calendar
                            [02:57:34.860] [LOG]    Starting node helper for: calendar
                            [02:57:34.861] [LOG]    Connecting socket for: newsfeed
                            [02:57:34.862] [LOG]    Starting module: newsfeed
                            [02:57:34.863] [LOG]    Connecting socket for: MMM-soccer
                            [02:57:34.864] [LOG]    Starting module: MMM-soccer
                            [02:57:34.865] [LOG]    Sockets connected & modules started ...
                            [02:57:35.140] [LOG]    Launching application.
                            [02:57:38.216] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
                            [02:57:38.364] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                            Where am I wrong?
                            Can you help me?
                            Thanks.
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @Egnos
                              @Egnos Requires version >= 2.14 of MagicMirror!
                              Your mirror is not up to date
                              E 1 Reply Last reply
                              • E
                                Egnos @strawberry 3.141
                                @strawberry-3-141 ok thanks!
                                I have updated Magic Mirror to the latest version.
                                Now I only see “LOADING IN PROGRESS”, below the error:
                                [ERROR] Getting league table: 403 Forbidden
                                Where am I wrong now?
                                Many Thanks.
                                • strawberry 3.141S
                                  @Egnos seeing your previous post with the config, your league probably requires a free API key.
                                  • E
                                    @strawberry-3-141
                                    The Italian Serie aA championship should be free. Also if I try to enter the site in the section of the Italian Serie A championship but I get this error:
                                    Italy Serie A
                                    Are you sure the site works?
                                    Many thanks.
                                    • strawberry 3.141S
                                      @Egnos the module doesn’t make use of the site native-stats.org. You need to specify the api key in the config such as api_key: 'YOUR_API_KEY',. https://www.football-data.org/client/register
                                      • E
                                        @strawberry-3-141 with the Api Key works!
                                        Thanks.
                                        • strawberry 3.141S
                                          Fixed
                                          • Nunjuck template was rendering one team less than specified in config
                                          H 1 Reply Last reply
                                          • H
                                            hugopvl @strawberry 3.141
                                            @strawberry-3-141
                                            I’ve been here for a few hours trying to get Portugal’s first league up and running, and from what I see it’s free, but it’s always charging and it doesn’t work. if you put germany it works correctly.
                                            i try: don’t work
                                            module: ‘MMM-soccer’,
                                            position: ‘top_left’,
                                            api_key: ‘24ea5f89c975401c90bdccb9dd5c16df’,
                                            show: ‘PORTUGAL’,
                                            league: {“PORTUGAL”: “PPL”},
                                            logos: false,
                                            colored: false,
                                            max_teams: 7
                                            this: dont work
                                            show: ‘PORTUGAL’,
                                            logos: false,
                                            colored: false,
                                            max_teams: 7
                                            this: work fine
                                            show: ‘GERMANY’,
                                            logos: false,
                                            colored: false,
                                            max_teams: 7
                                            thank so mutch
                                            • 10
                                            • 11
                                            • 9 / 11
