    602 Posts 67 Posters 2.4m Views 68 Watching
    • evroomE
      evroom @shbatm
      @shbatm
      Performed all steps.
      No change: no stream is started (nothing in the pm2 logs).
      Then deleted the MMM-RTSPStream module completely.
      Rebooted.
      Installed the module again.
      Then performed all steps to get in the develop branch.
      I ended up disabling the module and running a script under pm2 control.
      Pity, it worked just fine till I started to test the changes.
      The ‘pm2 delete omx_stream1’ was the final blow, but should not be the reason for a stream not to appear again.
      Perhaps a complete re-install of MM is necessary, but that is too much work for now.
      Should I be forced to do so in the future, I will give MMM-RTSPStream a try again.
      MagicMirror version: 2.37.0
      A 1 Reply Last reply
        shbatm Module Developer @Cr4z33
        @cr4z33 Can you please post (or send in chats) your current config. I’m curious if we’re missing something obvious.
        @evroom I’m sorry you can’t get it working again. I’m at a loss as to why it’s not starting the streams properly. Everything in your config you sent looks like it should be working from the module’s end. The only thing I can think of is something else is interfering and preventing the module from starting. (Would show up as a “MMM-RTSPStream is suspended…” in the DevTools (web browser) console logs.
        Cr4z33C 1 Reply Last reply
        • A
          anthony6608 @evroom
          @evroom I’m sorry but I haven’t read too far back in the posts but have you tried disabling your other modules to determine if there’s a conflict somewhere?
          The reason I ask is because shbatm helped me recently with everything setup correctly but stream not displaying. One of the issues turned out to be the GoogleMapsTraffic module. Just wanted to mention that just in case. Good luck!
          • Cr4z33C
            Cr4z33 @shbatm
            @shbatm here you go. :slightly_smiling_face:
            config.js
              costascontis
              hi ,trying to use this module to watch an ip cam.After i start MM i get in the log:
              Starting stream stream1 with args: [
                  "--avdict",
                  "rtsp_transport:tcp",
                  "--win",
                  "738, 63, 1090, 305",
                  "--live",
                  "--video_queue",
                  "4",
                  "--fps",
                  "30",
                  "rtsp://admin:@192.168.1.108:554/12?"
              error: object file .git/objects/0a/340d5d575f5675a19c2108bb1acc9f20576259 is empty
              fatal: loose object 0a340d5d575f5675a19c2108bb1acc9f20576259 (stored in .git/objects/0a/340d5d575f5675a19c2108bb1acc9f20576259) is corrupt
              fatal: The remote end hung up unexpectedly
              Starting PM2 for omx_stream1
              PM2 started for omx_stream1
              when i press pause and play again i get:
              Stopping stream stream1
              Stopping PM2 process: omx_stream1
                  "--avdict",
                  "--win",
                  "--live",
                  "--video_queue",
                  "4",
                  "--fps",
                  "30",
              I just get a blank screen.Steam is working nice with vlc,its the second low res stream of this camera.
              config:
                  module: "MMM-RTSPStream",
                  position: "top_center",
                      autoStart: true,
                      rotateStreams: true,
                      rotateStreamTimeout: 10,
                      moduleWidth: 354,
                      moduleHeight: 240,
                      localPlayer: 'omxplayer',
                      remotePlayer: 'none',
                      showSnapWhenPaused: false,
                      remoteSnaps: false,
                      stream1: {
                          url: 'rtsp://admin:@192.168.1.108:554/12?',
                          frameRate: undefined,
                          width: undefined,
                          height: undefined,
              any ideas?
                shbatm Module Developer @costascontis
                For the first one:
                @costascontis said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                That’s a new one by me… maybe time for Google on that one.
                For the blank screen: watch all of the PM2 logs (pm2 logs command) and see if you see something like this:
                1|omx_stre | * failed to add service - already in use?
                1|omx_stre | /usr/bin/omxplayer: line 67: 15281 Aborted (core dumped)
                If you do, you probably have the latest version of Raspbian with the OpenGL driver enabled in raspi-config– omxplayer isn’t working properly with the OpenGL driver enabled, if you want to use omxplayer, you’ll have to enable the legacy driver: https://www.raspberrypi.org/forums/viewtopic.php?t=204794
                If you see anything else in the PM2 logs, let me know.
                  costascontis
                  i tested the bunny rtsp and another camera that output a “rtsp://ipcamera:554/ch0.h264” link and both work,so i think the camera i want to use that output the “rtsp://ipcamera:554/12” link has a problem with omxplayer.I will look at pm2 logs and i ll get back to you,thanx
                  edit : the links that worked for me did not auto started but i had to press pause and play again.
                  pm2 log :
                  0|mm       | Starting stream stream1 with args: [
                  0|mm       |     "--avdict",
                  0|mm       |     "rtsp_transport:tcp",
                  0|mm       |     "--win",
                  0|mm       |     "738, 63, 1090, 305",
                  0|mm       |     "--live",
                  0|mm       |     "--video_queue",
                  0|mm       |     "4",
                  0|mm       |     "--fps",
                  0|mm       |     "30",
                  0|mm       |     "rtsp://admin:@192.168.1.108/12.h264"
                  0|mm       | ]
                  0|mm       | PM2: omx_stream1 already running. Stopping old instance...
