    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 582.7k Views 43 Watching
    • H
      hugopvl @strawberry 3.141
      @strawberry-3-141
      I’ve been here for a few hours trying to get Portugal’s first league up and running, and from what I see it’s free, but it’s always charging and it doesn’t work. if you put germany it works correctly.
      i try: don’t work
      module: ‘MMM-soccer’,
      position: ‘top_left’,
      api_key: ‘24ea5f89c975401c90bdccb9dd5c16df’,
      show: ‘PORTUGAL’,
      league: {“PORTUGAL”: “PPL”},
      logos: false,
      colored: false,
      max_teams: 7
      this: dont work
      show: ‘PORTUGAL’,
      logos: false,
      colored: false,
      max_teams: 7
      this: work fine
      show: ‘GERMANY’,
      logos: false,
      colored: false,
      max_teams: 7
      thank so mutch
      H 1 Reply Last reply
      • H
        hugopvl @hugopvl
        @hugopvl
        I found the problem,
        inside the folder of the module:
        file MMM-soccer.js
        defaults: {
            api_key: false,
            colored: false,
            **show: 'PORTUGAL',**
            focus_on: false,
            max_teams: false,
            logos: false,
            leagues: {
                **PORTUGAL: 'PPL',**
                FRANCE: 'FL1',
                ENGLAND: 'PL',
                SPAIN: 'PD',
                ITALY: 'SA'
        so I think the module is only loading the leagues that are in the list as default, I added Portugal as default and added it to the leagues in the list below and it already works correctly.
        THX
          sdetweil @hugopvl
          @hugopvl but u can do that in config.js
          anything in defaults can be replaced w similar notation in the module config section
          lavolp3L H 2 Replies Last reply
          • lavolp3L
            @sdetweil @hugopvl
            yes the only error in above config seemed to be that @hugopvl has written
            instead of
              leagues: {PORTUGAL: “PPL”},
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • H
              hugopvl @sdetweil
              supposed to be the right one, but if you read my previous comment, you can see that it wasn’t working, it just worked with the change in MMM-soccer.js
              THX
              lavolp3L 1 Reply Last reply
              • lavolp3L
                lavolp3 Module Developer @hugopvl
                @hugopvl it didn’t work because of the small mistake I mentioned before. Your config entry was not recognized because your object was league: not leagues:
                @strawberry-3-141 might include in the README that additional leagues can be included via the config entry you made before. Or include all of them from the start.
                • strawberry 3.141S
                  Today the European Championship will kickoff :flexed_biceps: :soccer_ball:
                  I’m currently working on version 3 of this module. It will be possible to not only display the standings of a league but also get the schedules and top scorers displayed in a carousel.
                  On top of that, the module will finally support cups such as the European Championship, Champions League, and World Cup.
                  If you want to test the beta for tonight’s kickoff, then head over to Github https://github.com/fewieden/MMM-soccer/pull/42 for all details.
                  If you find any issues or need help, please report them here https://github.com/fewieden/MMM-soccer/pull/42 so they are all grouped together.
                  Reply Quote 2
                  • strawberry 3.141S
                    Fixed the standings for the ongoing European Championship. Schedules are now filtered by the current matchday.
                    Check out https://github.com/fewieden/MMM-soccer/pull/42 to test v3 of the module.
                    B 1 Reply Last reply
                      Babene1 Project Sponsor @strawberry 3.141
                      @strawberry-3-141
                      thanks for the new version, it’s really great. Great new features.
                      However, i have Problem to install the leatest version with „schedules fix“. Unfortunately I am not so familiar with git. Is there a new branch available or have to use „feature/extract-api-provider"?
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @Babene1
                        @babene1 it is the same branch. You can check which branch you are currently using with git status.
                        On branch feature/extract-api-provider
                        Your branch is up to date with 'origin/feature/extract-api-provider'.
                        To update to the latest commit you can simply run git pull, as no dependencies have changed.
