    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.7k Views 43 Watching
    • strawberry 3.141S
      Version 2.1.0
      Requires version >= 2.14 of MagicMirror!
      Added
      • Integrated MMM-Modal
      Changed
      • Using remote logos
      • Preview pictures
      Fixed
      • Fade effect
      • Focus_on in modal highlights correct team
      • Help modal shows correct voice commands
      Removed
      • Logo downloader
      • Doclet integration
      https://github.com/fewieden/MMM-soccer
      [card:fewieden/MMM-soccer]
      • E
        Egnos
        I tried the module but on the MM I don’t see anything.
        My config.js
        				module: 'MMM-soccer',
        				position: 'bottom_right',
        				disabled: false,
        					api_key: false,
        					colored: true,
        					show: 'ITALY',
        					focus_on: false,
        					logos: true,
        					max_teams: false,
        					leagues: {ITALY: 'SA'},
        MM output:
        pi@MagicMirror:~/MagicMirror $ npm start
        > magicmirror@2.10.1 start /home/pi/MagicMirror
        > ./run-start.sh
        [02:57:33.259] [LOG]    Starting MagicMirror: v2.10.1
        [02:57:33.272] [LOG]    Loading config ...
        [02:57:33.282] [LOG]    Loading module helpers ...
        [02:57:33.286] [LOG]    No helper found for module: alert.
        [02:57:33.382] [LOG]    Initializing new module helper ...
        [02:57:33.384] [LOG]    Module helper loaded: updatenotification
        [02:57:33.386] [LOG]    No helper found for module: clock.
        [02:57:34.112] [LOG]    Initializing new module helper ...
        [02:57:34.113] [LOG]    Module helper loaded: calendar
        [02:57:34.114] [LOG]    No helper found for module: compliments.
        [02:57:34.115] [LOG]    No helper found for module: currentweather.
        [02:57:34.122] [LOG]    No helper found for module: weatherforecast.
        [02:57:34.176] [LOG]    Initializing new module helper ...
        [02:57:34.177] [LOG]    Module helper loaded: newsfeed
        [02:57:34.829] [LOG]    Initializing new module helper ...
        [02:57:34.830] [LOG]    Module helper loaded: MMM-soccer
        [02:57:34.831] [LOG]    All module helpers loaded.
        [02:57:34.832] [LOG]    Starting server on port 8080 ...
        [02:57:34.856] [LOG]    Server started ...
        [02:57:34.858] [LOG]    Connecting socket for: updatenotification
        [02:57:34.859] [LOG]    Connecting socket for: calendar
        [02:57:34.860] [LOG]    Starting node helper for: calendar
        [02:57:34.861] [LOG]    Connecting socket for: newsfeed
        [02:57:34.862] [LOG]    Starting module: newsfeed
        [02:57:34.863] [LOG]    Connecting socket for: MMM-soccer
        [02:57:34.864] [LOG]    Starting module: MMM-soccer
        [02:57:34.865] [LOG]    Sockets connected & modules started ...
        [02:57:35.140] [LOG]    Launching application.
        [02:57:38.216] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
        [02:57:38.364] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        Where am I wrong?
        Can you help me?
        Thanks.
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @Egnos
          @Egnos Requires version >= 2.14 of MagicMirror!
          Your mirror is not up to date
          E 1 Reply Last reply
          • E
            Egnos @strawberry 3.141
            @strawberry-3-141 ok thanks!
            I have updated Magic Mirror to the latest version.
            Now I only see “LOADING IN PROGRESS”, below the error:
            [ERROR] Getting league table: 403 Forbidden
            Where am I wrong now?
            Many Thanks.
            • strawberry 3.141S
              @Egnos seeing your previous post with the config, your league probably requires a free API key.
              • E
                @strawberry-3-141
                The Italian Serie aA championship should be free. Also if I try to enter the site in the section of the Italian Serie A championship but I get this error:
                Italy Serie A
                Are you sure the site works?
                Many thanks.
                • strawberry 3.141S
                  @Egnos the module doesn’t make use of the site native-stats.org. You need to specify the api key in the config such as api_key: 'YOUR_API_KEY',. https://www.football-data.org/client/register
                  • E
                    @strawberry-3-141 with the Api Key works!
                    Thanks.
                    • strawberry 3.141S
                      Fixed
                      • Nunjuck template was rendering one team less than specified in config
                      H 1 Reply Last reply
                      • H
                        hugopvl @strawberry 3.141
                        @strawberry-3-141
                        I’ve been here for a few hours trying to get Portugal’s first league up and running, and from what I see it’s free, but it’s always charging and it doesn’t work. if you put germany it works correctly.
