    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 918.1k Views 74 Watching
      Johans @j.e.f.f
      @j-e-f-f
      No, It doesn’t come back.
      I made a new installation on fresh SD card.
      All works fine without installing your module, after that it’s not working anymore.
      J J 2 Replies Last reply Reply Quote 0
        Johans @Johans
        When I run directly in the browser, it’s OK, but thats not the main goal, should run via the MagicMirror.
        • H Offline
          hco125
          I posted an issue on your module link in GitHub, but no response yet. Please see this link for details. Both the config in the link as well as the one below do the same thing…loading infinitely.
          			module: 'MMM-DarkSkyForecast',
          			header: "Weather",
          			position: 'top_center',
          			disabled: false,
          				updateInterval: 10,
          				units: 'us',
          				forecastHeaderText: "O'Neill, NE",
          				iconset: '5c',
          				apiKey: 'blocked for privacy',
          				latitude: '42.457649',
          				longitude: '-98.647789',
          				forecastLayout: 'tiled',```
          • lavolp3L Offline
            lavolp3 Module Developer @hco125
            @hco125
            Time to go do some debugging. Ican imagine noone will be able to help you with the information given.
            Please do the following:
            Start the mirror in dev mode
            npm start dev
            OR
            Open the mirror webpage on another browser (MIRRORIP:8080), press F12 for dev mode
            In both cases, try to find error messages referring to this module and post them here.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • H Offline
              hco125
              I stripped down my MagicMirror configuration as well, so that we know that another module is not interfering. The modules that ARE on this config include: alert, updatenotification, MMM-ModuleScheduler, clock, MMM-AlarmClock, MMM-DarkSkyForecast, and MMM-Screencast. Here are the errors in the console running MagicMirror and accessing on Chrome with those modules running.
              moment-timezone-with-data.js:472 Moment Timezone has no data for none. See http://momentjs.com/timezone/docs/#/data-loading/.
              logError	@	moment-timezone-with-data.js:472
              57
              fn.tz	@	moment-timezone-with-data.js:554
              getDom	@	clock.js:79
              (anonymous)	@	main.js:110
              updateDom	@	main.js:109
              updateDom	@	main.js:514
              updateDom	@	module.js:358
              (anonymous)	@	clock.js:45
              However, I then stripped ALL modules EXCEPT MMM-DarkSkyForecast and rechecked the console. I get NO errors, and the log is as follows, but the modules still loads infinitely, with no display of weather (see screenshot, below):
              Initializing MagicMirror.
              translator.js:201 Loading core translation file: translations/en.json
              translator.js:224 Loading core translation fallback file: translations/en.json
              loader.js:182 Load script: modules/MMM-DarkSkyForecast//MMM-DarkSkyForecast.js
              module.js:469 Check MagicMirror version for module 'MMM-DarkSkyForecast' - Minimum version:  2.2.0 - Current version: 2.6.0
              module.js:471 Version is ok!
              module.js:477 Module registered: MMM-DarkSkyForecast
              loader.js:152 Bootstrapping module: MMM-DarkSkyForecast
              loader.js:182 Load script: vendor/node_modules/moment/min/moment-with-locales.js
              loader.js:182 Load script: modules/MMM-DarkSkyForecast/skycons.js
              loader.js:157 Scripts loaded for: MMM-DarkSkyForecast
              loader.js:197 Load stylesheet: modules/MMM-DarkSkyForecast/MMM-DarkSkyForecast.css
              loader.js:159 Styles loaded for: MMM-DarkSkyForecast
              loader.js:161 Translations loaded for: MMM-DarkSkyForecast
              loader.js:197 Load stylesheet: css/custom.css
              MMM-DarkSkyForecast.js:138 Starting module: MMM-DarkSkyForecast
              main.js:468 All modules started!
              module.js:156 MMM-DarkSkyForecast received a system notification: ALL_MODULES_STARTED
              module.js:156 MMM-DarkSkyForecast received a system notification: MODULE_DOM_CREATED
              module.js:156 MMM-DarkSkyForecast received a system notification: DOM_OBJECTS_CREATED
              So after adding in one module at a time to determine which one was throwing the errors I posted above, it is the default MagicMirror “clock” module, and I do not believe it is the cause of the MMM-DarkSkyForecast problems.
                j.e.f.f Project Sponsor Module Developer @Johans
                @johans @hco125 i believe your issues are related. If the module runs in the web browser, but not on the mirror, then we’re seeing an issue with the difference in JavaScript syntax supported by Chrome versus Electron. I’ll need to debug your configs in Electron running on the Pi, as the errors will only be seen in the browser console.
