    602 Posts 67 Posters 2.3m Views 68 Watching
      shbatm Module Developer @evroom
      @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      Back on develop branch again.
      Please send me your config in a chat.
        shbatm Module Developer @Cr4z33
        @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        With omxplayer stream switching is almost OK if it wasn’t that it doesn’t select the wanted stream.
        I can’t replicate this issue. Directly sending notifications: of the form notification: "RTSP-PLAY", payload: "streamX" works as expected and switches to the correct stream when using autoStart: false, rotateStreams: true, rotateStreamTimeout: 0.
        How many streams do you have again? Is it less than 10?
        With vlc it’s a mess as multiple streams ALWAYS start at the same time after a voice command.
        I think this is related to the fact that VLC doesn’t close the streams automatically when switching, it puts the window in the background until it times out, then it closes. Try adding a shutdownDelay: 0 to your module config to make the VLC stream close immediately on hiding. Same thing with omxplayer though, switching appears to work as expected on my end.
        Please also make sure you have the latest version of PM2: sudo npm install -g pm2
          djuscha
          @shbatm
          did develop update now, both streams are on stop and error messages :(
          PM2            | App [omx_stream2:1] online
          0|mm           | Initializing new module helper ...
          0|mm           | Module helper loaded: newsfeed
          2|omx_stream1  | * failed to add service - already in use?
          2|omx_stream1  | Video codec omx-mjpeg width 352 height 288 profile -99 fps 30.000000
          2|omx_stream1  | Subtitle count: 0, state: off, index: 1, delay: 0
          2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1221 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
          PM2            | App [omx_stream1:2] exited with code [134] via signal [SIGINT]
          PM2            | App [omx_stream1:2] starting in -fork mode-
          PM2            | App [omx_stream1:2] online
          1|omx_stream2  | * failed to add service - already in use?
          1|omx_stream2  | Video codec omx-mjpeg width 352 height 288 profile -99 fps 30.000000
          1|omx_stream2  | Subtitle count: 0, state: off, index: 1, delay: 0
          1|omx_stream2  | /usr/bin/omxplayer: Zeile 67:  1244 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
          PM2            | App [omx_stream2:1] exited with code [134] via signal [SIGINT]
          PM2            | App [omx_stream2:1] starting in -fork mode-
          2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1287 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
          0|mm           | Module helper loaded: MMM-RTSPStream
          0|mm           | All module helpers loaded.
          0|mm           | Starting server on port 8080 ...
          0|mm           | Server started ...
          0|mm           | Connecting socket for: updatenotification
          0|mm           | Connecting socket for: MMM-Fuel
          0|mm           | Starting module helper: MMM-Fuel
          0|mm           | Connecting socket for: newsfeed
          0|mm           | Starting module: newsfeed
          0|mm           | Connecting socket for: MMM-RTSPStream
          0|mm           | PM2: Stopping all OMXPlayer Streams...
          0|mm           | Sockets connected & modules started ...
          1|omx_stream2  | /usr/bin/omxplayer: Zeile 67:  1320 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
          2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1349 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
          1|omx_stream2  | /usr/bin/omxplayer: Zeile 67:  1399 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
          2|omx_stream1  | /usr/bin/omxplayer: Zeile 67:  1422 Abgebrochen             (Speicherabzug geschrieben) LD_LIBRARY_PATH="$OMXPLAYER_LIBS${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}" $OMXPLAYER_BIN "$@"
          0|mm           | Launching application.
          0|mm           | libGL error: MESA-LOADER: failed to retrieve device information
          ^C
          pi@raspberrypi:~ $ pm2 status
          │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
          │ mm          │ 0  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.5 MB   │
          │ omx_stream1 │ 2  │ N/A  │ fork   │ stopped │ 9   │ 0%     │ 0 B      │
          │ omx_stream2 │ 1  │ N/A  │ fork   │ stopped │ 9   │ 0%     │ 0 B      │
           Use `pm2 show <id|name>` to get more details about an app
          pi@raspberrypi:~ $
          can you undo that somehow?
            shbatm Module Developer @djuscha
            @djuscha said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            This looks like the same error I got when I tried to use omxplayer with the OpenGL driver enabled in raspi-config. You’ll have to use the legacy driver if you want to use omxplayer on the most recent version of Raspbian.
            EDIT 10-Jan-19: Use the latest develop branch version. omxplayer requires the --no-osd flag to work properly with the OpenGL (Fake KMS) driver.