                        i try: don’t work
                        module: ‘MMM-soccer’,
                        position: ‘top_left’,
                        api_key: ‘24ea5f89c975401c90bdccb9dd5c16df’,
                        show: ‘PORTUGAL’,
                        league: {“PORTUGAL”: “PPL”},
                        logos: false,
                        colored: false,
                        max_teams: 7
                        this: dont work
                        show: ‘PORTUGAL’,
                        logos: false,
                        colored: false,
                        max_teams: 7
                        this: work fine
                        show: ‘GERMANY’,
                        logos: false,
                        colored: false,
                        max_teams: 7
                        thank so mutch
                        • H
                          hugopvl @hugopvl
                          @hugopvl
                          I found the problem,
                          inside the folder of the module:
                          file MMM-soccer.js
                          defaults: {
                              api_key: false,
                              colored: false,
                              **show: 'PORTUGAL',**
                              focus_on: false,
                              max_teams: false,
                              logos: false,
                              leagues: {
                                  **PORTUGAL: 'PPL',**
                                  FRANCE: 'FL1',
                                  ENGLAND: 'PL',
                                  SPAIN: 'PD',
                                  ITALY: 'SA'
                          so I think the module is only loading the leagues that are in the list as default, I added Portugal as default and added it to the leagues in the list below and it already works correctly.
                          THX
                            sdetweil @hugopvl
                            @hugopvl but u can do that in config.js
                            anything in defaults can be replaced w similar notation in the module config section
                            lavolp3L H 2 Replies Last reply
                            • lavolp3L
                              @sdetweil @hugopvl
                              yes the only error in above config seemed to be that @hugopvl has written
                              instead of
                                leagues: {PORTUGAL: “PPL”},
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                              • H
                                hugopvl @sdetweil
                                supposed to be the right one, but if you read my previous comment, you can see that it wasn’t working, it just worked with the change in MMM-soccer.js
                                THX
                                lavolp3L 1 Reply Last reply
                                • lavolp3L
                                  lavolp3 Module Developer @hugopvl
                                  @hugopvl it didn’t work because of the small mistake I mentioned before. Your config entry was not recognized because your object was league: not leagues:
                                  @strawberry-3-141 might include in the README that additional leagues can be included via the config entry you made before. Or include all of them from the start.
                                  • strawberry 3.141S
                                    Today the European Championship will kickoff :flexed_biceps: :soccer_ball:
                                    I’m currently working on version 3 of this module. It will be possible to not only display the standings of a league but also get the schedules and top scorers displayed in a carousel.
                                    On top of that, the module will finally support cups such as the European Championship, Champions League, and World Cup.
                                    If you want to test the beta for tonight’s kickoff, then head over to Github https://github.com/fewieden/MMM-soccer/pull/42 for all details.
                                    If you find any issues or need help, please report them here https://github.com/fewieden/MMM-soccer/pull/42 so they are all grouped together.
                                    Reply Quote 2
                                    • strawberry 3.141S
                                      Fixed the standings for the ongoing European Championship. Schedules are now filtered by the current matchday.
                                      Check out https://github.com/fewieden/MMM-soccer/pull/42 to test v3 of the module.
                                      B 1 Reply Last reply
                                        Babene1 Project Sponsor @strawberry 3.141
                                        @strawberry-3-141
                                        thanks for the new version, it’s really great. Great new features.
                                        However, i have Problem to install the leatest version with „schedules fix“. Unfortunately I am not so familiar with git. Is there a new branch available or have to use „feature/extract-api-provider"?
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @Babene1
                                          @babene1 it is the same branch. You can check which branch you are currently using with git status.
                                          On branch feature/extract-api-provider
                                          Your branch is up to date with 'origin/feature/extract-api-provider'.
                                          To update to the latest commit you can simply run git pull, as no dependencies have changed.
                                            my branch is up to date
                                            this is my modul-config:
                                                        position: 'top_right',
                                                            colored: true,
                                                            logos: true,
                                                            rotationInterval: 20 * 1000, // 20 seconds instead of 15 (default)
                                                            provider: {
        'football-data': {
        apiKey: 'API Keay' // Replace with your API key
                                                            competitions: [
        code: 'EC', // European championship
        standings: {
        provider: 'football-data',
        focusOn: 'GER', // Germany
        maxEntries: 5
        schedules: {
        maxEntries: 7
                                            should not only display the current matchday?
                                            • 10
                                            • 11
                                            • 10 / 11
