    MMM-MyCommute
    286 Posts 80 Posters 716.6k Views 77 Watching
      j.e.f.f Project Sponsor Module Developer @Smotx
      @smotx The module is designed to be as frugal as possible when making requests. Outside of your start and end times, no requests are being made to Google. Between those times, requests are made every ten minutes, one for each destination configured.
      • citizendevpiC Offline
        citizendevpi @Bob
        @bob so how often do you refresh the data to stay under the limit of the “free” tier?
          Aries1984 Module Developer
            rmonteroc
            Hi, yesterday this module stopped working for me, I reinstalled it using the default config and still not working, I don’t even get the “loading” message
            Anybody else?
            • joela85J Offline
              joela85
              Hi, mine was working fine for me this morning.
              • Y Offline
                yupwho
                @j-e-f-f - Thanks for creating this module.
                I have a question - is it possible to use the Origin property inside the destination objects? The use case is that i’ll like to display the commute to work in the morning and in the evening display the traffic back from work. I believe this will be possible if origin can be defined at each destination level.
                  j.e.f.f Project Sponsor Module Developer @yupwho
                  @yupwho no, the module doesn’t work that way. However you can define a second instance if the module and use your work as the origin and route your way home. However it wouldn’t be an accurate representation of commute time because the module reflects current traffic patterns. So it might say your trip home right now is 20 minutes but it might actually be an hour at the time you actually commute home.
                    Skeeter
                    Does this module still work? I’ve just installed it and get nothing other than “Loading…” no matter what I try. I’ve used the example config (with my own API key) and tried a number from scratch and nothing works.
                    The MMM-Traffic module this is based on is installed and works so I know my API is working. Anything dumb I should check for to make sure I’ve not screwed up?
                    Edit: Solved it. When running in Docker I needed to restart the Container for the API key to get picked up and work.
                    • F Offline
                      fotis.str @Looking
                      @looking Hi looking, I’m having the same an error display how did you solved it ? thanks in advance, FS
                        robiv8
                        Is this modul working also in germany?
                          @robiv8 yeah it does work for me perfectly. Can send you my latest config if you want?
                            robiv8
                            Au das wäre sehr nett :kissing_face:
                            • L Offline
                              lolobyte @Aries1984
                              @aries1984
                              Bitte mir dann auch wenn moglich.
                              • K Offline
                                keyun21
                                Newbie here I guess i have to pay for Google API service right? without that this module not going to work correct?
                                • BKeyportB Offline
                                  BKeyport Module Developer @keyun21
                                  @keyun21 You have to set up a pay account, including a credit card, but they give you a specific number of free accesses, and if you keep the module to a timeframe that you’d normally look at it, you’d have a hard time exceeding those uses.
                                  • K Offline
                                    keyun21 @BKeyport
                                    @bkeyport said in MMM-MyCommute:
                                    Thanks a lot I will look into to see how many I can get free and how to set up module to run specific times?
                                      Hi everybody,
                                      sorry for the late reply. Haven’t been here much in the last couple of weeks. Here’s my config:
                                              module: 'MMM-MyCommute',
                                              position: 'bottom_right',
                                              header: 'Traffic',
                                              classes: 'default everyone',
                                                  apikey: 'your API Key',
                                                  origin: 'Marienplatz 1, 80331 München',
                                                  startTime: '05:00',
                                                  endTime: '10:00',
                                                  hideDays: [0, 6],
                                                  destinations: [
                                                          destination: 'Belgradstraße 13, 80796 München',
                                                          label: 'Good Food',
                                                          mode: 'driving',
                                                          color: '#82E5AA'
                                        seanluse41
                                        Can this module support Japanese addresses?
                                        The default config and values work for me, but putting in Japanese addresses returns loading… forever.
                                        • T Offline
                                          thoeng
                                          This is great and very practical module! Everything is working on me but i would like to remain below USD200 (40K calls)/mo API call request. This means staying below 1.3K calls/day
                                          However, after installed I can see 570+ request call in 2 hours on Google API dashboard. This is despite setting pollFrequency: 1200000 (20mins interval) on MM config.
                                          Any help please?
                                          I 1 Reply Last reply Reply Quote 1
                                            charp07
                                            MM is only loading the “loading…” text for this module. All my other modules are showing right. I am getting request on the Google API Console under the Directions API. So I believe that I must have the module installed correctly. Does anyone know why this would be happening?
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