            • Cr4z33C Offline
              Cr4z33 @shbatm
              @shbatm I can confirm that I followed the whole instructions properly and I am using notification: "RTSP-PLAY", payload: "streamX" indeed for my 7 different streams (so yes less than 10).
              All I can say is that it is NOT working as intended. :winking_face:
              Anyway I always forgot to post the (latest version) PM2 log so here it is if you can find anything helpful?
              I wish I could do more, but again I am not skilled enough sorry… :smiling_face_with_open_mouth_cold_sweat:
              PM2 Log
                @cr4z33 @evroom the last things I can suggest to try:
                1. @Cr4z33 Make sure you have autoStart: false in your config. @evroom yours should be true.
                2. Update the module one more time:
                cd ~/MagicMirror/modules/MMM-RTSPStream
                git fetch --al && git pull
                rm -R node_modules/
                npm install
                1. Nuke and update your pm2:
                pm2 kill
                rm ~/.pm2/dump.pm2
                sudo npm i -g pm2
                1. Restart the MM script (you’ll have to redo pm2 save BEFORE you run any streams if you want the MM to start on boot).
                Cr4z33C evroomE 2 Replies Last reply Reply Quote 0
                • Cr4z33C Offline
                  Cr4z33 @shbatm
                  @shbatm I feel sorry, but nothing has improved. :disappointed_face:
                  • evroomE Offline
                    evroom @shbatm
                    @shbatm
                    Performed all steps.
                    No change: no stream is started (nothing in the pm2 logs).
                    Then deleted the MMM-RTSPStream module completely.
                    Rebooted.
                    Installed the module again.
                    Then performed all steps to get in the develop branch.
                    I ended up disabling the module and running a script under pm2 control.
                    Pity, it worked just fine till I started to test the changes.
                    The ‘pm2 delete omx_stream1’ was the final blow, but should not be the reason for a stream not to appear again.
                    Perhaps a complete re-install of MM is necessary, but that is too much work for now.
                    Should I be forced to do so in the future, I will give MMM-RTSPStream a try again.
                    MagicMirror version: 2.37.0
                      @cr4z33 Can you please post (or send in chats) your current config. I’m curious if we’re missing something obvious.
                      @evroom I’m sorry you can’t get it working again. I’m at a loss as to why it’s not starting the streams properly. Everything in your config you sent looks like it should be working from the module’s end. The only thing I can think of is something else is interfering and preventing the module from starting. (Would show up as a “MMM-RTSPStream is suspended…” in the DevTools (web browser) console logs.
                        anthony6608 @evroom
                        @evroom I’m sorry but I haven’t read too far back in the posts but have you tried disabling your other modules to determine if there’s a conflict somewhere?
                        The reason I ask is because shbatm helped me recently with everything setup correctly but stream not displaying. One of the issues turned out to be the GoogleMapsTraffic module. Just wanted to mention that just in case. Good luck!
                        • Cr4z33C Offline
                          Cr4z33 @shbatm
                          @shbatm here you go. :slightly_smiling_face:
                          config.js
                            costascontis
                            hi ,trying to use this module to watch an ip cam.After i start MM i get in the log:
                            Starting stream stream1 with args: [
                                "--avdict",
                                "rtsp_transport:tcp",
                                "--win",
                                "738, 63, 1090, 305",
                                "--live",
                                "--video_queue",
                                "4",
                                "--fps",
                                "30",
                                "rtsp://admin:@192.168.1.108:554/12?"
                            error: object file .git/objects/0a/340d5d575f5675a19c2108bb1acc9f20576259 is empty
                            fatal: loose object 0a340d5d575f5675a19c2108bb1acc9f20576259 (stored in .git/objects/0a/340d5d575f5675a19c2108bb1acc9f20576259) is corrupt
                            fatal: The remote end hung up unexpectedly
                            Starting PM2 for omx_stream1
                            PM2 started for omx_stream1
                            when i press pause and play again i get:
                            Stopping stream stream1
                            Stopping PM2 process: omx_stream1
                                "--avdict",
                                "--win",
                                "--live",
                                "--video_queue",
                                "4",
                                "--fps",
                                "30",
                            I just get a blank screen.Steam is working nice with vlc,its the second low res stream of this camera.
                            config:
                                module: "MMM-RTSPStream",
                                position: "top_center",
                                    autoStart: true,
                                    rotateStreamTimeout: 10,
                                    moduleWidth: 354,
                                    moduleHeight: 240,
                                    localPlayer: 'omxplayer',
                                    remotePlayer: 'none',
                                    showSnapWhenPaused: false,
                                    remoteSnaps: false,
                                    stream1: {
                                        url: 'rtsp://admin:@192.168.1.108:554/12?',
                                        frameRate: undefined,
                                        width: undefined,
                                        height: undefined,
                            any ideas?
