    MMM-Random Fact
    Scheduled Pinned Locked Moved Education
    59 Posts 12 Posters 47.7k Views 11 Watching
    • lavolp3L
      lavolp3 Module Developer @Ramez
      My module fails as well and I blame the following message in my developer’s console
      [Violation] 'message' handler took 767ms
      It is not directly linked to the module but is coming up since I had it installed just now
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      lavolp3L 1 Reply Last reply
      • lavolp3L
        lavolp3 Module Developer @lavolp3
        @lavolp3 module works after a complete reboot. Sorry for the bothering :-)
        R 1 Reply Last reply
          Ramez @lavolp3
          @lavolp3 glad it’s working…could you try to change it’s language and see if it still works?
          • lavolp3L
            @ramez to be honest, it doesn’t work again. Can’t really find the reason for that.
            My confige entry:
                    disabled: false,
                    module: 'MMM-rfacts',
                    position: 'top_right',
                        lang: "de",  //facts will be translated to this language according to ISO-639$
                        updateInterval: 10 * 60 * 1000, // every 10 minutes
                        animationSpeed: 10,
                        initialLoadDelay: 875, // 0 seconds delay
                        retryDelay: 1500,
                        fadeSpeed: 7
            IN the pm2 logs I only get this
            0|mm       | (node:10423) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 53): Error
            • cowboysdudeC
              cowboysdude Module Developer @lavolp3
              @lavolp3 said in Random Fact:
              animationSpeed: 10,
              retryDelay: 1500,
              fadeSpeed: 7
              Do a git pull…should be fixed now :) Check the config below…
              Actually this is THE only thing you need in your config.js file …
                  disabled: false,
                Ramez @cowboysdude
                @cowboysdude sorry, but still same error
                • cowboysdudeC
                  cowboysdude Module Developer @Ramez
                  @ramez Not really sure as I cannot duplicate your error and no one else seems to be having the issue.
                  • Mykle1M
                    I just downloaded the most recent version and fired it up.
                    • lavolp3L
                      Well for me this module does not work as well (only showing “Eine Tatsache bekommen” in German) and I have again Unhandled Rejection Warnings, which are not errors however… but I have the feeling they are related to the problem.
                      (node:25288) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error
                      0|mm       | (node:25288) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                      0|mm       | (node:25288) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): Error
                      I only get these when I activate this module
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @lavolp3
                        I’m not seeing that at all and I have plenty of modules loading along with it. Have you tried running this module by itself?
                        • joela85J
                          joela85
                          Is there a config option to show/hide the “Random Fact” title if you just want the fact?
                          Alternatively, would positioning and colour customisation of the title be done in CSS?
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @joela85
                            @joela85
                            Both can be achieved in custom.css file
                            .MMM-rfacts .title {
                                display:none;
                                (or positioning and colour customisation)
                            .MMM-rfacts .description  {
                                (positioning and colour customisation code here)
                            Reply Quote 3
                            • joela85J
                              joela85
                              Great, thank you. I will take a look at that when I have a little bit of spare time.
                                Ramez @Mykle1
                                @mykle1 yep, it does work ONLY when set to english but other languages has a problem as stated here due to error in promise.all() function Here …please try to change your language to any other to confirm the error and let us know.
                                @lavolp3 it’s the same error of mine.
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @Ramez
                                  @ramez
                                  Ahh ok. I’m sure the author will address the issue when he has time.
                                  • cowboysdudeC
                                    Is fixed…git pull…enjoy your weekend. Thanks @Mykle1
                                      dirkie
                                      I’m getting the same issues.
                                      entry in config:
                                      disabled: false,
                                      module: ‘MMM-rfacts’,
                                      position: ‘bottom_bar’
                                      but it only shows “Ein Tatsache bekommen…”. I did “git pull” today and I am up to date.
                                      Any hint?
                                      • cowboysdudeC
                                        cowboysdude Module Developer @dirkie
                                        @dirkie Yes…the api is strange… if you hit it too many times they will lock you out for a couple days…
                                        Give it time and it should work again.
                                        • lavolp3L
                                          I am still having an Unhandled promise rejection:
                                          UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 13): TypeError: Cannot read property 'refs' of undefined
                                          My config is completely stripped down now as the new Readme suggests. No config entries.
                                          Loading message is in German which is my language.
                                          However translation still does not seem to work here.
                                          Any suggestions?
                                          • cowboysdudeC
                                            I will look at it again tonight they may have changed the api… stay tuned.
                                            • 2 / 3