                  0|mm       | Starting PM2 for omx_stream1
                  0|mm       | PM2 started for omx_stream1
                  i see no error but no streaming,only the name of the cam and black screen…
                    djuscha
                    I found that on my troubleshooting on the internet maybe that helps us?
                    RTSP-Stream-Viewer
                      pm2 log :
                      0|mm       |     "--avdict",
                      0|mm       |     "--win",
                      0|mm       |     "--live",
                      0|mm       |     "4",
                      0|mm       |     "--fps",
                      0|mm       |     "30",
                      0|mm       | ]
                      Looks like you’re using an older version of the module based on the log. Try pulling the new version and switching to the develop branch… you should see the full omxplayer command line output to the logs, which you can use to test your camera outside of MM and the module.
                      • swvalentiS
                        swvalenti Project Sponsor
                        Updated to dev branch and use rotate streams true (3) and after 3 hours it completely locks up my entire RPi and I have to pull the plug and disable same. Seems like it is too much on CPU to keep starting/stopping OMX every 15 seconds to cause the crash? Single stream average RPi temp is 128f but when rotate is on it jumps to 160f. Maybe thats the issue?
                          shbatm Module Developer @swvalenti
                          @swvalenti That could be. OMX player doesn’t switch very easily. VLC switching was working well on the newest version of Rasbian with OpenGL (Fake KMS) enabled.
                          swvalentiS 1 Reply Last reply
                          • swvalentiS
                            swvalenti Project Sponsor @shbatm
                            @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                            How do I make that switch and implement? Sorry for the noob question.
                              shbatm Module Developer @djuscha
                              @djuscha said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                              RTSP-Stream-Viewer
                              Thanks for the link. Bits of that script look like the script I saw which originally inspired me to use omxplayer, but it has some additional options (like pushing a video off the screen instead of stopping it) that seem promising. I ended up using pm2 instead of screen because that’s what most MM users were already using, and it had the auto restart feature built in.
                              I don’t have much time for the next month or so to keep playing with the omx version, so if you wouldn’t mind, please open an issue on GitHub, and if you or anyone has time/skills to implement, I’ll be happy to take a PR.
                              To-do (notes to myself or anyone that works on this):
                              1. Implement dbus control to move the video off-screen instead of stopping it when we need to hide it: Example dbuscontrol.sh; npm dbus Package
                              2. Implement ffmpeg & vlc’s shutdownDelay option for omx player (e.g. move the video off-screen and stop it after x seconds instead of stopping it immediately when hiding a stream).
                                @swvalenti said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                Look back at previous posts in this thread, there should be several posts from the past month about switching and upgrading.
                                  @djuscha Use the latest develop branch version if you still want to use omxplayer with OpenGL (Fake KMS). I was stumbling around and found that omxplayer requires the --no-osd flag to work properly with the OpenGL (Fake KMS) driver.
                                    costascontis
                                    can someone use vlc instead of omxplayer with your module?If yes whats the pro and con on that?
                                    BKeyportB S 2 Replies Last reply
                                    • BKeyportB
                                      BKeyport Module Developer @costascontis
                                      I know on the develop branch you can.
                                      Pro: it kept the original aspect ratio.
                                      con: it didn’t work more than once.
                                        Yes, its still experimental but was working fine for me. If you’re on a Raspberry Pi, it works best if you’re using the newest distro of Raspbian because VLC has Hardware Acceleration enabled.
                                        Your mileage may vary between omxplayer and VLC. OMXPlayer is finicky and doesn’t rotate streams well (will be working on that)–VLC should in theory be much more stable and easy to use, but some people have had issues getting it to respond correctly on the Pi.
                                        Back up a few pages on this thread to find out how to install the develop branch.
                                        Cr4z33C 3 Replies Last reply
                                        • Cr4z33C
                                          Cr4z33 @shbatm
                                          @shbatm I hope your module will be perfect one day until then I have unfortunately to give up with the channel switching function and set a static Radio/TV stream. :thumbs_up_medium-light_skin_tone:
                                          • Cr4z33C
                                            Cr4z33 @shbatm
                                            Hi @shbatm ,
                                            how is the bug fixing job doing right now? :)
                                            I’ve done in the meantime some testing both with VLC and OMXplayer options by using different streaming sources like mp3 podcasts, mp4 live channels & some IP cameras (that I’ve got at home).
                                            I can confirm that something is wrong in the module code because the EXACT same issue (wrong stream selected while switching) is happening with the above sources. :confused_face:
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 30
                                            • 31
                                            • 11 / 31