                          my branch is up to date
                          this is my modul-config:
                                      module: 'MMM-soccer',
                                      position: 'top_right',
                                          colored: true,
                                          logos: true,
                                          rotationInterval: 20 * 1000, // 20 seconds instead of 15 (default)
                                          provider: {
                                              'football-data': {
                                                  apiKey: 'API Keay' // Replace with your API key
                                          competitions: [
                                                  code: 'EC', // European championship
                                                  standings: {
                                                      provider: 'football-data',
                                                      focusOn: 'GER', // Germany
                                                      maxEntries: 5
                                                  schedules: {
                                                      maxEntries: 7
                          should not only display the current matchday?
                          • strawberry 3.141S
                            @babene1 schedules wasn’t optimized yet for no focusOn team specified.
                            Run git pull to get the latest commit.
                            lavolp3L M 2 Replies Last reply
                            • lavolp3L
                              lavolp3 Module Developer @strawberry 3.141
                              @strawberry-3-141 Really great work man!
                                matze86 @strawberry 3.141
                                @strawberry-3-141
                                Nice work 👍🏻
                                Is ist possible to add a config value that it shows only the top scorer?
                                Another idea is that the module shows the Player List from the focussed Team with some stats (played Games, goals, assists, cards,…),
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @matze86
                                  @matze86 I’m not exactly sure what you want. Do you want to show only one single player or only the top scorer view?
                                  M 1 Reply Last reply
                                    pikasso
                                    Hello
                                    Successfully installed a Smart Mirror. All went with some struggles but I managed to make it go then improve step by step to my goal…
                                    With the initial MMM-soccer installed, an API key and all perfectly working, I tried to install the branch 42 following the commands you shared… git to extract-api-provider
                                    cd ~/MagicMirror/modules/MMM-soccer
                                    git fetch
                                    git checkout feature/extract-api-provider
                                    git pull
                                    npm i --production
                                    While all was good with inital version once updated to v3, I can see the caroussel but it’s empty either if I use the default configuration here
                                    Module loaded corretly but there seems to be no data when the caroussel switches. Bellow shows a message “No data available”.
                                    pi@smartmirror:~/MagicMirror/modules/MMM-soccer $ git pull
                                    Déjà à jour.
                                    pi@smartmirror:~/MagicMirror/modules/MMM-soccer $ git status
                                    Sur la branche feature/extract-api-provider
                                    Votre branche est à jour avec 'origin/feature/extract-api-provider'.
                                    Modifications qui ne seront pas validées :
                                      (utilisez "git add <fichier>..." pour mettre à jour ce qui sera validé)
                                      (utilisez "git checkout -- <fichier>..." pour annuler les modifications dans la copie de travail)
                                            modifié :         package-lock.json
                                    aucune modification n'a été ajoutée à la validation (utilisez "git add" ou "git commit -a")
                                    In my global config, the locale is set to ‘fr-FR’ and … again, my configuration is the one here . I tried as well with [Babene’s config] removing any other module… (https://forum.magicmirror.builders/post/92126) :
                                    			module: "alert",
                                    			module: "updatenotification",
                                    			position: "top_bar"
                                    			module: "clock",
                                    			position: "top_left"
                                                    colored: true,
                                                    logos: true,
                                                    provider: {
                                                        'football-data': {
                                                            apiKey: 'xxxxx' // Replace with your API key
                                                    competitions: [
                                                            standings: {
        maxEntries: 5
                                                            schedules: {
        maxEntries: 7
                                    But nothing comes… looks like my API Key is maybe not working for v3 ? It was perfectly working with initial version though
                                    Would you have any suggestion in order to make it work ?
                                      @strawberry-3-141 said in MMM-Soccer - Standings, Schedules and Top Scorers:
                                      I want to Show the top 10 scorer of the league for example
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @pikasso
                                        @pikasso I just started the module with your config and got data.
                                        Do you have any errors in the logs?
                                        • strawberry 3.141S
                                          @matze86 this is already possible, see example config:
                                              provider: {
                                                'football-data': {
                                                  apiKey: 'XXX'
                                              competitions: [
                                                  code: 'BL1',
                                                  scorers: {
                                                    maxEntries: 5
                                          • K
                                            Kongledyret
                                            Does this still work?
                                            Getting “Loading…”
                                            Config:
                                              position: 'bottom_right',
                                                show: 'ENGLAND',
                                                max_teams: 5
                                            • 10
                                            • 11
                                            • 10 / 11
