    Bathroom Magic Mirror
    67 Posts 25 Posters 104.0k Views 27 Watching
      PaulB
      WOW! That looks so professional. Great work. Hope you have a lot of fun with the mirror :)
      • qu1queQ
        qu1que Project Sponsor
        Wow!! I like your mirror a lot. Impressive the final result. What are the buttons for?
        spitzlbergerjS 1 Reply Last reply
        • spitzlbergerjS
          spitzlbergerj Project Sponsor Module Developer @qu1que
          @qu1que Thanks a lot for your post.
          The bottom button boots the Raspberry in a safe way (without simply turning off the power)
          The top button controls the lights in the bathroom via a homematic webservice.
          Regards
          Josef
          http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
            PaulB
            @spitzlbergerj
            I love your work. Could you recommend any tipps on how to build a mirror in the bath? I would like to do this as my next project. So are there any Best Practices regarding any silicone or electronics?.
            Greetings from Germany :)
            • spitzlbergerjS
              spitzlbergerj Project Sponsor Module Developer @PaulB
              @paulb Hallo Paul,
              das Silicon, das ich verwendet habe, habe ich im Post angegeben. Der Spionspiegel verlangt ein spezielles Silicon (neutralvernetzend), damit die Beschichtung nicht angelöst wird. Und ansonsten habe ich Standard-Komponenten verwendet. Durch die Lüftungsöffnungen erhoffe ich mir eine bessere Belüftung. Bisher konnte ich keine Probleme feststellen.
              Grüße
              Sepp
              Regards
              Josef
              P 1 Reply Last reply
              • lavolp3L
                lavolp3 Module Developer
                @spitzlbergerj Impressive mirror!
                Especially like the lighting solution.
                What glass did you use? (also from Germany here)
                What is the material you have used for the backplate?
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                • spitzlbergerjS
                  spitzlbergerj Project Sponsor Module Developer @lavolp3
                  Hi @lavolp3,
                  I bought the LED light bar here
                  As described in the last section of the article, I purchased the mirror from Glas-Star.de and the Aluminium composite panel (ACP - german: Alu Dibond) from plattenzuschnitt24.de as my backplate.
                  The Aluminium composite panel is 4 mm thick and serves as a “black background” and as a mounting surface for all installations. It also stiffens the wooden frame on which I screwed the plate.
                  greetings
                  Sepp
                  Regards
                  Josef
                  lavolp3L michael5rM 2 Replies Last reply
                  • lavolp3L
                    lavolp3 Module Developer @spitzlbergerj
                    @spitzlbergerj OK so you’re using the Mirropane Chrome Spy there I assume.
                    Going to order that as well since I have the feeling it’s the best glass for a well lit bath.
                    Thanks for the Alu Dibond tip.
                      PaulB @spitzlbergerj
                      @spitzlbergerj Moin Sepp, danke für dein Feedback.
                      Werde es mal meiner Freundin vorschlagen… vllt wird das ja was :-D
                      Viele Grüße aus Hamburg,
                      Paul
                      • michael5rM
                        michael5r Module Developer @spitzlbergerj
                        @spitzlbergerj Super nice build!
                        If you don’t mind, a couple of questions:
                        1. Seeing that you screwed the Dibond panel into the wood frame, did you cover up the screw holes afterwards or are they just not visible through the glass?
                        2. I didn’t see any brackets or bracing in the photos, so how are you actually holding the monitor in place?
                        Thanks!
                        • spitzlbergerjS
                          spitzlbergerj Project Sponsor Module Developer @michael5r
                          @michael5r Good morning,
                          I’ll be happy to answer the questions:
                          1. I did not cover the screws. You still can’t see them through the glass.
                            If you want to be sure, it should be sufficient to paint the screws with a black permanent marker.
                            The only thing you see at the moment (if you know where to look ;-) ) is a small gap between the wooden frame and the silicone. At this point I apparently didn’t press the glass on well enough when I glued it to the frame. But that’s a little something.
                          1. The monitor is actually already being fixed by the cutout in the Dibond plate. I adapted the cutout very exactly to the size of the screen. With an adhesive tape around it this is then sufficiently fixed. But I finally screwed two small angles to the wooden frame, which hold the monitor securely in the cutout of the panel. This is now doubly secure.
                          Another tip about the motion detector (see also the supplement above in the text):
                          In addition to the cutout for the monitor, I would now have an additional small cutout for the radar board (20 x 40 mm) made. The radar detector works perfectly, but unfortunately not through the Dibond plate. I had to fix it at the bottom of the frame. That’s OK, but it would have been perfect behind the mirror glass.
                          Many greetings
                          Sepp
                          Regards
                          Josef
                          • A
                            acdacd2
                            very nice and waf.
                            How did you fix the mirror on the wood ?
                            Thanks,
                            marc,
                            • spitzlbergerjS
                              spitzlbergerj Project Sponsor Module Developer @acdacd2
                              @acdacd2 Hi, thank you very much.
                              The mirror glass is glued with silicone. The groove in the frame serves this purpose. See also the pictures/photos 3, 8 as well as 17 and 18.
                              Regards
                              Josef
                                SimtechBen
                                Very Nice Mirror! Quality work. Can you tell me how you wired up the radar sensor and where you finally placed it? I am assuming that you are using it to turn the screen on and off. What module did you use for that? I cannot get mine to trigger reliably.
                                  bhepler Module Developer
                                  Excellent work! That is a really sharp looking mirror. And you obviously planned out a lot ahead of time. I especially love the cutouts for the angle brackets in the corners. That is some serious attention to detail.
                                  • spitzlbergerjS
                                    spitzlbergerj Project Sponsor Module Developer @bhepler
                                    @bhepler Thank you. Yes, I’ve planned a long time. The mirror should be allowed to hang in the bathroom :-)
                                    Regards
                                    Josef
                                    • spitzlbergerjS
                                      spitzlbergerj Project Sponsor Module Developer @SimtechBen
                                      @simtechben Hi, I connected the radar sensor like a PIR sensor and followed this description in the broadest sense (https://www.nils-snake.de/archives/magic-mirror-bewegungssensor-einbauen-teil-5). I adapted the script to my needs. But the logic is still as described in the article.
                                      Now I glued the radar sensor outside in the middle of the lower frame board with white tape. So it lies horizontally on the frame at the bottom. Not optimal in alignment, but it works and my wife agreed ;-)
                                      As described above, I would simply place it behind the mirror if there was no Dibond plate or if it had a corresponding cutout.
                                      Regards
                                      Josef
                                        Ramez
                                        really nice :) just a small question, how did you mount it to the bath wall? you drilled the wall for some hings or what?
                                        many thanks :thumbs_up:
                                        • spitzlbergerjS
                                          spitzlbergerj Project Sponsor Module Developer @Ramez
                                          @ramez Hi,
                                          Thank you for your kind words of praise.
                                          On picture 7 you can see my assembly construction. I use the same principle as for a kitchen wall cabinet. A rail is mounted on the wall. The construction hangs then with special fittings on this rail. The advantage of these fittings is that they are height-adjustable and depth-adjustable. This makes exact positioning possible. This is very good for drilling between tiles, because you should only drill in the joints.
                                          I then fastened the frame itself with screws from above through the frame into the substructure (see picture 24).
                                          Here are the links:
                                          https://www.amazon.de/gp/product/B01MPZM5ER/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                                          https://www.amazon.de/gp/product/B01BDR8K32/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
                                          Regards
                                          Josef
                                          • cowboysdudeC
                                            Excellent job!
                                            • 1 / 4