                              shbatm Module Developer @costascontis
                              For the first one:
                              @costascontis said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                              That’s a new one by me… maybe time for Google on that one.
                              For the blank screen: watch all of the PM2 logs (pm2 logs command) and see if you see something like this:
                              1|omx_stre | * failed to add service - already in use?
                              1|omx_stre | /usr/bin/omxplayer: line 67: 15281 Aborted (core dumped)
                              If you do, you probably have the latest version of Raspbian with the OpenGL driver enabled in raspi-config– omxplayer isn’t working properly with the OpenGL driver enabled, if you want to use omxplayer, you’ll have to enable the legacy driver: https://www.raspberrypi.org/forums/viewtopic.php?t=204794
                              If you see anything else in the PM2 logs, let me know.
                                costascontis
                                i tested the bunny rtsp and another camera that output a “rtsp://ipcamera:554/ch0.h264” link and both work,so i think the camera i want to use that output the “rtsp://ipcamera:554/12” link has a problem with omxplayer.I will look at pm2 logs and i ll get back to you,thanx
                                edit : the links that worked for me did not auto started but i had to press pause and play again.
                                pm2 log :
                                0|mm       | Starting stream stream1 with args: [
                                0|mm       |     "--avdict",
                                0|mm       |     "rtsp_transport:tcp",
                                0|mm       |     "--win",
                                0|mm       |     "738, 63, 1090, 305",
                                0|mm       |     "--live",
                                0|mm       |     "--video_queue",
                                0|mm       |     "4",
                                0|mm       |     "--fps",
                                0|mm       |     "30",
                                0|mm       |     "rtsp://admin:@192.168.1.108/12.h264"
                                0|mm       | ]
                                0|mm       | PM2: omx_stream1 already running. Stopping old instance...
                                0|mm       | Starting PM2 for omx_stream1
                                0|mm       | PM2 started for omx_stream1
                                i see no error but no streaming,only the name of the cam and black screen…
                                  djuscha
                                  I found that on my troubleshooting on the internet maybe that helps us?
                                  RTSP-Stream-Viewer
                                    pm2 log :
                                    0|mm       |     "--avdict",
                                    0|mm       |     "--win",
                                    0|mm       |     "--live",
                                    0|mm       |     "4",
                                    0|mm       |     "--fps",
                                    0|mm       |     "30",
                                    0|mm       | ]
                                    Looks like you’re using an older version of the module based on the log. Try pulling the new version and switching to the develop branch… you should see the full omxplayer command line output to the logs, which you can use to test your camera outside of MM and the module.
                                    • swvalentiS Offline
                                      swvalenti Project Sponsor
                                      Updated to dev branch and use rotate streams true (3) and after 3 hours it completely locks up my entire RPi and I have to pull the plug and disable same. Seems like it is too much on CPU to keep starting/stopping OMX every 15 seconds to cause the crash? Single stream average RPi temp is 128f but when rotate is on it jumps to 160f. Maybe thats the issue?
                                        shbatm Module Developer @swvalenti
                                        @swvalenti That could be. OMX player doesn’t switch very easily. VLC switching was working well on the newest version of Rasbian with OpenGL (Fake KMS) enabled.
                                        swvalentiS 1 Reply Last reply Reply Quote 0
                                          swvalenti Project Sponsor @shbatm
                                          @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                          How do I make that switch and implement? Sorry for the noob question.
                                            RTSP-Stream-Viewer
                                            Thanks for the link. Bits of that script look like the script I saw which originally inspired me to use omxplayer, but it has some additional options (like pushing a video off the screen instead of stopping it) that seem promising. I ended up using pm2 instead of screen because that’s what most MM users were already using, and it had the auto restart feature built in.
                                            I don’t have much time for the next month or so to keep playing with the omx version, so if you wouldn’t mind, please open an issue on GitHub, and if you or anyone has time/skills to implement, I’ll be happy to take a PR.
                                            To-do (notes to myself or anyone that works on this):
                                            1. Implement dbus control to move the video off-screen instead of stopping it when we need to hide it: Example dbuscontrol.sh; npm dbus Package
                                            2. Implement ffmpeg & vlc’s shutdownDelay option for omx player (e.g. move the video off-screen and stop it after x seconds instead of stopping it immediately when hiding a stream).
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 30
                                            • 31
                                            • 11 / 31
