    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 828.8k Views 74 Watching
    • richland007R Offline
      richland007
      Any ideas at what those squares are in front of my temperature numbers everybody ?? ;)
        j.e.f.f Project Sponsor Module Developer @richland007
        @richland007 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
        how can i make the background of your module non transparent/black or semi transparent??
        Try this in your custom.css file:
        .MMM-DarkSkyForecast .module-content {
          background-color: rgba(0,0,0,0.5);
        The first three parameters 0,0,0 are the color (in this case black), and the last parameter 0.5 is the level of transparency. Adjust accordingly to suit your needs.
          No idea why this is happening, but it generally means that the browser is trying to render a character that is outside of the character set.
          Can you PM me with your config? I wonder if the data is providing those characters.
          richland007R Cr4z33C 2 Replies Last reply Reply Quote 0
            richland007 @j.e.f.f
            @j-e-f-f Thank you for your reply.
            Do you want my entire MM config.js file or just the MMM-DarkSkyForecast part of it??
            D
            • lavolp3L Offline
              lavolp3 Module Developer
              EDIT: SORRY, nevermind… small mistake in my latitude gave wrong values…
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • Cr4z33C Offline
                Cr4z33 @j.e.f.f
                @j-e-f-f any way I can see the wind direction too?
                • lavolp3L Offline
                  lavolp3 Module Developer @Cr4z33
                  @cr4z33 it is shown if you include
                  concise: false
                  into the config.
                  That’s the way to show more info.
                  If you want to ONLY show the wind direction you would have to manipulate the .js file manually in line 429
                        windSpeed: Math.round(speed) + " " + this.getUnit("windSpeed") + (!this.config.concise ? " " + this.getOrdinal(bearing) : ""),
                  into
                        windSpeed: Math.round(speed) + " " + this.getUnit("windSpeed") + " " + this.getOrdinal(bearing),
                  In my case this unfortunately messes up the layout a bit. But it seems to work.
                  Cr4z33C J 2 Replies Last reply Reply Quote 0
                  • Cr4z33C Offline
                    Cr4z33 @lavolp3
                    @lavolp3 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                    concise: false
                    into the config.
                    That’s already perfect thanks! :thumbs_up_medium-light_skin_tone:
                      D
                      Just the dark sky portion.
                        jackoliver361
                        Hey i have your module working but when i also add the MMM-Awsome-alexa module it moves to this location even though ive set it to display in the top_right. It goes into the right location when mmm-awesome-alexa is removed. Any ideas ? 0_1548268916774_problem.JPG
                        • 10
                        • 11
                        • 33
                        • 34
                        • 9 / 34