                Sorry I’ve been slow to respond. I just got back from visiting family for the holidays so I haven’t been checking this forum at all nor the issue list in my git repo. Will take a look and let you know if I find any problems.
                  djsunrise19
                  Looks very nice. Is there a way to get the “feels like” temperature, too? I can’t find anything about it.
                  • H Offline
                    hco125
                    @j-e-f-f & @lavolp3
                    I figured out the issue…idiot error (me). I typed the config option as “apiKey” instead of “apikey” and it wouldn’t read it as registered. So sorry for taking your time. Works now.
                      j.e.f.f Project Sponsor Module Developer @djsunrise19
                      @djsunrise19 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                      I’m planning to add it. This is something I’d like as well.
                        @johans said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                        @j-e-f-f
                        Can you try something? Completely remove MMM-DarkSkyForecast (i.e.delete the directory with rmdir -rf MMM-DarkSkyForecast), and comment out the entry in the config. Restart MM. Does your player come back now? If so, try this:
                        Reinstall my module using git clone ... but DON’T run npm install in the MMM-DarkSkyForecast directory. All of the dependencies are currently included with Magic Mirror, so it should work as-is.
                        Put the DarkSky entry back in your config and restart MM. If everything works then the issue is that my module is installing a different version of one of the dependencies than what is included in MM, and likely is causing the incompatibility with the MMM-Widget module.
                        • richland007R Offline
                          richland007
                          @j-e-f-f Thank you for this nice weather module :)
                          I do have a strange occurrence happening however… no matter if i use ca, us, si for units in front of every high temperature number i get a square… the temperature is displayed along with that square … what is that??
                          Oh another thing …how can i make the background of your module non transparent/black or semi transparent?? I am trying to use the @Sean MMM-WeatherBackground and the majority of pictures are too bright to read this module.
                          • Cr4z33C Offline
                            Cr4z33 @j.e.f.f
                              richland007
                              Any ideas at what those squares are in front of my temperature numbers everybody ?? ;)
                                j.e.f.f Project Sponsor Module Developer @richland007
                                @richland007 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                Try this in your custom.css file:
                                .MMM-DarkSkyForecast .module-content {
                                  background-color: rgba(0,0,0,0.5);
                                The first three parameters 0,0,0 are the color (in this case black), and the last parameter 0.5 is the level of transparency. Adjust accordingly to suit your needs.
                                  No idea why this is happening, but it generally means that the browser is trying to render a character that is outside of the character set.
                                  Can you PM me with your config? I wonder if the data is providing those characters.
                                  richland007R Cr4z33C 2 Replies Last reply Reply Quote 0
                                    richland007 @j.e.f.f
                                    @j-e-f-f Thank you for your reply.
                                    Do you want my entire MM config.js file or just the MMM-DarkSkyForecast part of it??
                                    D
                                    • lavolp3L Offline
                                      EDIT: SORRY, nevermind… small mistake in my latitude gave wrong values…
                                      • Cr4z33C Offline
                                        Cr4z33 @j.e.f.f
                                        @j-e-f-f any way I can see the wind direction too?
                                        • lavolp3L Offline
                                          lavolp3 Module Developer @Cr4z33
                                          @cr4z33 it is shown if you include
                                          concise: false
                                          into the config.
                                          That’s the way to show more info.
                                          If you want to ONLY show the wind direction you would have to manipulate the .js file manually in line 429
                                                windSpeed: Math.round(speed) + " " + this.getUnit("windSpeed") + (!this.config.concise ? " " + this.getOrdinal(bearing) : ""),
                                          into
                                                windSpeed: Math.round(speed) + " " + this.getUnit("windSpeed") + " " + this.getOrdinal(bearing),
                                          In my case this unfortunately messes up the layout a bit. But it seems to work.
                                          Cr4z33C J 2 Replies Last reply Reply Quote 0
                                          • Cr4z33C Offline
                                            Cr4z33 @lavolp3
                                            @lavolp3 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                            concise: false
                                            into the config.
                                            That’s already perfect thanks! :thumbs_up_medium-light_skin_tone:
                                            • 16
                                            • 17
                                            • 5 / 17
